the underlørd Posted August 25, 2005 Report Share Posted August 25, 2005 First off, take out the ashtray and seat warmer buttons: Then pry out the plastic peice thats in the center console. You'll need a 8MM socket.then pull up and out on the console, making sure to disconnect the wires that are just underneath it. You'll also have to break the leather boot around the ebrake handle.. but don't worry, it looks fine when you put it all back together.Then, take a 12mm socket and unbolt the left side support on the center console. Trust me, it'll make your life much easier in about 2 steps.Next, undo the Clip seen here... DON'T LOSE IT.Next up, take a screwdriver, and pry on the console support, as seen here by my lovely assistant Jake. Pop the side linkage out, it should come out easy...Now, you can break that Ball Seat (the white thing) I hope you already bought a new one, cause it's Murder to get it out without breaking it. Cram a flathead screwdriver into the tabs, and smack it with a hammer... then pull the whole thing out. Next up... Take the rubber boot out, set it aside... Then this is where it gets fun.. Take the OE shift knob, put it in a vice, and go to town, be careful not to cut the lil trim peice! Now that you've got it all off, take the EST shifter, and take the ball off. Now you have to get the long rod to seat in the bottom linkage. This isn't easy. It took Jake and I about 5 minutes on his car, and about 30 minutes on my car. We finally took a bastard file and rounded the edges off of the bottom Rod ball. Success! Shoutout to the NWC!Now, you can put the console back on, and hook up all the wires.Put the rubber boot, and the leather boot on, and screw down your new shift knob, and your're done. Go test it out! Link to comment Share on other sites More sharing options...
S70 R Posted August 25, 2005 Report Share Posted August 25, 2005 sweet! kinda a bitch of a job but its well worth it i think! Link to comment Share on other sites More sharing options...
Mesoam Posted August 25, 2005 Report Share Posted August 25, 2005 first...teach kevin how to take better pics...second get that change out of there, third get a band-aid on that cut, fouth nice job! i'm just jelous of the t5m Link to comment Share on other sites More sharing options...
S70 R Posted August 25, 2005 Report Share Posted August 25, 2005 thats my hand, and that wasnt even a cut from that job, old cut from a while ago and my hands just look like hell all the time from work Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted August 25, 2005 Report Share Posted August 25, 2005 :) begins to fantasize. Looks great, thanks for the review Kevin and Jake. Link to comment Share on other sites More sharing options...
Mesoam Posted August 25, 2005 Report Share Posted August 25, 2005 thats my hand, and that wasnt even a cut from that job, old cut from a while ago and my hands just look like hell all the time from work←your new best freind....I didn't think I would like wearing them at first, then you don't know how you worked w/o them Link to comment Share on other sites More sharing options...
the underlørd Posted August 25, 2005 Author Report Share Posted August 25, 2005 i'll make sure someone with some skills fixed the pics.. Link to comment Share on other sites More sharing options...
Zappo Posted August 25, 2005 Report Share Posted August 25, 2005 i'll make sure someone with some skills fixed the pics..←Should have called me to take the pictures. :) Link to comment Share on other sites More sharing options...
maiku Posted August 25, 2005 Report Share Posted August 25, 2005 looks like fun to installi didn't have any money to do the short shift kit...guess i'll have to shift even faster now Link to comment Share on other sites More sharing options...
9mil Posted August 25, 2005 Report Share Posted August 25, 2005 Just did mine last night too- kinda a PIA - I actually did it without breaking the white retainer thing....right up until I took a hammer to it on the install- 70bucks will have to be spent, i guess. The action is WAY better than the stock, which would almost hit the ash tray in 1,3,5 and the e brake in 2,4,r - WAY better! Link to comment Share on other sites More sharing options...
gdizzle Posted August 25, 2005 Report Share Posted August 25, 2005 Nice Kevin, but you suck at taking pics. Oh, and Travis, I HATE working with gloves. Link to comment Share on other sites More sharing options...
josh_S70GLT Posted August 25, 2005 Report Share Posted August 25, 2005 great job, one commentbreak the leather boot around the ebrake handleYou don't need to seperate the plastic and leather, it will all slip off with a little bit of twisting Link to comment Share on other sites More sharing options...
fastboy Posted August 25, 2005 Report Share Posted August 25, 2005 Yeah that install sucks big time. I snap that clip right off the bat. stupid white clip...... good install though and taking out that side support makes it SO much easier...... work gloves suck Link to comment Share on other sites More sharing options...
jwmerrill Posted August 25, 2005 Report Share Posted August 25, 2005 I did this on my black C70. It was a major PITA. On my saffron C70 I simply cut about 1 1/4" (If I Recall Correctly) off the stock shifter and replaced the shift knob/boot. I can't tell much difference between the two! by the way. The VMS transplant is almost finshed in my black C70. I hope to have it by the weekend!jwm Link to comment Share on other sites More sharing options...
gdizzle Posted August 25, 2005 Report Share Posted August 25, 2005 I did this on my black C70. It was a major PITA. On my saffron C70 I simply cut about 1 1/4" (If I Recall Correctly) off the stock shifter and replaced the shift knob/boot. I can't tell much difference between the two! by the way. The VMS transplant is almost finshed in my black C70. I hope to have it by the weekend!jwm←Fantastic! Jim, I know I've asked you this before, but size MOMO boot did you use? Link to comment Share on other sites More sharing options...
