Hellas850 T-5 Posted April 4, 2008 Report Share Posted April 4, 2008 Well I started my own project-adventure I would say,because to find and collect the right parts it will be like an adventure.So last weekend I made the engine into pieces,found some problems that justify my fear for the oil consumpion and the oil smokes.Later in the afternoon(Greek time)I'll post some(many) pictures.And I'll try to keep thread interesting. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted April 4, 2008 Report Share Posted April 4, 2008 Good luck!"Project adventures" are always fun Link to comment Share on other sites More sharing options...
UnknownSoldier Posted April 5, 2008 Report Share Posted April 5, 2008 Nice, good luck with the build, hey, isn't Greek time in the golo :lol: Link to comment Share on other sites More sharing options...
prasamin Posted April 5, 2008 Report Share Posted April 5, 2008 what kind of problems did you find? Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted April 5, 2008 Author Report Share Posted April 5, 2008 One last complete photoMy friend who helped me with the engine removalMe...Engine is off!The poor manifold...A photo of the cylinders all of them had lines from top to bottom.The unlucky 4th rod.Compression was going down.The crankcase.Mark on the crank from 4th rod.I cleaned up the block for the beginning.Another view of the cylinders before the machine shop,but I am thinking to buy a new block(1650 euros)The last to the right side is the 4th.Mark from the crankshaft.So guys these are what I could load for now,as I said I don't have free time(working hours 08.00-20.00) so it will be difficult. Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted April 5, 2008 Author Report Share Posted April 5, 2008 what kind of problems did you find?One bent rod 4th.The compression from the one side of the piston was going in the crankcase.And the third piston although that the rod was OK it had compression loss.All the rings were worn although they were changed 100.000km before,but it must be from the pistons that started the problem. Link to comment Share on other sites More sharing options...
prasamin Posted April 5, 2008 Report Share Posted April 5, 2008 were you doing regular oil changes, etc? Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted April 5, 2008 Author Report Share Posted April 5, 2008 I was changing oil and filter every 5000km.But I changed many brands,shell,motul,volvo.5w-40-15w-50-15w-40 synthetic and semi-synthetic.And lately because of the high oil consumption(1lt/800km)I used an oil additive-I don't remember the name it is from USA and had a big difference.Until first 2000km no oil burnt.But when I was raising the turbo pressure at around 1.5 bar,then nothing could stop the consumption,200gr every 150km.You can't imagine what oil smokes where coming out from the engine.I'll try to load a video here to see it.It was really bad thing when the car was shining ang the smoke was like diesel truck's exhaust and the smell like 2 stroke motorcycle. Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted April 5, 2008 Report Share Posted April 5, 2008 try not to be alarmed, but I believe your friend might have been under the influence of marijuana when this shot was taken. Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted April 5, 2008 Author Report Share Posted April 5, 2008 try not to be alarmed, but I believe your friend might have been under the influence of marijuana when this shot was taken. That is me.I was like this because my eyes are sensitive to the flash.So it was when I closed my eyes. Link to comment Share on other sites More sharing options...
UnknownSoldier Posted April 6, 2008 Report Share Posted April 6, 2008 try not to be alarmed, but I believe your friend might have been under the influence of marijuana when this shot was taken. haha FAIL Paul, maybe u were under the influence when u posted this Like me pal. :P Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted April 6, 2008 Author Report Share Posted April 6, 2008 Ok a question now,has anyone put on 143mm rods instead of 139,5mm and shorter pistons?I'm thinking to put them on but are there pistons available for this combo piston-rod?Thanks. Link to comment Share on other sites More sharing options...
Dmsee Posted April 6, 2008 Report Share Posted April 6, 2008 Good luck with the project, post that video if you can find it Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted April 6, 2008 Author Report Share Posted April 6, 2008 Good luck with the project, post that video if you can find itThank you very much,which video?This one with the oil smokes?I'll post it here,and some others in showroom. Link to comment Share on other sites More sharing options...
Dmsee Posted April 6, 2008 Report Share Posted April 6, 2008 Thank you very much,which video?This one with the oil smokes?I'll post it here,and some others in showroom.Yea, the oil smoke. That oil consumption is crazy :lol: Link to comment Share on other sites More sharing options...
