raymondjiii Posted July 30, 2005 Report Share Posted July 30, 2005 On the 98 V70AWD there is a huge piece of sub-frame (???) right under the fuel filter. I can't see how to get to the other side's fuel fitting and the pressure relief valve.The pictures here at Bay13 don't have this piece in the way.Thank you for any advice. Link to comment Share on other sites More sharing options...
Nuno_rules Posted July 30, 2005 Report Share Posted July 30, 2005 I have just down mine about a month ago.You have to work from inside the boot, unscrew the spare tyre cover (4 bolts). Size 10 or 12.Then take off the round cover that sits just above the fuel filter. Everything gets done from there.You will need a cloth or a rag , you would be surprised by the amount of petrol coming out.Release the valve (unscrew), it is like a tap.Loosen up the bracket that the fuel filter and remove the pipe at both end.Fitting is reverse.Easy job, but scary when the petrol drips. Obviously, no lighter, no light, no fire, nothing electric and no matches around.That is if you want to live... Link to comment Share on other sites More sharing options...
raymondjiii Posted July 31, 2005 Author Report Share Posted July 31, 2005 Thanks a million! I would never have looked there in a million years! That was SO much easier.Nobody had that one documented. Not Chiltons, Haynes, owner's manual, bay13.I actually got the bolt out and the end hose but the other hose was impossible to get (going through the bottom of the car.) I probably would've gotten it, in another 78 hours of struggling with it.So much easier from the two access holes!Thanks again! Link to comment Share on other sites More sharing options...
Guest willard Posted January 29, 2006 Report Share Posted January 29, 2006 This message is for numo_rules. I just read your message regarding the changing of the fuel filter on the 98 AWD. I can't thank you enough for the time you saved me changing the filter.Thanks!!!!!!!!!!!!!!!!!!!!Willard Link to comment Share on other sites More sharing options...
aldug Posted July 13, 2006 Report Share Posted July 13, 2006 Couldn't you pull the fuse for the fuel pump and run the car until the engine dies to get rid of all of the gas in the fuel lines? Link to comment Share on other sites More sharing options...
raymondjiii Posted July 24, 2006 Author Report Share Posted July 24, 2006 Couldn't you pull the fuse for the fuel pump and run the car until the engine dies to get rid of all of the gas in the fuel lines?That was not the issue - getting rid of the pressure. The issue was getting the other end of the fuel filter disconnected. Link to comment Share on other sites More sharing options...
