1130home Posted April 7, 2005 Report Share Posted April 7, 2005 I know this might have been covered but what hose do you take off in which to suck seafoam into the injectors? :P Link to comment Share on other sites More sharing options...
merlin390 Posted April 8, 2005 Report Share Posted April 8, 2005 if you want to run seafoam through the injectors then pour it into the gas tank. If you want to run it through the intake, use a piece of vac line and an unused port on the vac tree behind the TB Link to comment Share on other sites More sharing options...
1130home Posted April 8, 2005 Author Report Share Posted April 8, 2005 if you want to run seafoam through the injectors then pour it into the gas tank. If you want to run it through the intake, use a piece of vac line and an unused port on the vac tree behind the TB←Thanks Link to comment Share on other sites More sharing options...
xcaliber912 Posted April 8, 2005 Report Share Posted April 8, 2005 that s stuff is incredible.....i used it and could see the carbon that had been shot out of my exhaust...but be careful. it will stain whatever ground is behind you......i hope you like smoke to.....!!!! Link to comment Share on other sites More sharing options...
Guest Guest Posted April 8, 2005 Report Share Posted April 8, 2005 what is it and where do you get it? Link to comment Share on other sites More sharing options...
burchs1 Posted April 8, 2005 Report Share Posted April 8, 2005 Hi,Register and put your location in your profile so we can help you better. Seafoam makes several different products, then one being referred to here is a general purpose cleaner for the engine, carb, injectors, etc. Read about it here:Seafoam Product PageIn Minnesota and I'm sure in many other states you can find cans of this on the shelves at most auto parts stores, etc. It costs about $6 a can.what is it and where do you get it?← Link to comment Share on other sites More sharing options...
xcaliber912 Posted April 8, 2005 Report Share Posted April 8, 2005 i forgot to mention that the only way you will see smopke is to put it into the vacuum tree which will clean your engine the best....if you decide to put it in the crank case get an oil change within 300 miles and if you go with the gas tank put it in when you are at a gas station on empty and fill it up so it mixes better. i did all 3.....you can put the full can in your tank a 1/3 into your crank case and 2/3 can into the throttle body (vacuum lines).....read the back of the can for better directions. after you put it into the throttle body it suggests going for a drive. i was suggested by many people that this drive is sprited to help mix it better. and those drives are always fun Link to comment Share on other sites More sharing options...
T5BRICK Posted April 8, 2005 Report Share Posted April 8, 2005 i'm gonna have to give this stuff a try. B) Link to comment Share on other sites More sharing options...
Paul33603 Posted April 21, 2005 Report Share Posted April 21, 2005 Guys and gals,Yesterday on the way home from Sams club I stopped at Nappa Autoparts and picked up a bottle of SeaFoam. Well to tell you the truth I am VERY skeptial of any add to oil-gas-intake product. I decided I would try the Seafoam, the intake route by placing another vanumme hose on to the vacumme tree and sucking the product through letting it sit for a few minutes like I have read on here before. I had a cloud of smoke for about 4 blocks. I am EXTREMELY happy I did this and if you havent or are waiting to DO IT NOW! I HAD a LOUD Valve type of ticking sound when the car was cold, After warm up it would go away and come back occassionaly. My 94 855T has over 195,000 miles on it and I honestly thought it was time for a new engine. Well that is gone with this product! I am EXTREMELY happy I did this and if you havent or are waiting to DO IT NOW! I am just simply amazed that this product works well and thought everyone should know.Wow I am excited! Paul Link to comment Share on other sites More sharing options...
Mesoam Posted April 21, 2005 Report Share Posted April 21, 2005 i think the turbo guys have been having better luck w/ dramatic results...my car felt a bit smoother but that is about it...a point a bud brought up is that if you have ALOT of build up disconnecting the CAT is a good idea b/c it could clog it up quickly Link to comment Share on other sites More sharing options...
merlin390 Posted April 21, 2005 Report Share Posted April 21, 2005 thats a good point. Makes me kinda wish I had throught about unbolting it before I ran that can through :( Link to comment Share on other sites More sharing options...
745turbo Posted April 21, 2005 Report Share Posted April 21, 2005 any NW crew guys wanna do this before the meet? Link to comment Share on other sites More sharing options...
T5BRICK Posted April 21, 2005 Report Share Posted April 21, 2005 i'd like to try this. maybe smooth my idle out a little. Link to comment Share on other sites More sharing options...
MBT Posted April 21, 2005 Report Share Posted April 21, 2005 745turbo,I'm in.One problem: the CAT thing. How hard is it to disconnect it? and what is involved exactly?Not a big fan of clogged up tubes/pipes in my car. :) Link to comment Share on other sites More sharing options...
745turbo Posted April 21, 2005 Report Share Posted April 21, 2005 actually i dont know what seafoam does or is, i just hear about it all the time. whats the process. i have to have my down pipe made to match my new turbo and its turbine housing (hehe 3"?) but i guess thatd give me perfect chance. someone break it down for me......whats the procedure? Link to comment Share on other sites More sharing options...
