Volvospeed Forums
Diy: Make Fiberglass Eyelids
TFIVEM
First off as always... do this at your own risk.. however you arnt really doing anything that can harm the headlight so if you pull off breaking them... thats a bit more talent.
tools need:
Fiber glass mat
Bondo resin
scissors
sandpaper
masking tape
sharpie marker
mixing bowl
brush
PAM (cooking spray)
dremel
Ok you want to begin by completley cover your headlights in masking tape. you want every thing covered cause this stuff gets everywhere. i would also do this in a well ventalated area because it smells up quick.
cut up the fiber glass into small peices so they are easy to work with
take the sharpie and line out over the tape where you want the eyelid to be... its inportant to do this because it will help out later on.
spary down the headlight in pam so it will be easy to remove the fiber glass later on.
pour resin and proper amount of hardener into a glass dish. 1/4 can of resin gets 1/4 bottle of hardener
apply a coat of resin all over the light then press the fiber glass into the resin. once you have appliesd the fiberglass apply another coat of resin over the fiberglass
once that has dried go ahead and hit it with the sandpaer.
repeat the process again and let dry
peel it off and check out the back... sharpie peel :)
cut along the line with the dremel
Test fit
hit them with paint
fit again
enjoy
peg tease.. thanks corey
The one thing I will say is that most people here will try to paint the raw glass. You guys are going to want to sand it down quite a bit from it's raw form and lay down some mud on any low spots. You don't have to glaze coat these, but it wouldn't hurt. If you aren't great at mudding and sanding, you will likely have pin holes and small imperfections. As long as they aren't horrible, you can take care of them with a filler primer. If you still have issues, sand off the primer and use a glaze. It will be easier to work with than normal mud and will be more forgiving. Sand it and re-prime.
Another thing to look out for is if your mud dries and you reapply some from a new 'batch' (filler/hardener ratio), it will show through thin coats. If you end up splitting up your mudding, you will want to make sure you use enough paint to hide the splotches this will create.
Other than that, the process is really very simple.
Off topic, but are those the jewel headlights/aftermarket?
Or did you sand down the original?
How much would you say doing this costs?
You can get glass and resin at Walmart, Lowes, HD, etc. It's not very good, but good enough for this. 1 gal can of resin and a small bag of chop will set you back maybe $15, tops. Paint is the killer. You can get a color matched paint in a spray can with flex for ~$30 from a paint store. Just bring them in your fuel door or headlight trim. It will match better than buying from the dealer or paintscratch.com.
thanks for all the replys. overall it took about 2 hours. first time ive ever used fiberglass. your definetley right about the mud though. i really just wanted to get them wrapped up for today. but i def have plans. i spent about 20$ total for everything and that was because i bought about 8 x 8 foot sheet of fiberglass. the fogs below my headlights are golf cart foglights.... lol but they match the flutes of the original headlights perfectly. if you want em gary there yours. shoot me a price lol.
Send me the eyebrows.;)
Gary
  • Create New...
