Thors Hammer Posted December 6, 2006 Report Share Posted December 6, 2006 Hello fellow Volvo enthusiasts,I searched the forum for information and found various topics related to this theme.Most everyone complained about the high cost of replacing these sensors.My local Volvo dealer wanted 200 EUROs just for the sensor, hate to think what the price including installation would have been As 200 EUROs are approx. 250 US$ I searched around the web and discovered that:a) Bosch is the OEM manufacturer (many of you are aware of this I know.) I could get the Bosch part with connector for 136 EUROs delivered to my home.c) The Bosch part without the connector I could have delivered for 75 EUROs.Point c) made it clear that never mind what it would cost over the 200 EUROs to havethe dealer install it I could already save 125 EUROs simply on the part. So the decision was easy, I ordered the sensor for approx. 100 US$ delivered.Here's what I got, purchased from an English firm, (made in the USA!)Here are the contents (more than I expected, thought I'd be soldering and insulating wires:)The actual removal of the original parts was harder than anything else. This was partiallydue to the fact that the old sensor was pretty well baked in place and that the orig. connectorwas hard to get at and (without knowing how) difficult to get disconnected.Most of you have seen the sensor before:Up and to the left (from below the vehichle) is the connector:To disconnect the connector (as it is nearly impossible to reach or work from below) you will need to attack from above (I ended up lying accross the motor.) I removed the connector comming off the bottom left cornerof the brake fluid resevoir to make room for my arms. The connector is fitted to a tab.Slide it off so you can disconnect it easier. The connector is the nastiest I ever encounteredor the most secure if you will and hard to reach. You have to slide a red double pronged keyout sideways to release it, you can push the two male ends in first to get it moving in the right direction first:To remove the sensor you will need to get under the vehicle. As I don't have a lift, I jacked up andsupported the front of the vehicle with jack stands. A pit or lift would make this part easier as you willneed a 22mm wrench to get the old sensor out and they are often very stuborn.Use penetrating oil, WD40 etc. and let it work in. As I was laying on my back and could not get thesensor to break loose I used my foot ("putting some ALL GLORY TO THE HYPNOTOAD into it," if you will) as due to the small clearancethere was no chance to apply a cheater bar. Once you have broken the sensor loose, pull the cable free(a small plastic retainer holds him in place which will pop out and can be re-used,) feed it down to thesensor and screw the sensor out while turning the cable and connector in unison.My sensor after removal:Now, following the instructions in the kit, you simply cut the connector off with approx. 10cm of wire,strip the wires, match the complete length of the connector piece and the sensor piece with either the sameor to be safe a bit more say an inch or two. Cut the sensor wire to the measured length and strip it's wires.Now the neat connectors come in from the kit. The housing is slipped over the wires, then the insulators and thenone connector per wire. This procedure is repeated on the other opposing wires.So no soldering and complete insulation:Now we reinstall our assembly:Screw the new sensor in (I have torque values but went flush and an 1/8th of a turn as due to the wireI couldn't use standard sockets)Feed the cable up to the red-tab connector and reconnect it (secure the plastic wire retainer to the original plug hole)and secure the connector assembly on the metal tab (my connector lost the tab so I used a plastic tie:)Reset the Lambda/Check engine light:*********************** FINISHED ******************************************************Notes:This kit should be as cheap or cheaper than here being it's made in the USA if you're in North America.If you are in Europe or just want information (Bosch conversion data, connection info, diagnostic info etc.)I can highly reccomend this company although I am not affiliated with them in any way:http://www.lambdasensor.com/They shipped within 24 hours and answered my emails promptly. Link to comment Share on other sites More sharing options...
ViperVette Posted December 6, 2006 Report Share Posted December 6, 2006 Coolness. That seems like a pretty painless install. Nice job. Link to comment Share on other sites More sharing options...
AlvinL Posted December 6, 2006 Report Share Posted December 6, 2006 Thank you for that write up. :) Link to comment Share on other sites More sharing options...
Guest JJF Posted December 13, 2006 Report Share Posted December 13, 2006 Message for Thors Hammer.What headlights do you have on that 850?JJF Link to comment Share on other sites More sharing options...
SIAMBLUE Posted December 13, 2006 Report Share Posted December 13, 2006 On my car it is a air fuel sensor, i changed mine last week, Volvo wanted £146 + 17.5% vat, about $ 300 that same company you used i got mine delivered for £87 about $160 and was delivered the next day, and it was exactly the same Bosch part,Gary, Link to comment Share on other sites More sharing options...
Guest VIC Posted December 14, 2006 Report Share Posted December 14, 2006 Excellent info! Thanks! (merit a sticky, add to the repair section please)I checked the web page, but What's the part number for the sensor?Thanks,Vic Link to comment Share on other sites More sharing options...
MadeInJapan Posted December 15, 2006 Report Share Posted December 15, 2006 Yes, very cool...may have to do this in a month or two.Can you give us some info on your home made reset device? Link to comment Share on other sites More sharing options...
