Mesoam Posted May 6, 2005 Report Share Posted May 6, 2005 Well, I had my tranny cooler sitting in my basement for a few months and finally got around to it today. I followed Charles's instructions and have some things to add.I chose to mount the TC behind the bumper, directly behind the license plate to keep it stock looking.I fabed up 2 quick and easy brackets. Simply some metal we had laying around, cut to length, drilled and a 90 bend put at the end.I used 2 self tapping screws to get into the metal which worked great especially since getting a drill in there is a TIGHT fit.To remove the old line on the trans I actually had to remove the air pump (in addition to the battery tray) to get a wrench in there and have enough room to get some decent torqueI might catch some flack for the way I secured the hoses to the cooler which where press on barb fittings with hose clamps but it works and I'm not worried about it so If you choose to mount the cooler in the location i have used you will have to trim the splash guard for line/fitting clearance. No big deal, its thin plastic so the Dremel made quick workAlso I found I had to notch a little corner out of the battery tray just to be "safe" for clearance.I think that's about it, comments? Questions?PICSCooler assemblyBracketsMounted, under shotFront shot pic, my car isn't that dirty, flash makes it look that way..I swear See it tucked behind there....If you are looking straight on it's no where to be seenEDIT: I allways like to know how much things COST! $40 for the cooler (bought from member on the board, sorry forgot who!) They are typically arround there any way$35 for the tranny lines (I bought both but you really only need the lower)$38 for the hoses to be built out of the 1 lower hose. That includes, hose, crimp fittings and labor (be sure to call arround it took me 4 times before finding a place that could even do it)$113 worth it? I think so....The number one cause for transmission failure is excess heat!Also noticed smoother shifts :blink: Link to comment Share on other sites More sharing options...
Nebor Posted May 6, 2005 Report Share Posted May 6, 2005 Very nice! Looks professional. Link to comment Share on other sites More sharing options...
theunderlord Posted May 6, 2005 Report Share Posted May 6, 2005 is that an FMIC? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted May 6, 2005 Report Share Posted May 6, 2005 Looks good. Quick question. Whats ID on thos barbs? They look small but it could be the picture. Link to comment Share on other sites More sharing options...
Nebor Posted May 6, 2005 Report Share Posted May 6, 2005 is that an FMIC?←Something gave me the idea that it was a transmission cooler... :D Link to comment Share on other sites More sharing options...
theunderlord Posted May 6, 2005 Report Share Posted May 6, 2005 Something gave me the idea that it was a transmission cooler... ←i was just preparing him for the question he's gonna have to answer over and over from morons. Link to comment Share on other sites More sharing options...
Nebor Posted May 6, 2005 Report Share Posted May 6, 2005 i was just preparing him for the question he's gonna have to answer over and over from morons.←Cue up the "How many pounds of boost could I run.... with a 12x1.5x10" intercooler?" threads. Link to comment Share on other sites More sharing options...
Zappo Posted May 6, 2005 Report Share Posted May 6, 2005 I am reading the Jegs catalog right now to order the cooler for this mod. Link to comment Share on other sites More sharing options...
PullMyFinger Posted May 6, 2005 Report Share Posted May 6, 2005 Hey, looks just like mine. Except I mounted mine behind the driver side opening. I have a matching cooler to go on the other side for engine oil. You need 3/8" hose barbs. Link to comment Share on other sites More sharing options...
Zappo Posted May 6, 2005 Report Share Posted May 6, 2005 Hey, looks just like mine. Except I mounted mine behind the driver side opening. I have a matching cooler to go on the other side for engine oil. You need 3/8" hose barbs.←Yeah, that is where I plan on mounting mine also. Link to comment Share on other sites More sharing options...
bobcat Posted May 6, 2005 Report Share Posted May 6, 2005 have mine in the same place works really well, gets nice and hot plus the tranny shifts better.still think it could be better so ive got another 2x 13 rows going in.car still holds 1.2 bar to redline. Link to comment Share on other sites More sharing options...
Mesoam Posted May 7, 2005 Author Report Share Posted May 7, 2005 Kev, I put it behind the license plate to "hopefully" avoid all of those q's but i'm sure i'll get it once and a while...Charles, not sure. I compared the barb ID's to the stock line openings (eyeball) and they where fairly close so I didn't think 2x...I would like to throw on a set of the swivel NPT fittings that take the hose directly but didn't feel like throwing $60 at 2 fittings. Link to comment Share on other sites More sharing options...
turbor850 Posted May 7, 2005 Report Share Posted May 7, 2005 looks nice travis ! Link to comment Share on other sites More sharing options...
George @ ViVA Posted May 7, 2005 Report Share Posted May 7, 2005 Looking good! Getting excited about the next NE meet? Link to comment Share on other sites More sharing options...
C70Jeo Posted May 7, 2005 Report Share Posted May 7, 2005 Mine has been sitting in my garage for 2 years. I have the bigger though. Back then I had the mentality that bigger was better Link to comment Share on other sites More sharing options...
