Guest AlvinL Posted April 20, 2006 Report Share Posted April 20, 2006 1993 to 1995 850's have the diagnostic connector beside the windshield washer fill. Click and read the Bay 13 link on how to read the 1993 to 1995 Diagnostic Connectors Check Engine codes and how to clear them. THE USE OF THE FOLLOWING INFORMATION IS ENTIRELY AT THE USERS RISK To retrieve the flash codes the following procedure can be adopted: Connect an LED, with the correct polarity, in series with a 1k8 ohm resistor, between pin 16 (+) and pin X, where X is the pin corresponding with the module to be read. Connect a push to make switch between pin X and pins 4 or 5 (-). The circuit can then be used in the same way as the pre '96 diagnostic sockets, situated in the engine compartment. For: Motronic 4.3 or Fenix 5.2, X = 3. ECC , X = 6, Timer Type 4, X = 9. Cruise Control, X = 13; 900 & S/V 90 ABS, X = 12 . What the codes mean: A1: Transmission 111 No faults found 112 Solenoid S1 short circuit to battery voltage 113 Transmission control module (TCM) fault 114 Program selector open circuit or short circuit to supply 121 Solenoid S1 short circuit to ground or control module fault 122 Solenoid S1 open circuit 123 Solenoid STH short circuit to battery voltage 124 Mode selector faulty or short circuit to ground 131 Solenoid STH open/short circuit or control module fault 132 Transmission control module(TCM) fault 134 Faulty load signal from ignition control module 141 Oil temperature sensor short circuit to ground 142 Oil temperature sensor open circuit 143 Kickdown switch faulty or short to ground 211 Transmission control module (TCM) fault 212 S2 solenoid short circuit to battery 213 Throttle position (TPS) signal too high 221 S2 solenoid short circuit to ground or control module fault 222 S2 solenoid open circuit 223 Throttle position (TPS) sensor signal too low 231 Throttle position (TPS) sensor sporadic 232 Speedometer signal missing 233 Incorrect speedometer signal 235 High Oil temperature 245 Open or short in Torque limiting circuit 311 RPM signal from transmission missing 312 RPM signal from transmission faulty 313 Faulty signal from gear position sensor (PNP) 321 Shift time too long 322 Incorrect gear ratio 323 Lock up slips or is not engaged 331 Short circuit to battery in SL circuit 332 SL solenoid open or control module fault 333 SL solenoid short or control module fault A2: Fuel System 111 No faults detected 112 Fault in ECM 113 Short term fuel mixture too weak 115 Injector 1 121 MAF sensor signal 123 ECT signal 125 Injector 2 131 RPM sensor signal missing 132 Battery voltage 135 Injector 3 143 Front knock sensor signal 145 Injector 4 153; 153 Rear HO2S signal 154 EGR system leakage 155 Injector 5 212 Front HO2S signal 214 RPM sensor signal sporadic 223 IAC valve opening signal 225 A/C pressure sensor signal 231 Long term fuel trim, part load 232 Long term fuel trim, idling 233 Long term idle air trim 241 EGR system flow malfunction 245 IAC valve closing signal 311 VSS signal 314 CMP sensor signal 315 EVAP system 325 Memory failure 335 Request for MIL lighting from TCM 411 TP sensor signal 413 EGR temp sensor signal 414 Boost pressure regulation 416 Boost pressure reduction from TCM 425 Rear HO2S sensor control faulty 432 Temperature warning level 1 433 Rear knock sensor signal 435; 435 Front HO2S slow response 436, 436 Rear HO2S compensation 443 Three way cat. Efficiency 444 Acceleration signal 451 Misfire cylinder 1 452 Misfire cylinder 2 453 Misfire cylinder 3 454 Misfire cylinder 4 455 Misfire cylinder 5 512 Short term fuel trim (integrator), lower limit 513 Temperature warning level 2 514 Engine cooling fan low speed signal 521 521 Front HO2S Preheating 522; 522 Rear HO2S Preheating 531 Power stage group A 532 Power stage group B 533 Power stage group C 534 Power stage group D 535 TC control valve signal 541 EVAP valve signal 542 Misfire more than one cylinder 543 Misfire at least one cylinder 544 Misfire more than one cylinder, three way cat damage 545 Misfire at least one cylinder, three way cat damage 551 Misfire cylinder 1, three way cat damage 552 Misfire cylinder 2, three way cat damage 553 Misfire cylinder 3, three way cat damage 554 Misfire cylinder 4, three way cat damage 555 Misfire cylinder 5, three way cat damage A3: ABS 111 No DTC set 121 Left front wheel sensor, faulty signal <40 km/h 122 Right front wheel sensor, faulty signal <40 km/h 123 Left rear wheel sensor, faulty signal <40 km/h 124 Right rear wheel sensor, faulty signal <40 km/h 125 Signal faulty from at least one wheel sensor for a long period 135 Control Module faulty 141 Faulty pedal sensor, shorted to ground or supply 142 Faulty brake pedal switch, open or short 143 Control module faulty 144 Brake discs overheated 151 Left front wheel sensor, open/short to battery 152 Right front wheel sensor, open/short to battery 155 Rear axle sensor open/short to battery 211 Left front wheel sensor, not signal on moving off 212 Right front wheel sensor, no signal on moving off 213 Left rear wheel sensor, no signal on moving off 214 Right rear wheel sensor, no signal on moving off 215 Valve relay, open/short 221 Left front wheel sensor, ABS operation signal missing 222 Right front wheel sensor, ABS operation signal missing 223 Left rear wheel sensor, ABS operation signal missing 224 Right rear wheel sensor, ABS operation signal missing 231 Left front wheel sensor, signal missing 232 Right front wheel sensor, signal missing 235 Rear axle sensor, signal missing 311 Left front wheel sensor, open/short 312 Right front wheel sensor. open/short 313 Left rear wheel sensor, open/short 314 Right rear wheel sensor, open/short 321 Left front wheel sensor, irregular >40 km/h 322 Right front wheel sensor, irregular >40 km/h 323 Left rear wheel sensor, irregular >40 km/h 324 Right rear wheel sensor, irregular >40 km/h 411 Left front wheel inlet valve, open/short 412 Left front wheel return valve, open/short 413 Right front wheel inlet valve, open/short 414 Right front wheel return valve, open/short 415 Rear valve open/short 421 Rear wheel inlet valve circuit, open/short 422 Rear wheel return valve circuit, open/short 423 Traction control system valve, open/short 424 Pressure switch for TRACS, faulty or short circuit 441 Control module faulty 442 Pump pressure low 443 Pump motor, electrical or mechanical fault 444 No power supply to valves in hydraulic unit A6: Ignition System (On some cars, this may not respond. See A2) 111 No DTC set 112 Control Module fault 123 Engine Coolant Temperature Sensor (ECT) from Control module missing or faulty 131 Engine speed (RPM) sensor signal missing 142 Control Module Fault 143 Knock sensor (KS) missing or faulty 144 Ignition control module load signal missing 154 EGR system flow too high in system 214 Engine speed (RPM) sensor signal missing sporadically 224 Engine Coolant Temperature sensor (ECT) signal missing or faulty 234 Throttle Position (TPS) signal missing at idle 241 EGR system flow too low in system 243 Throttle Position sensor (TPS) signal missing at idle 311 Vehicle speed signal missing or faulty 314 Camshaft Position sensor (CMP) signal missing or faulty 324 Camshaft Position sensor (CMP) signal missing sporadically 411 Throttle position sensor (TPS) signal from fuel injection system missing or faulty 413 EGR temperature sensor signal faulty 432 Control module box temperature too high level 1 433 Knock sensor (KS) signal missing or faulty 513 Control module box temperature too high, level 2 A7: Instrument Cluster 112 Fuel gauge short circuit 113 Fuel gauge open circuit 121 Temp. sensor interval too short 122 Temp. sensor interval too long 123 Digital output 48 pulse short circuit to supply 131 Digital output 12 pulse short circuit to supply 132 No RPM sensor signal 133 Tank signal to trip computer short to supply 221 Speed signal/signal absent B1: Electronic Climate Control 111 No fault 121 Outside temperature sensor shorted to ground 122 Outside temperature sensor open circuit or shorted to 12 volts 123 Driver's side interior temperature sensor shorted to ground 124 Driver's side interior temperature sensor open circuit or shorted to 12 volts 125 Passenger's side interior temperature sensor shorted to ground(earth) 126 Passenger's side interior temperature sensor open circuit or shorted to 12 volts 131 Driver's side air duct temperature sensor shorted to ground(earth) 132 Driver's side air duct temperature sensor open circuit or shorted to 12 volts 133 Passenger's side air duct temperature sensor shorted to ground(earth) 134 Passenger's side air duct temperature sensor open circuit or shorted to 12 volts 135 No signal from engine coolant temperature sensor 141 Faulty signal from driver's side temperature selector switch 143 Faulty signal from passenger's side temperature selector switch 145 Faulty signal from function selector switch 151 Signal from fan speed sensor missing or too high 152 Signal from fan speed sensor shorted to earth 211 Driver's side damper motor position sensor open circuit or shorted to 12 volts 212 Driver's side damper motor position sensor shorted to earth 221 Passenger's side damper motor position sensor open circuit or shorted to 12 volts 222 Passenger's side damper motor position sensor shorted to earth 231 Ventilation damper motor position sensor open circuit or shorted to 12 volts 232 Ventilation damper motor position sensor shorted to earth 233 Floor/defrost damper motor position sensor open circuit or shorted to 12 volts 234 Floor/defrost damper motor position sensor shorted to earth 235 Recirculation damper motor position sensor open circuit or shorted to 12 volts 236 Recirculation damper motor position sensor shorted to earth 311 Driver's side damper motor shorted to earth or shorted to 12 volts 312 Passenger's side damper motor shorted to earth or shorted to 12 volts 313 Ventilation damper motor shorted to earth or shorted to 12 volts 314 Floor/defrost damper motor shorted to earth or shorted to 12 volts 315 Recirculation damper motor shorted to earth or shorted to 12 volts 321 Driver's side damper motor active too long 322 Passenger's side damper motor active too long 323 Ventilation damper motor active too long 324 Floor/defrost damper motor active too long 325 Recirculation damper motor active too long 411 Blower fan seized or drawing excessive current 412 Driver's side interior temperature sensor inlet fan shorted to earth 413 No control voltage at driver's side interior temperature sensor inlet fan 414 Driver's side interior temperature sensor inlet fan seized 415 Passenger's side interior temperature sensor inlet fan shorted to earth 416 No control voltage at passenger's side interior temperature sensor inlet fan 417 Passenger's side interior temperature inlet fan seized 418 No control signal to blower fan power stage 419 Faulty diagnostic signal from blower fan power stage 420 ECU fault in program memory 511 Damper motor limit position self-adjustment not carried out B2: Cruise Control 111 No faults detected 112 Abnormal speed signal 122 Speed has not exceeded 22mph or no speed signal 211 Control module malfunction 212 Malfunction in the circuit to the vacuum pump or regulator B5: SRS 111 No fault detected 112 Sensor module fault 127 SRS lamp open/short circuit 211 Drivers airbag short circuit 212 Drivers airbag open circuit 213 Drivers airbag short circuit to ground 214 Drivers airbag short circuit to supply 221 Passenger airbag short circuit 222 Passenger airbag open circuit 223 Passenger airbag short circuit to ground 224 Passenger airbag short circuit to supply 231 Left belt tensioner short circuit 232 Left belt tensioner open circuit 233 Left belt tensioner short circuit to ground 234 Left belt tensioner short circuit to supply 241 Right belt tensioner short circuit 242 Right belt tensioner open circuit 243 Right belt tensioner short circuit to ground 244 Right belt tensioner short circuit to supply B6: Power Seat 112 Position sensor for motor. Signal missing or defective 114 Motor 4. Open circuit 121 Position sensor for motor 2. Signal missing or defective 123 Motor 1. Motor running, even though its button is not being pushed 131 Motor 2. Motor running, even though its button is not being pushed 132 Motor 3. Motor running, even though its button is not being pushed 133 Motor 4. Motor running, even though its button is not being pushed 143 Motor 1. The motor is turning in wrong direction 144 Motor 2. The motor is turning in wrong direction 211 Position sensor for motor 4. Signal missing or defective 214 Motor 3. The motor is turning in wrong direction 224 Motor 4. The motor is turning in wrong direction 321 Fault in stored memory position 3 322 Fault in stored memory position 2 323 Fault in stored memory position 1 331 Motor 1 break in lead 332 Motor 2 break in lead 333 Motor 3 break in lead 414 Limit position. Incorrect calibration 1-2-21-2-2 Position sensor for motor 3, signal absent or faulty Link to comment Share on other sites More sharing options...
