ROB @ VMS Posted July 21, 2004 Report Share Posted July 21, 2004 As you may know the head is a major player in power. If it cannot flow x amount then the power is limited to flow. We at Vms have done detailed flow chart of my 01 T5 Head. This way we can see at what lift the max cfm can be reached. Here is the data Given.Intake Lift Cfm .100 86 .200 140 .300 180 .400 190Exhuast: .100 72 .200 136 .300 156 .400 160 .450 162______________________________Now You must have your your cams specs to see where max lift is. on the 99> i beleive our cams are differnt but max out around .350 so going to .400 as seen would not yield much in a power gain without doing port and valve work to the motor. Now we have After numbers we can see what lift we would be. So Basicly this could also be posted as a answer to " Would cams help My Car" . As seen no unless you open the head up and increase Cfm at a higher lift point.The stock volvo T5 are a very nice. These stock flow number are VERY good and there is room to improve on the head without hogging it out or removing excess material that would decrease the strength of the head. I hope this answers some of the cam questions as well. I will soon post after numbers as we have them avalible to us. Link to comment Share on other sites More sharing options...
Guest DougK Posted July 21, 2004 Report Share Posted July 21, 2004 Good to know Rob! Link to comment Share on other sites More sharing options...
Bay13 Posted July 21, 2004 Report Share Posted July 21, 2004 The turbos, 1999 and on are CVVT on the exhaust shaft, so the computer is responsable for the numbers that as you have posted are good as they get. Link to comment Share on other sites More sharing options...
ROB @ VMS Posted July 22, 2004 Author Report Share Posted July 22, 2004 Correct but from what i have read about the Bosch VVT is its mainly used to smooth starts and idle. I dont think it plays too much of a role in making power in the high rpm range. I have some Me7 data stuff and Torque Based system articals somewhere i can share. But now we have numbers to work with. Link to comment Share on other sites More sharing options...
Bay13 Posted July 22, 2004 Report Share Posted July 22, 2004 I was told that on the non turbos it was mainly an emissions thing, but on the turbos it was a power thing.I guess my point is that if you are going to change a mechanical part, that is controlled by a computer, it is a must to know what the computer is doing with your mechanical part. Link to comment Share on other sites More sharing options...
ROB @ VMS Posted July 22, 2004 Author Report Share Posted July 22, 2004 yes i agree Link to comment Share on other sites More sharing options...
Guest Guest Posted July 22, 2004 Report Share Posted July 22, 2004 Someone pin this or add this info to the FAQ! Link to comment Share on other sites More sharing options...
Boosted2003 Posted July 22, 2004 Report Share Posted July 22, 2004 darn. The b234f redblock head flows more then that. Link to comment Share on other sites More sharing options...
Guest DougK Posted July 22, 2004 Report Share Posted July 22, 2004 darn. The b234f redblock head flows more then that.←I dont think they do. Link to comment Share on other sites More sharing options...
ROB @ VMS Posted July 22, 2004 Author Report Share Posted July 22, 2004 I have never seen numbers on the B234F. Can u show numbers. Either way these numbers are very good for a stock head. Volvo seemed to put alot of work into the design. Link to comment Share on other sites More sharing options...
BlackT5 Posted July 22, 2004 Report Share Posted July 22, 2004 Too bad they didn't put more design into this Link to comment Share on other sites More sharing options...
turbor850 Posted July 22, 2004 Report Share Posted July 22, 2004 Hey Rob, I was about to post the numbers. . .just got them today Oh well, yeah, the numbers are very good, flow kinda like a small chevy block . . . (as Terry told me)can't wait til these are done :excl: Link to comment Share on other sites More sharing options...
ROB @ VMS Posted July 22, 2004 Author Report Share Posted July 22, 2004 They in fact flow more. Next thing is the new flow data. Should be avalible around monday or tues. Link to comment Share on other sites More sharing options...
Jamaica2G Posted July 22, 2004 Report Share Posted July 22, 2004 Too bad they didn't put more design into this ←hahahahaha ROFLOL Adrian Link to comment Share on other sites More sharing options...
volvo850r Posted July 22, 2004 Report Share Posted July 22, 2004 Volvo actually bought the motor from porsche in late 80"s so Porsche made a good design. They were going to use the motor with a tt setup in the 911's. Link to comment Share on other sites More sharing options...
