Boomin850 Posted June 21, 2005 Report Share Posted June 21, 2005 Right Clicky and SaveThis is seriously the best thing that I have found after searching forever on how to sand the flutes inside glass lenses. I'm gonna follow these instructions and we'll see how well it works. Oh and it's pretty much exactly what Exexpat said to do but in greater detail.-MIKE D Link to comment Share on other sites More sharing options...
exexpat Posted June 21, 2005 Report Share Posted June 21, 2005 Good find, the Novus 1,2,3 was a good idea. I couldn't get clarity until I cleared mine, but then there is risk of long term discoloration. 3-4 days of work is depressing, though. The PMMA plastic lenses take baout 45 minutes or less each from start to finish and no discoloration, no dremel, no risk of cracks. You may want to drop the $60 for both shipped at Swedish Car Parts and go this route. :) Link to comment Share on other sites More sharing options...
Serge Posted July 15, 2005 Report Share Posted July 15, 2005 Nice! That seems like a bunch of work! Might go with the plastic ones... hehe. Link to comment Share on other sites More sharing options...
Boomin850 Posted July 15, 2005 Author Report Share Posted July 15, 2005 The way I look at is, yea its a lot of work, but it wont pit as easily and if you do a good job the clarity should be better....SHOULD...-MIKE D Link to comment Share on other sites More sharing options...
HPTDoh Posted July 15, 2005 Report Share Posted July 15, 2005 Me too.. pardon the n00b question, but why is there a need to delute the lenses? Is it because of scattering light? Link to comment Share on other sites More sharing options...
Boomin850 Posted July 15, 2005 Author Report Share Posted July 15, 2005 Exactly...the light reflects off of the fluting and right into oncoming traffic -MIKE D Link to comment Share on other sites More sharing options...
HPTDoh Posted July 15, 2005 Report Share Posted July 15, 2005 meh.. they didnt need their eyes anyway Link to comment Share on other sites More sharing options...
Serge Posted July 15, 2005 Report Share Posted July 15, 2005 Exactly...the light reflects off of the fluting and right into oncoming traffic -MIKE D←The fluting doesn't really cause glare. It does however screw up the cutoff which is the major plus factor of projectors. Link to comment Share on other sites More sharing options...
Boomin850 Posted July 15, 2005 Author Report Share Posted July 15, 2005 LOL I thought the glare was one of the biggest factors...oh well-MIKE D Link to comment Share on other sites More sharing options...
Zappo Posted July 15, 2005 Report Share Posted July 15, 2005 Exactly...the light reflects off of the fluting and right into oncoming traffic -MIKE D←It wouldn't raise the light any higher, it would just defuse it to the sides more. The cutoff wouldn't be as sharp, although it would still be better than stock because you are controling the light before it hits the lens instead of having the lens do all the work. Projected out onto the road, the difference is almost meaningless. The fluting might decrease the range a little, but not below what you should have the lights set to anyway.Dr.Pheta is running projectors with fluted lenses right now.Personally, if I had this mod, I would want people to see the projector in the light, just to know there is something different there. :) Link to comment Share on other sites More sharing options...
HPTDoh Posted July 15, 2005 Report Share Posted July 15, 2005 It wouldn't raise the light any higher, it would just defuse it to the sides more. The cutoff wouldn't be as sharp, although it would still be better than stock because you are controling the light before it hits the lens instead of having the lens do all the work. Projected out onto the road, the difference is almost meaningless. The fluting might decrease the range a little, but not below what you should have the lights set to anyway.Dr.Pheta is running projectors with fluted lenses right now.Personally, if I had this mod, I would want people to see the projector in the light, just to know there is something different there. ←I thought there was someone rockin fluted projectors. You will definately notice my lights are different, even if I do leave the fluting. Link to comment Share on other sites More sharing options...
drPheta Posted July 17, 2005 Report Share Posted July 17, 2005 Yeah, my setup is still running on fluted lenses (OEM Glass), and I definitely am not going to sit around for 4 days sanding lenses down. I'll probably grab plastic lenses from Swedish Car Parts and go that route.The output seems lower than Bimmers sitting next to my car (I'm running e46 Single Xenon projectors, thus the able comparison). Also, my cutoff isn't as money as it could be without the flutes, so I'm most definitely going to end up with a circle of no flutes in front of my projectors. Link to comment Share on other sites More sharing options...
HPTDoh Posted July 17, 2005 Report Share Posted July 17, 2005 It wouldn't raise the light any higher, it would just defuse it to the sides more. The cutoff wouldn't be as sharp, although it would still be better than stock because you are controling the light before it hits the lens instead of having the lens do all the work. Projected out onto the road, the difference is almost meaningless. The fluting might decrease the range a little, but not below what you should have the lights set to anyway.Dr.Pheta is running projectors with fluted lenses right now.←Wow, you called it.. the range w/ flutted glass is much shorter and directed to the sides more. Maybe its just the drastic contrast between that and my stock headlights w/ HID's, but I can't stand the beam like this. I'll be switching back to my original setup until I can get my hands on some plastic lenses. Link to comment Share on other sites More sharing options...
Boomin850 Posted July 22, 2005 Author Report Share Posted July 22, 2005 Wow, Im seriously thinking about giving up on this ish. There is just no stopping...I've been sanding for the past 2 hours on only one lense and, well, this just sucks balls.-MIKE D Link to comment Share on other sites More sharing options...
exexpat Posted July 22, 2005 Report Share Posted July 22, 2005 Wow, Im seriously thinking about giving up on this ish. There is just no stopping...I've been sanding for the past 2 hours on only one lense and, well, this just sucks balls.-MIKE D←I have 7 plastic lenses in my garage now, they take 1 hour each. Edit: was I right about 10 hours? Link to comment Share on other sites More sharing options...
