Johann Posted May 6, 2006 Report Share Posted May 6, 2006 Removed the AC condensor, plumbing and pump,For the pump a replacement pulley was needed, Link to comment Share on other sites More sharing options...
WhiteT5 Posted May 6, 2006 Report Share Posted May 6, 2006 It certainly looks better... should help w/ heat soak a tad. It must not get very hot there to be able to go w/o A/C. Link to comment Share on other sites More sharing options...
98BRICK Posted May 6, 2006 Report Share Posted May 6, 2006 How difficult was it to remove thecompressor?? did you hafto lower the subframe?Why not just find a smaller belt? Link to comment Share on other sites More sharing options...
gdizzle Posted May 6, 2006 Report Share Posted May 6, 2006 nice job Johann. do you have the part number for the volvo bracket/pulley? Link to comment Share on other sites More sharing options...
Johann Posted May 6, 2006 Author Report Share Posted May 6, 2006 nice job Johann. do you have the part number for the volvo bracket/pulley?Bracket = 1270598Pulley = 9458470Bolt for Pulley = 965186Cap for Bolt for Pulley = 9125572Also needed are 3 bolts to mount the bracket but the ones I received with it were to short, one pulled half the thread from the acc. plate mounting point.. -->'99 is M8 X 70, 2000 is M8 x 60 Link to comment Share on other sites More sharing options...
Mesoam Posted May 6, 2006 Report Share Posted May 6, 2006 I would melt w/o my AC...But anyway, def the way to go, also have to consider the weight savings... Link to comment Share on other sites More sharing options...
gdizzle Posted May 7, 2006 Report Share Posted May 7, 2006 I would melt w/o my AC...But anyway, def the way to go, also have to consider the weight savings...cause it's SOOOO hot in New England! :lol: Link to comment Share on other sites More sharing options...
98BRICK Posted May 8, 2006 Report Share Posted May 8, 2006 k...was it easy to remove the compressor? and why not just find a different belt than install that pulley? Link to comment Share on other sites More sharing options...
PullMyFinger Posted May 8, 2006 Report Share Posted May 8, 2006 ...and the question remains unanswered.Can you just use a shorter belt or do you *have* to run that idler pulley/bracket setup? Link to comment Share on other sites More sharing options...
98BRICK Posted May 9, 2006 Report Share Posted May 9, 2006 ...and the question remains unanswered.Can you just use a shorter belt or do you *have* to run that idler pulley/bracket setup?and...was the compressor easy to remove??? Link to comment Share on other sites More sharing options...
the underlørd Posted May 9, 2006 Report Share Posted May 9, 2006 c'mon Johann..... where ya at big guy? Link to comment Share on other sites More sharing options...
Johann Posted May 9, 2006 Author Report Share Posted May 9, 2006 I'm soo sorry.. First the AC fluid needs to be removed. Then a few hoses and pipes need to be removed from the pump, the condensor and the evaporator. Some are inbus bolts 6 mm, for other connections a special Volvo removal tool is needed. I needed to loosen the ECU box to take the 2 metal pipes out leading from the front to the firewall.A small puzzle but very doable.The pump is bolted on with 4 large bolts and after removing the belt it can be pulled from the engine.I couldn't find a small belt suitable to run far enough around the alternator pulley, with a small belt it will only touch 1/3 of the circumference so the alternator will slip when power is needed. Also I think the way the tensioner is situated it is a no go. The extra pulley makes the belt run more than 2/3 over the alternator pulley. I think the non AC belt is different from the one used with the AC pump, not sure. Link to comment Share on other sites More sharing options...
BlackBeast Posted May 9, 2006 Report Share Posted May 9, 2006 Would I have to change the Climate Control controls for a non A/C version?Also do you just block off the holes left in the evaporator? Link to comment Share on other sites More sharing options...
ViperVette Posted May 9, 2006 Report Share Posted May 9, 2006 Very cool man, I don't think I could handle not having the AC during those hot summer month of New Jersey, yea... July really gets ya. Def. a good mod for someone that dosen't mind just crackin' the window instead of AC. So, your not runing the pump... HP saved. Direct air to IC, horsepower gained. Lightened... sounds great man. Link to comment Share on other sites More sharing options...
98BRICK Posted May 10, 2006 Report Share Posted May 10, 2006 thanks....i already removed the condensor....i then got an underdrive pulley w/ the belt that bypasses the compressor...so i was looking to take that out, too... Link to comment Share on other sites More sharing options...
