Steering Feel
12 replies to this topic
#1 hi. my name is AJ
hi. my name is AJ
  • 99 posts
  • Crew:SCC
Posted 31 July 2008 - 05:45 PM
Okay, so i got the Koni FSD + Eibach setup installed yesterday in my S70 T5m, and it rides wayy better!
but the feel of the steering wheel still seems a bit sloppy. it feels like there is still alot of slack in the steering wheel. Is there any way to improve this???
#2 Oreo931
    Level 8 Senior Member
  • 23,659 posts
Posted 31 July 2008 - 05:48 PM
Did you get an alignment after you had the new suspension installed?
#3 hi. my name is AJ
hi. my name is AJ
  • 99 posts
  • Crew:SCC
Posted 31 July 2008 - 05:52 PM
QUOTE (OrEo931 @ Jul 31 2008, 10:48 AM) <{POST_SNAPBACK}>
no, but it felt like this before the new suspension got installed. but then again i think the car needed an alignment pre-konis anyway.
#4 Oreo931
  • 23,659 posts
QUOTE (hi. my name is AJ @ Jul 31 2008, 01:52 PM) <{POST_SNAPBACK}>
When you get new struts, you get an alignment.
#5 Boost_Junky
Boost_Junky
  • 2,022 posts
  • Interests:shiny objects and things that make noise
Posted 31 July 2008 - 05:57 PM
Check your ball joints, tie rod ends and bearings. They could all have play and effect your steering. With car off the ground, grab the wheel at 12 and 6 then shake it. Try this at 9 and 3 too. If there is movement inspect the component that is giving and replace.
95' 850 T5,Eibach Koni FSD,Strut Bar,Adj. Endlinks,ST@17psi,FMIC,
3" DP,2.5" Cust. Cat Back Sys,EST Intake,8k HID,Silcone Everything
04' S2K, Coil Overs, HKS Exhaust, Injen Inkake, Cust. 3 Piece Wheels
98' V70 bone stock
#6 hi. my name is AJ
hi. my name is AJ
  • 99 posts
  • Crew:SCC
Posted 31 July 2008 - 05:59 PM
thanks guys, your help is very much appreciated!
#7 rynodyno312
rynodyno312
  • 595 posts
Posted 31 July 2008 - 06:19 PM
a set of heavy-duty adjustable endlinks should help a little. My car felt a bit sharper after I installed Tom's endlinks.
2000 S70 T5A Nautic Blue
#8 7 VII 7
7 VII 7
  • 22,522 posts
Posted 31 July 2008 - 06:38 PM
just get your car aligned then go from there... it needs to be done anyways since you replaced the struts
1 of 1 - '97 427 854R - 110k
#9 MrTopher
MrTopher
  • 776 posts
  • Crew:ECC
Posted 31 July 2008 - 06:39 PM
depending on what type of driving you do (highway vs. windy roads) dialing in some negative camber with that alignment will sharpen up your steering response. -1º or so should do it
http://www.chrisamosphotography.com
'95 850. Manual. NA. 208k. Direzza Z1. Eibach. Bilstein HD. Hawk HPS. H&R 15mm. IPD Mounts.FOR SALE - $3750 See Thread/PM me
#10 hi. my name is AJ
hi. my name is AJ
  • 99 posts
  • Crew:SCC
Posted 31 July 2008 - 07:21 PM
awesome guys, one of the reasons why i <3 volvospeed: fast replies!
#11 7 VII 7
7 VII 7
  • 22,522 posts
Posted 31 July 2008 - 07:22 PM
QUOTE (hi. my name is AJ @ Jul 31 2008, 03:21 PM) <{POST_SNAPBACK}>
and you need to shut up
another reason to like VS.. unnecessary cursing and treating people bad!!!! laugh.gif
#12 Jesus
Jesus
  • 4,698 posts
Posted 31 July 2008 - 07:29 PM
QUOTE (MrTopher @ Jul 31 2008, 02:39 PM) <{POST_SNAPBACK}>
Front and back wheels?
#13 hi. my name is AJ
hi. my name is AJ
  • 99 posts
  • Crew:SCC
Posted 31 July 2008 - 11:07 PM
QUOTE (7 VII 7 @ Jul 31 2008, 12:22 PM) <{POST_SNAPBACK}>
