Boomin850 Posted June 11, 2005 Report Share Posted June 11, 2005 I remember asking this before, or mebe it was just reading about it, but whats a good kit I can buy to relocate my battery to the trunk? I know prolly ebay, but thought Id ask first. Also, for those that have done this...are there any problems that seem to occur? Anything at all? Thanks ahead of time.-MIKE D Link to comment Share on other sites More sharing options...
freeskier8585 Posted June 11, 2005 Report Share Posted June 11, 2005 there really isnt a kit persay, you have to wire it all yourself, and find your own battery case Link to comment Share on other sites More sharing options...
staggrlee Posted June 11, 2005 Report Share Posted June 11, 2005 I remember asking this before, or mebe it was just reading about it, but whats a good kit I can buy to relocate my battery to the trunk? I know prolly ebay, but thought Id ask first. Also, for those that have done this...are there any problems that seem to occur? Anything at all? Thanks ahead of time.-MIKE D←Ohm's Law:V=I*R ...or more appropriately:I=V/R If you don't use a heavy enough gauge the resistance of the + wire run can be sufficient to drop current enough so that your battery won't charge. Probably minimum of 2 gauge would be best. I talked to a guy who did this with an <'04 S40 (I think with 4 gauge) and got about 400 miles to a charge before having to hook it back up to a trickle charger. Before you go to the trouble of mounting it, hook the battery up with the length of cable you intend to use and measure both voltage and current at the battery both before and after. If it drops too much you might need to go with a higher output alternator.You'll obviously want to ground it in the trunk or under the seat too.You also need to make sure that the battery is vented to the outside of the car, the by-product of a charging battery is hydrogen and a build up of H concentration and a spark... :blink: Link to comment Share on other sites More sharing options...
freeskier8585 Posted June 11, 2005 Report Share Posted June 11, 2005 or use a sprial cell battery, and id go with 0 guage wire, thats what ive did and ive never had any problems Link to comment Share on other sites More sharing options...
lax01 Posted June 11, 2005 Report Share Posted June 11, 2005 with the amount of wire it requires...you really won't gain any weight savings by putting it in the trunk...it will actually make your car heavier...just get a lighter battery and turn it sideways if you need more room... Link to comment Share on other sites More sharing options...
Legbend Posted June 11, 2005 Report Share Posted June 11, 2005 could be doing it for weight distribution... but that'd be negligible too.just get smaller, lighter battery. Link to comment Share on other sites More sharing options...
freeskier8585 Posted June 12, 2005 Report Share Posted June 12, 2005 or he could be doing it for the room, i used maybe 5 pounds fo wire, the same, almost as mounting a sub, in fact if you have a sub you no longer have to run that wire, so you gain 0 pounds Link to comment Share on other sites More sharing options...
Meek Posted June 14, 2005 Report Share Posted June 14, 2005 What's the preferred aftermarket battery? Optima Red? Thanks. Link to comment Share on other sites More sharing options...
freeskier8585 Posted June 14, 2005 Report Share Posted June 14, 2005 yup Link to comment Share on other sites More sharing options...
Boomin850 Posted June 15, 2005 Author Report Share Posted June 15, 2005 Sorry for not replying soon...but ne ways I want to do it for both the room and because its just plain easier and cleaner to wire stereo ish that way. -MIKE D Link to comment Share on other sites More sharing options...
Boomin850 Posted December 29, 2005 Author Report Share Posted December 29, 2005 To bring up an old subject...Already have a kit and everything...wire is 2guage. Just want to see if anyone had any pictures of how they did it. Do I need to have a distribution block up front too? Jus wondering...I've never done this before and want to do it right the first time for once :lol: Link to comment Share on other sites More sharing options...
Zulu Posted December 30, 2005 Report Share Posted December 30, 2005 I've done it and yes there is a kit...I'll get you the name next week. I leave for Detroit tommorow morning.edit: nvm, didn't read the very last post lol. Link to comment Share on other sites More sharing options...
Sean Posted December 30, 2005 Report Share Posted December 30, 2005 How do Audis vent to the outside? All their batteries I've seen are under the back seat and I don't think I've seen any vents to the outside. Link to comment Share on other sites More sharing options...
T5INYAFACE Posted December 30, 2005 Report Share Posted December 30, 2005 I just got a battery relocator kit from sumit and it was $50. It came with everthing i need even the box to put it in. Link to comment Share on other sites More sharing options...
