beachnut Posted November 4, 2005 Report Share Posted November 4, 2005 I've been working on replacing the evap on the 850, but I've hit a roadblock. I need to loosen the a/c lines at the firewall (I assume) ....theseBased upon the recommendation of a fellow VS member, I bought this a/c disconnect tool set , but I am obviously too obtuse to figure out how they work, and search as I may on the web, I cannot find any how-to's or descriptions. I need help please :rolleyes: Link to comment Share on other sites More sharing options...
beachnut Posted November 5, 2005 Author Report Share Posted November 5, 2005 Okay, I finally figured these beotches out and got the a/c lines off, but they were still quite hard to remove. Ultimately I had pull on the white climate box that houses the evap to get them to give a little from the couplings, then I used a large bladed flathead to leverage them the rest of the way out.So ... you think this evaporator is bad ??!!! Link to comment Share on other sites More sharing options...
prasamin Posted May 17, 2006 Report Share Posted May 17, 2006 Scott, remember the little plastic clips with the ears? well, are there any that need to be replaced when doing the evap? also, are there only 4 total o-rings in there for the evap lines?I bought the heater core oring kit from FCP, and I think the evap has some similar plastic clips, just don't know for sure!also, what tool was it that you tried to use to disconnect the lines? the link you had is broken! was it a spring coupling tool set? Link to comment Share on other sites More sharing options...
PR850TURBO Posted May 17, 2006 Report Share Posted May 17, 2006 I'm sure you guys are having a lot of fun with this.Did my one two months ago. You have to tear apart the whole dash!Disconnecting/re-connecting the lines is the most difficult step. Have the lines steady, pull, pulll and Be patient!I got the plastic clips from an A/C shop. Later someone told me you can use the standard one for GM/Ford A/C lines. You can get those in Pepboys for ~ $10.Here is a link that maybe helpful in the processhttp://www.volvospeed.com/Repair/ac.php Link to comment Share on other sites More sharing options...
beachnut Posted May 18, 2006 Author Report Share Posted May 18, 2006 Pras - here's a better link, second to last set. You can get these in any auto store I've found:http://www.mytoolstore.com/astro/asthan13.htmlRegarding those clips that are similar to the heater hose clips, they aren't necessary to replace. They are on there from the factory but i have no idea what purpose they served. I didn't use anything like that when I replaced my evap. The only thing they tell me is if they're on there then the evap has never been replaced! :lol: Link to comment Share on other sites More sharing options...
beachnut Posted May 18, 2006 Author Report Share Posted May 18, 2006 Oh yeah, there ARE only 4 o-rings at the firewall (2 per line). There are more at the other ends of the lines, but it depends on whether you'll be removing those. I replaced my accumulator/drier, so I needed a couple there too. Link to comment Share on other sites More sharing options...
Guest AlvinL Posted August 4, 2006 Report Share Posted August 4, 2006 From what I understand, the orifice tube is located in-line between the condensor and evaporator. It is replaceable as it can be bought from the dealer. How do I get to this device? Link to comment Share on other sites More sharing options...
prasamin Posted August 4, 2006 Report Share Posted August 4, 2006 From what I understand, the orifice tube is located in-line between the condensor and evaporator. It is replaceable as it can be bought from the dealer. How do I get to this device?good question.....i heard you had to just get the entire line, and that had the tube in it Link to comment Share on other sites More sharing options...
