Volvospeed Forums
Rear Spring Replacement / Swap 850
Gage
Here is my write up on rear spring swap
Tool's Needed
1/2dr ratchet with a 18mm and 15mm socket
Pry Bar
Jack car up and place on stands pull rear wheel
Loosen the shock nut and lower spring mount nut
place jack under the the spring and lift up just enough to get the shock off the mounting stud
remove jack and get the pry bar and slowly lift from the bottom of the spring up
with the spring out pull the top rubber mount off and lower metal mount out
put the lower mount in the new spring and put the rubber mount on the top
lift the new spring in to place and make sure the spring is siting in the right spot
Place jack back under the arm and lift just enough to get the shock back on the stud and put the nut back on
remove the jack and put the lower spring mount nut back on
Put tire back on and your done
Please pin if worthy Thanks
Those are MY springs!
Dang power outages, winterstorms, etc...
:lol:
Nice write up! You wasted no time in getting those things in!
Are you doing the fronts yourself, too?
:lol:
:lol::lol:
Yes im waiting on my spring compressors to get back from my uncle
  • 2 weeks later...
  • 2 weeks later...
It isn't 19mm, it is 18mm.
your right ill fix it
How ironic!! I am planning on replacing mine within the next two weeks and was getting ready to do a search and I see this. I'll just print your write up.
Any difference in the ride or ride height??
yes there was but that is cuse they are eibach lowering springs
Tool's Needed
Pry Bar
Good post with photos and instructions. :rolleyes:
  • 3 months later...
  • Create New...
