vstylz Posted August 30, 2005 Report Share Posted August 30, 2005 Im just wondering what some of you are running in terms of Rotors and pads..?What combos do you all think is better come time for replacement (time to upgrade as i see it)...what do you all think about Powerslot rotors with some stock pads? I dont know much about this so was hoping to get a few ideas!oh and its a negative on a big brake kit! unless someone wants to front me the cash... i'm good for it... just give me about 2 years :D Link to comment Share on other sites More sharing options...
the underlørd Posted August 30, 2005 Report Share Posted August 30, 2005 stock pads suck for dust..I had zimmerman xdrilled with OE pads on the silver car, they work great, just a lot of dust..now, i have stock rotors and i'm not 100% what pads.. (i forget) and they don't dust , but I don't use the breaks that much cause of the 5 speed. Link to comment Share on other sites More sharing options...
vstylz Posted August 30, 2005 Author Report Share Posted August 30, 2005 I dont think id get drilled rotors (not really convinced by it)... but id like to get slotted... anyone here use powerslot or know anything about them...? i think peads are great but yea they do dust a lot... FCP sells Zimmerman for around 42 bucks... they have the OEM for 72... thas a huge difference... Link to comment Share on other sites More sharing options...
the underlørd Posted August 30, 2005 Report Share Posted August 30, 2005 I dont think id get drilled rotors (not really convinced by it)... but id like to get slotted... anyone here use powerslot or know anything about them...? i think peads are great but yea they do dust a lot... ←if you're not convinced of xdrilled, take a look at nything big and made in germany ... x-drilled. Link to comment Share on other sites More sharing options...
vstylz Posted August 30, 2005 Author Report Share Posted August 30, 2005 if you're not convinced of xdrilled, take a look at nything big and made in germany ... x-drilled. ←yea... definitley see that...one problemo for you though...i can guarantee that the structural integrity of your rotors arent like thoseProblem is that these drilled rotors are literally DRILLED after they've been made and thats just asking for it...these higher end cars; the drills are INCORPORTATED in the creation procedure...and anyways... i dont think 11" dirrled discs give the intended presence on the road that many seek from it... slotted rotors actually have some use... Link to comment Share on other sites More sharing options...
the underlørd Posted August 30, 2005 Report Share Posted August 30, 2005 sounds like you already know everything, why you askin us? Link to comment Share on other sites More sharing options...
gdizzle Posted August 30, 2005 Report Share Posted August 30, 2005 yea... definitley see that...one problemo for you though...i can guarantee that the structural integrity of your rotors arent like thoseProblem is that these drilled rotors are literally DRILLED after they've been made and thats just asking for it...these higher end cars; the drills are INCORPORTATED in the creation procedure...and anyways... i dont think 11" dirrled discs give the intended presence on the road that many seek from it... slotted rotors actually have some use...←the only way you are going to crack a drilled rotor is track use, you will NEVER crack them with OEM pads on the street. Link to comment Share on other sites More sharing options...
vstylz Posted August 30, 2005 Author Report Share Posted August 30, 2005 sounds like you already know everything, why you askin us?←i know what to not spend my money on (personal opinion).i dont know what everyeone experienced here, and thats what im asking as well as some opinions on good replacement rotors and pads. Link to comment Share on other sites More sharing options...
SH8KDWN Posted August 30, 2005 Report Share Posted August 30, 2005 I'm looking into X-drilled myself. I haven't heard anyone complain of mechanical failure. Perhaps others will post. From the research I've done it appears that slotted work great at dissapating heat but cut through pads much faster than X-drilled. Link to comment Share on other sites More sharing options...
vstylz Posted August 30, 2005 Author Report Share Posted August 30, 2005 the only way you are going to crack a drilled rotor is track use, you will NEVER crack them with OEM pads on the street.←makes sense...so why really would one get 11" drilled discs then?i personally dont believe in form without functionality when it comes to "modding". Link to comment Share on other sites More sharing options...
gdizzle Posted August 30, 2005 Report Share Posted August 30, 2005 makes sense...so why really would one get 11" drilled discs then?i personally dont believe in form without functionality when it comes to "modding".←It dissapates the gasses faster and more efficiently than a oem rotor wich creates more pad on rotor contact in hard braking. It also helps in heat dissapation. A search can answer all these n00b ?s very quickly. Link to comment Share on other sites More sharing options...
550 Posted August 30, 2005 Report Share Posted August 30, 2005 If I get brembos that are x-drilled, Im not going to worry about them "cracking" or breaking. Link to comment Share on other sites More sharing options...
Guest DougK Posted August 30, 2005 Report Share Posted August 30, 2005 Personally,I've had solid, slotted, xdrilled and combo's. I honestly prefer solid or slotted. I xdrilled my S60R discs on the 242 and felt it like it honestly lost performance.best brake setup Link to comment Share on other sites More sharing options...
vstylz Posted August 30, 2005 Author Report Share Posted August 30, 2005 It dissapates the gasses faster and more efficiently than a oem rotor wich creates more pad on rotor contact in hard braking. It also helps in heat dissapation. A search can answer all these n00b ?s very quickly.←oh please dont even give me that nonsense... slotted rotors will do nothing for almost everyone here... its just a looks thing... a search will can corroborate you're a douche bag... Link to comment Share on other sites More sharing options...
550 Posted August 30, 2005 Report Share Posted August 30, 2005 Again if you know all of this already, why did you ask? Link to comment Share on other sites More sharing options...
