BlackT5 Posted December 18, 2006 Report Share Posted December 18, 2006 I've been asked by a few people lately about what oil and coolant lines to use when installing a GT turbo.Fittings for a GT turbo on a T5 motor. I'm sure this will be the same on the 94-97 850 Turbo, T5, T5-R and R, 97 GLT, 98 S/V/C70 T5 and GLT. It's probably the same on the 99+ cars, but i don't know.The oil return *should* bolt up ..so you'll need oil feed and water lines. I went with the top notch shit, just because I wanted to do it once and not have to worry about any ghetto rig bullshit leaking on me. I bought the Aeroquip stuff locally and the turbo connections from atpturbo.comThis is what I did..1) GT install kit from ATP (ATP-GTK-001) $70 .... Although you probably won't need the oil drain and gasket... but it gives you the oil inlet restrictor and coolant banjos. I ordered the banjos with the 1/4" NPT.2) Oil feed to the block.. order an extra GT coolant banjo fitting with 1/4"NPT. It fits the block perfectly. (ATP-FTG-003) $223) From the banjo 1/4"NPT , you need an Aeroquip adaptor to connect to the feed line. So.. 1/4" NPT to 4AN fitting.4) Oil feed line.. I used a 4 ft 4AN line (ATP-OIL-015) $39 This will connect directly to the oil inlet restrictor from the GT install kit. That is the feed line done. Here's a pic of the feed line parts.Water lines: You get the coolant banjos in the install kit.5) Water feed connects to the water pipe just behind the water pump. I bought 18" of steel braided 8AN line. Cut to fit. I bought a 1/2" clamp and collar to fit the line, so it looks like a standard AN connector. You can just use a hose clamp if you want.6) Other end of the water line .. 8AN 90 deg fitting and an 8AN to 1/4"NPT adaptor to connect to the coolant banjo coming off the turbo.7) Water return: connects to the water pipe next to the heater core connection. I bought 12" of steel braided 10AN line. Cut to fit. I bought a 5/8" collar and clamp for the connection to the waterpipe.8) Other end of the water line.. This is a bit finicky, but use an 8AN 90 deg push fitting that will accept a 10AN line. Use another 5/8" clamp and collar or just a hose clamp. Then use another 8AN to 1/4" NPT fitting to connect to the coolant banjo.SO haha if you're not lost yet here is the entire list..from atpturbo..-GT install kit (ATP-GTK-001)-extra banjo for the oil feed (ATP-FTG-003)-4 ft of 4AN line for oil feed (ATP-OIL-015)from a local store..-18" of 8AN line-12" of 10AN line-2 X 1/4"NPT to 8AN fittings-1 X 1/4"NPT to 4AN fitting-1 X 8AN 90 deg push fitting (that will accept a 10AN line)-1 X 8AN 90 deg fitting-2 X 5/8" clamp & collar for 10AN line-1 X 1/2" clamp & collar for 8AN lineand more pics..GT install kit:Coolant lines and fittings:Clamps and collars:90 deg fittings and 8AN to 1/4"NPT fittings:Hope that helps :) Link to comment Share on other sites More sharing options...
thelostartof Posted December 18, 2006 Report Share Posted December 18, 2006 nice post .. this should help out more than a few peoplewhat is the total cost of everything tho? Link to comment Share on other sites More sharing options...
T5shortblock Posted December 18, 2006 Report Share Posted December 18, 2006 that's Grrrrrrrrrrrrreat! Link to comment Share on other sites More sharing options...
BlackT5 Posted December 18, 2006 Author Report Share Posted December 18, 2006 nice post .. this should help out more than a few peoplewhat is the total cost of everything tho?I think it works out to 200-250USD? I'll have to go home and look at my reciepts.Again, you can get the oil feed line for cheaper than atp, you probably don't need the oil drain that comes in the install kit, and i'm sure the prices of the Aeroquip stuff varies. Link to comment Share on other sites More sharing options...
Gioseppe Posted December 19, 2006 Report Share Posted December 19, 2006 get it on the motor already! Link to comment Share on other sites More sharing options...
BlackT5 Posted December 19, 2006 Author Report Share Posted December 19, 2006 get it on the motor already!Just waiting for gaskets. Fresh head gasket and all the seals for the cams etc.. Link to comment Share on other sites More sharing options...
prasamin Posted December 19, 2006 Report Share Posted December 19, 2006 nice writeup...someone needs to sell this entire kit separately or something. Link to comment Share on other sites More sharing options...
Gioseppe Posted December 19, 2006 Report Share Posted December 19, 2006 Just waiting for gaskets. Fresh head gasket and all the seals for the cams etc..you need one? i can get a whole set to you for cheap. Link to comment Share on other sites More sharing options...
BlackT5 Posted December 19, 2006 Author Report Share Posted December 19, 2006 you need one? i can get a whole set to you for cheap.Thanks, but it's already on it's way ;) Link to comment Share on other sites More sharing options...
GT2 Posted December 19, 2006 Report Share Posted December 19, 2006 Just wondering.I the second pic. the 1/4 x -4 fitting seems to have a small metering hole in it. Whats the purpose for that?Thanks Link to comment Share on other sites More sharing options...
BlackT5 Posted December 19, 2006 Author Report Share Posted December 19, 2006 Just wondering.I the second pic. the 1/4 x -4 fitting seems to have a small metering hole in it. Whats the purpose for that?ThanksAre you referring to this?If so, that's the oil inlet restrictor for the Garrett GT ball bearing turbos. Link to comment Share on other sites More sharing options...
GT2 Posted December 20, 2006 Report Share Posted December 20, 2006 Are you referring to this?If so, that's the oil inlet restrictor for the Garrett GT ball bearing turbos.Ahh.. so the ball bearings must not need high pressure? Link to comment Share on other sites More sharing options...
BlackT5 Posted December 20, 2006 Author Report Share Posted December 20, 2006 Ahh.. so the ball bearings must not need high pressure?Correct. Link to comment Share on other sites More sharing options...
turbor850 Posted December 20, 2006 Report Share Posted December 20, 2006 way to go GT like everyone else good luck with it Mark ! ! ! can't wait to see more pics ! Link to comment Share on other sites More sharing options...
Gioseppe Posted December 20, 2006 Report Share Posted December 20, 2006 way to go GT like everyone else how many people are on GT series turbos... i can only really think of two. Johann and Doug. Link to comment Share on other sites More sharing options...
