Cid499 Posted March 25, 2006 Report Share Posted March 25, 2006 Maybe the title is a bit deceiving.I am trying to get my headunit/cd changer to work in my house. So I took my CD changer and headaunit out, but couldn't remove the wire that connected the two (its under some carpet that I don't care to remove). The next best thing, I thought, would be to cut the wire at the two ends, and color match the wires inside the main sleeving. It turns out, the wires inside the sleeving aren't even the same colors/number ! Somewhere between the front and back of my car, the wire changes.Here's the pictures - which wires can I solder together to get sound and 'handshake' out of my changer?The above plug connects to the back of headunit.The above plug connects to the wire coming out of the CD changer.Thanks,Phil Link to comment Share on other sites More sharing options...
Owned Posted March 25, 2006 Report Share Posted March 25, 2006 Your pictures aren't working. Try www.imageshack.usOr anything else, as long as it's not photobucket. Link to comment Share on other sites More sharing options...
Cid499 Posted March 25, 2006 Author Report Share Posted March 25, 2006 I updated the original thread with links to the pics. hopefuly those work Link to comment Share on other sites More sharing options...
Owned Posted March 25, 2006 Report Share Posted March 25, 2006 I updated the original thread with links to the pics. hopefuly those workNope. I already tried the direct link from the properties menu before I posted. Keep trying! :D Link to comment Share on other sites More sharing options...
Cid499 Posted March 25, 2006 Author Report Share Posted March 25, 2006 OK ITS THERE NOW... imageshack linksEDIT: Nevermind everybody... I used a test light to figure out which pins go to what wire. Then, using the pinout diagrams, I put it back together.http://kiora.ath.cx/alpine/7513din.gifhttp://i7.photobucket.com/albums/y260/craz...angerPinout.jpgSwitchable AUX in, cost = $5.If you want to know the wire colors, let me know. Link to comment Share on other sites More sharing options...
