DouginDenver Posted January 3, 2006 Report Share Posted January 3, 2006 My owner's manual says "ATF" as the fluid type for topping off the power steering fluid reservoir. It does not specify any particular kind, like it does for the transmission, it just says ATF. Do I use the same kind specified for the tranny? Also, I know the original owner had oil changes done at Grease Monkey. Do places like Grease Monkey use the proper fluids, or do they just put in regular power steering fluid? Are they compatible? Link to comment Share on other sites More sharing options...
DouginDenver Posted January 3, 2006 Author Report Share Posted January 3, 2006 My owner's manual says "ATF" as the fluid type for topping off the power steering fluid reservoir. It does not specify any particular kind, like it does for the transmission, it just says ATF. Do I use the same kind specified for the tranny? Also, I know the original owner had oil changes done at Grease Monkey. Do places like Grease Monkey use the proper fluids, or do they just put in regular power steering fluid? Are they compatible?OK, since posting this I did a search on the topic and found a discussion that says that no matter what the manual says, since '99 Vovlo has actually used a synthetic fluid. So the manual is wrong? How can I tell? Just take a sample out and if it ain't red it ain't ATF? What will the synthetic look like? Where do I get some? Link to comment Share on other sites More sharing options...
the underlørd Posted January 3, 2006 Report Share Posted January 3, 2006 i'd just use power steering fluid. Link to comment Share on other sites More sharing options...
rodrigo Posted January 3, 2006 Report Share Posted January 3, 2006 i'd just use power steering fluid....yes...even though the manual in your glove box says Auto Trans Fluid.I would try and find out what was used before and top it off with that. Link to comment Share on other sites More sharing options...
MrWinkey Posted January 4, 2006 Report Share Posted January 4, 2006 Volvo does recommend a special fluid however I use a compatiable steering fluid in my shop (GM fluid is fine) I wouldn't recommend ATF but you can use it ....opinions may vary though ;) Link to comment Share on other sites More sharing options...
