Warning!
17 replies to this topic
#1 Guest_Guest_98c70turbo_*_*
Posted 06 October 2004 - 07:34 PM
Well sad.gif , as some of you know I just bought a eclipse cd8454 to be installed in my 98 c70, but I just found out today as I had one of the installers look at the car's stereo wiring. Guess what? People with the dolby surround system will not be able to get an aftermarket radio installed!!! mad.gif Dued to the wiring. Only option that was said, was to rewire the entire stereo with two aftermarket amps. If anyone esle knowns anything or something on putting an aftermarket headunit with the dolby let me know!!!
Thanks,
Shaun
#2 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 07 October 2004 - 04:06 AM
you don't have to bypass the factory amp...you can just use harnesses...crutchfield.com will have them....try it out...they also sell install kits.
never mind...just searched for your car, but doesnt list it...you can email them however, they pretty much know everything about audio....try it out
Edited by prasamin, 07 October 2004 - 04:13 AM.
#3 Guest_Guest_98c70turbo_*_*
Posted 08 October 2004 - 04:07 AM
#4 VS Legend
VS Legend
  • 6,824 posts
Posted 08 October 2004 - 04:29 AM
Make your own harness.
Get wiring diagrams for the harness thingy on your aftermarket unit and the one for the volvo, plug in the harness for your aftermarket unit and manually splice the wires where they should be spliced to.
(I'm no audio genious, please wait for someone to confirm this is a good idea before trying it.)
2007 Volvo XC70 Daily Driver Steel Cargo Barrier (+50HP), Cargo Cover (+30HP), Bluetooth (+5HP), iPod Dock (To Be Installed, +15HP)
1995 Volvo 850 T-5R Currently in Storage RWD Conversion, 8-Speed Automatic Conversion, Quadruple Turbo w/ Supercharger and NOx
#5 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 08 October 2004 - 04:57 AM
not a good idea....the dolby interface may not let him do that....those factory amps probably won't do anything with splicing and a remote connection if there is no harness available...rewiring and bypassing the amps may be the best and only option....shouldn't cost you more than $100 to do the entire thing, and it will sound good, esp with an eclipse hu.
good luck....if you have Al and Eds where you are, they are reasonable, and pretty good....if you're looking for a deal, go to a smaller independent stereo shop that seems decent, and they may give you a "cash deal", and you should stay there and watch and make sure they do it properly!
-Pras-
#6 V Tuning 850
V Tuning 850
    BIG TIME TOOL
  • PipPipPipPip
  • 3,624 posts
Posted 08 October 2004 - 11:17 AM
Bing we need your help on this one.
#7 volvo850r
volvo850r
  • 150 posts
Posted 08 October 2004 - 05:43 PM
You will not need to rewire the car, all you need to do is locate the factory amp and use the standart plugs that will work with after market harness.
blew up m56h for now
#8 Bing_0
Bing_0
    Sure, I can install that there!
  • 2,155 posts
Posted 09 October 2004 - 02:43 AM
i am not that famaliar with the dolby system on the newer volvos, but i will say this, if its like other full blow premium stock systems such as the mustang's mach 460, it is MUCH easier and reasonable to redo the whole system. infact, when a mach460 system rolls into the sjhop, we tell them staright up he either dont get anything, or change everything...just putting in a headunit would require a HUGE amount of wiring and testing
not all amplified stock systems can utilize an adapter wiring harness, some of the more simple ones where its basically a in dash amp powring some speakres, you can do it, but on other ones, where say, there are amps located in each speaker or next to each speaker, or say the speaker are a specific impedance or interfaces with the amps in a certain way to produce a certain sound...these types of stock system are for all practical pruposes, impossible to just plug in and play...
b
#9 Guest_Guest_98c70turbo_*_*
Posted 09 October 2004 - 03:42 AM
So your pretty much saying I should just be better off redoing the entire system instead of just at the amp? My local stereo shop said to rewire the entire system and then use two amps for the speakers and two 8" subs, sound good or what? Also does anyone have a radio diagram for a 98 c70? Thanks for the response guys!!! smile.gif
#10 Bing_0
Bing_0
  • 2,155 posts
Posted 09 October 2004 - 01:36 PM
well, what your shop essentially doing is redoing the entire system hehe, they are using amps to power the speakers and subs, i assume the reason why they are leavint the stock spekares is because you have the dynaudio system? smile.gif
but, as loing as the imedpance of your speakres are okay, your plan is all good smile.gif
as for wiring diagrams, hit up bay13admin and see if he can provide you with one
b
#11 98BRICK
98BRICK
    The Sarge
  • 1,238 posts
Posted 10 October 2004 - 04:31 PM
Long story short....I put an sc901, dolby, center speaker, and 4x100 amp in car...finally after a year...I ended up buying a used wiring harness made by "Prospero" on Swedespeed. His wiring harness allowed him to use the stock c70, 4x100, amp and a piggy back amp to run his dolby system with a remote cut off switch. I only used part of his waring system. Heres a pic of his system:
Prospero's system in a v70
I had a 6 pin connector made, and used the part of his harness to connect the amp to the stock speaker harness....the center speaker still plugs directly into the back of the sc901 and werks...
so, if your interested in part of the wiring harness...the 6 pin din that allows u to piggy back of the stock hu (ull prolly need another wiring harness to attach, like the one anthony made) or ur gonna chuck ur center speaker, dolby, and dash...lettme kno....ive got a gray dash and wiring harness to sell...and i may be interested in ur center speaker and dolby for back-ups...
98 S70GLT (Silver)
98 V70XC (White)
98 V70R (Saffron)
#12 98c70turbo
98c70turbo
  • 228 posts
Posted 12 October 2004 - 02:53 AM
hey,
I'm not selling my dolby headunit or any of the dolby speakers. Just trying to get the new eclipse headunit installed with the dolby system.
1998 Corel Red C70 Hpt (Shaun) SOLD
NOW 2002 Harley F150 Supercharged 5.4
IPD Mesh Grill///Eibach///Koni Sport///18sMasItaly///Nitto555s
IPB Image
#13 c70keeb
c70keeb
  • 290 posts
Posted 12 October 2004 - 03:14 AM
Doesn't eclipse sell a dolby processor...i was going to go this route but with an alpine iva-d300 but cars get broken in to every night in my apt. complex. The guy that was gonna install my system said he could try tapping in to the stock amp but it was going to be alot of testing. I made a cash offer and he agreed but then i no showed. I talked to a lot of different shops and only two places thought they could do it. So I don't know try around and let me know what happens b/c i'm very curious if it can be done.
my cardomain page....check the pics
'98 C70 Hpt. 3" turbo back exhaust, ipd ecu, updated lights...sold
'05 S60R Black Saphire, Nordkap, 6 speed, FMIC, IPD ecu stage 2, 3" DP, 3" exhaust, HID fogs
#14 98BRICK
98BRICK
    The Sarge
  • 1,238 posts
Posted 12 October 2004 - 04:33 AM
QUOTE(98c70turbo @ Oct 11 2004, 08:53 PM)
hey,
sorry...just tryin to help...in my limited experience i dont think u can keep the center speaker unless the HU is capable....ull prolly need to keep ur HU if u want the dolby or find one that has dolby and try to adapt it....theres quite alot of discussion about this kinda stuff on swedespeed...albeit mostly on newer cars...good luck
98 S70GLT (Silver)
98 V70XC (White)
98 V70R (Saffron)
#15 98c70turbo
98c70turbo
  • 228 posts
Posted 15 October 2004 - 02:40 AM
Anyone know where the stock amp is located in a 98 c70? Is it behind the glove box or in the the trunk? sad.gif
IPB Image
#16 98BRICK
98BRICK
    The Sarge
  • 1,238 posts
Posted 15 October 2004 - 03:49 AM
QUOTE(98c70turbo @ Oct 14 2004, 08:40 PM)
c70...shood be in he trunk...mounted vertically next to the driver's side taillamp/fender
id u have a cd changer...itll be behind it
Edited by Brett Ferguson, 15 October 2004 - 03:50 AM.
98 S70GLT (Silver)
98 V70XC (White)
98 V70R (Saffron)
#17 98c70turbo
98c70turbo
  • 228 posts
Posted 16 October 2004 - 01:12 PM
Hey,
thanks for the help!
Shaun
QUOTE(Brett Ferguson @ Oct 15 2004, 03:49 AM)
IPB Image
#18 98BRICK
98BRICK
    The Sarge
  • 1,238 posts
Posted 16 October 2004 - 05:11 PM
u bet!
98 S70GLT (Silver)
98 V70XC (White)
98 V70R (Saffron)
