Projector Headlights, One Of Many Threads
59 replies to this topic
#41 TaskMule
TaskMule
  • 1,151 posts
  • Interests:My car, my pets, my education.
Posted 24 July 2008 - 01:31 PM
QUOTE (OrEo931 @ Jul 23 2008, 10:28 PM) <{POST_SNAPBACK}>
These look great at night.
As you can see, I was messing with exposure times and camera settings.
HIDs are 35watt 6k SharpHID.
Wow. Outstanding cutoff.
98 V70R AWD
97 855R
#42 pwebb
pwebb
  • 707 posts
Posted 24 July 2008 - 04:52 PM
needs eyebrows
94 854 turbo - 160k - red on black
#43 matt b
    Earth day- Every day
  • 14,420 posts
Posted 24 July 2008 - 06:57 PM
QUOTE (ChambsT-5R @ Jul 23 2008, 08:54 PM) <{POST_SNAPBACK}>
Ehhh, undecided on that one, Adam...
Same here, not sure about these lights just yet.
MY97 855 Manual swap, Porsche Brakes, 16T on LPT block and plenty of IPD parts
#44 zrd5005
zrd5005
  • 140 posts
  • Crew:ECC
Posted 25 July 2008 - 07:11 PM
these the pics that you need?
Zach D.
Pennsylvania
1995 850 Turbo Sedan
#45 Oreo931
    Level 8 Senior Member
  • 23,651 posts
Posted 25 July 2008 - 07:20 PM
#46 zrd5005
zrd5005
  • 140 posts
  • Crew:ECC
Posted 25 July 2008 - 07:23 PM
thanks very much, can't wait to put them it, i guessing it would probably be a good idea to install the hids before putting the headlights into the car?
One thing i was wondering, can i hook up the angeleyes and those 2 little leds to a tiny 12v battery to test which wires are for what or will that burn out the bulbs?
Zach D.
Pennsylvania
#47 Aequitas_Veritas
Aequitas_Veritas
    Blue Calipers&Balls
  • 7,690 posts
Posted 25 July 2008 - 07:26 PM
QUOTE (zrd5005 @ Jul 25 2008, 12:23 PM) <{POST_SNAPBACK}>
yes that would work, or you can even just touch them to your battery and see which ones light up, dosnt matter the 12v source. I just touched them to my normal car battery, and they worked fine.
40+ mods and counting...
#48 Oreo931
  • 23,651 posts
Posted 25 July 2008 - 07:28 PM
Kay. Here is what you need to do:
All the places with red are going to need trimming.
The red mark on the lower left of the socket needs to be flush with the side. If you look at the original picture you will see how it kind of curves out to the right. Shave that down so it is flat. Just on the lower left half, no need to do it on the upper left half. Obviously I cant show depth with my "diagram" but you need to shave it all the way down (down as in towards the glass of the headlight lense).
The middle red line area, you will need to trim a little bit. Just make a small, lenth wise vertical valley looking thing. Doesnt have to be deep, just makes some extra room for the return wire (is it called that?) on the bulb.
For the two red marks on the right...As you can see, they have edges to them. They come to a point. They make a 90 degree angle. Get what I am saying? Shave those down a little bit so they are rounded off and not pointy. Make sure you do this the entire length of the socket, as I mentioned to do on the mark on the lower left hand side.
Let me know if you have any questions.
#49 zrd5005
zrd5005
  • 140 posts
  • Crew:ECC
Posted 25 July 2008 - 07:35 PM
how should i go about doing this, do i tak eth eentire socket out or just do it while its in the headlight, and what do i do to protect the projector lense from the metal/plastic? fileings
Zach D.
Pennsylvania
#50 Oreo931
  • 23,651 posts
Posted 25 July 2008 - 07:51 PM
QUOTE (zrd5005 @ Jul 25 2008, 03:35 PM) <{POST_SNAPBACK}>
Do it while it is in the headlight.
Tilt the headlight downwards so the shavings fall out...Stick a rag behind the area you are working...blow them out with leaf blower...put some grease on the dremel bit to catch the filings...I can think of more if you want laugh.gif
#51 turbomoose
turbomoose
  • 2,063 posts
Posted 25 July 2008 - 07:55 PM
Dude! A leaf blower?!
Why not use an air compressor with a air gun tip attachment?!
And if you put grease on a dremel tip, it will just fly off with centrifugal force.
Nathan '97 850 T5 172K SOLD! '03 SAAB 9⁵ 3.0t '09 SAAB 9⁵ Griffin
#52 Oreo931
  • 23,651 posts
Posted 25 July 2008 - 07:59 PM
QUOTE (TurboMoose @ Jul 25 2008, 03:55 PM) <{POST_SNAPBACK}>
1. because I am a newb and dont have an air compressor
2. people use the grease method all the time to catch shavings. I am not saying glob it on like you are lubing up for some buttsecks, but put some on there to catch the shavings. it works.
#53 zrd5005
zrd5005
  • 140 posts
  • Crew:ECC
Posted 25 July 2008 - 08:04 PM
kk well if i use the grinding bit and some dust particles from the socket get into where the lense is my air compressor should get them out just fine?
Zach D.
Pennsylvania
#54 turbomoose
turbomoose
  • 2,063 posts
Posted 25 July 2008 - 08:07 PM
Maybe on the headlight housing itself, but not the bit.
And I don't know about grease on a headlight housing either.
As it gets hot, any residue from the grease that isn't wiped up completely, or gets flung too far into the housing and not being able to get wiped, may over time create a film inside the glass of the headlight, like new car windshields get foggy with the shit the plastics release when they're new.
I think compressed air, a shop vac, or shaking out the filings would be the best route.
#55 Account_Deleted_T5M
Account_Deleted_T5M
    I Was Pwned
  • 5,827 posts
Posted 25 July 2008 - 08:32 PM
Looks good adam
Sorry to all the people who are still trying to get their money back.
#56 FINN
FINN
    Pretty Boy Racing
  • 7,064 posts
Posted 25 July 2008 - 09:42 PM
Damn! Thats sexy as hell. Good work Cpt.
#57 Oreo931
  • 23,651 posts
Posted 25 July 2008 - 11:16 PM
Couple daytime shots after I washed the car.
Yes, the hood looks funny in one of the pictures. I need to lower that hood latch a TINY bit so it sits even.
#58 TaskMule
TaskMule
  • 1,151 posts
Posted 26 July 2008 - 03:15 AM
QUOTE (NGB @ Jul 24 2008, 08:27 AM) <{POST_SNAPBACK}>
Also for all you reflector HID folks...this is a truly excellent example of why HIDs in reflector housings (like our stock lights) is not the best idea.
Yeah, maybe.
I think you might need to get a view from a couple 'o hundred feet away to really get a good idea of what it's like for an oncoming motorist.
But, I have my suspicions that you are right.
Meanwhile, wow...that looks fantastic.
98 V70R AWD
97 855R
#59 Plan_B
Plan_B
    Off-Topic Slut
  • 22,635 posts
Posted 26 July 2008 - 03:18 AM
Meh, I liked the jewels better whoreo, good job on the insall.
GAYTARD
#60 Plan_B
Plan_B
    Off-Topic Slut
  • 22,635 posts
Posted 26 July 2008 - 03:24 AM
GAYTARD
