s60wot Posted April 25, 2008 Report Share Posted April 25, 2008 On board message "Emission system service required" Pulled the DTC "P1171" According to Vadis the code is "Fuel Adaption, Bank 1"Any thoughts? Link to comment Share on other sites More sharing options...
micosan Posted May 9, 2008 Report Share Posted May 9, 2008 On board message "Emission system service required" Pulled the DTC "P1171" According to Vadis the code is "Fuel Adaption, Bank 1"Any thoughts?Could you lookup and tell me what DTC P1054 means? I've got a thread asking for this info but no luck so far. Thanks Link to comment Share on other sites More sharing options...
volvos60t5x Posted May 9, 2008 Report Share Posted May 9, 2008 On board message "Emission system service required" Pulled the DTC "P1171" According to Vadis the code is "Fuel Adaption, Bank 1"Any thoughts?do a search, you will find a lot of info about code here. Can be exhaust leak, maf, hose, O2 sensors, etc. Link to comment Share on other sites More sharing options...
micosan Posted May 9, 2008 Report Share Posted May 9, 2008 do a search, you will find a lot of info about code here. Can be exhaust leak, maf, hose, O2 sensors, etc.Thanks for the suggestion but I’ve done that here and other Volvo sites with no luck. The problem I found is once you get codes in the 1000 (P1054) range they are manufacturer specific. I’ve found some codes in the P1XXX range but they’re not complete. I was hoping someone with VADIS access could tell me what the code meant. Thanks again. Link to comment Share on other sites More sharing options...
MrWinkey Posted May 10, 2008 Report Share Posted May 10, 2008 On board message "Emission system service required" Pulled the DTC "P1171" According to Vadis the code is "Fuel Adaption, Bank 1"Any thoughts?More than likely an intake/vacuum leak.Could you lookup and tell me what DTC P1054 means? I've got a thread asking for this info but no luck so far. Thanks1054 is a no speed sensor signal from the ABS system. There may be other codes stored in the ABS system. Link to comment Share on other sites More sharing options...
micosan Posted May 12, 2008 Report Share Posted May 12, 2008 1054 is a no speed sensor signal from the ABS system. There may be other codes stored in the ABS system.Thanks Mr. Winkey Link to comment Share on other sites More sharing options...
