Alright fellas. Here is the deal. I am currently pulling the following codes. Need help solving the problem. As a background I have been having a dialogue with Rich in the Maintenance forum.
P0335 - Crankshaft Pos Sensor A Ckt Malf
P0300 - Random/Multiple Misfire Detected
P0301 - Cylinder 1 Misfire Detected
P0302 - Cylinder 2 Misfire Detected
P0305 - Cylinder 5 Misfire Detected
P0455 - Evap Emission Control Gross Leak
I am not concerned with the Evap Emission Control code for right now. I have been trying to figure that one out for quite some time.
My ignition system. I am running an Accel Electronic Super Coil with Magnecor spark plug wires and OEM Bosch spark plugs. I am running the stock plugs because I have read they are the best for the turbo cars. I am running the other upgraded components because they needed to be replaced at the time and I figured why not upgrade.
One of my buddies was talking with someone at IPD and they said I may need more gap on the plugs to run the Accel coil. Could this be my problem? If it is an ignition problem, from what you posted Rich, it seems it could set off my Crankshaft sensor code. Please correct me if I am wrong.
If the problem could be fixed with more spark plug gap can you recommend what I should gap them to? Finally, could some upgraded plugs fix the problem?
I know at least one person on here is running the same coil. Any suggestions. The other night I installed new Autolite copper plugs gapped at 35. Still misfiring. Please help.
Misfiring With Accel Electronic Super Coil
Started by larryo108, Oct 10 2004 04:54 PM
9 replies to this topic
Posted 10 October 2004 - 04:54 PM
Larry Overn
2003 Honda Civic Si
Talmo, Georgia
2003 Honda Civic Si
Talmo, Georgia
Posted 10 October 2004 - 05:02 PM
larry...i think sasso is running the same coil (eastern areospace version)...u may wanna try him, aswell...
Im not using any upgraded coil, yet....but i do run magnecor 8.5's and denso iridium ik20's (got a good deal on em), for about a year or so...with no problems....dont know if that helps
98 S70GLT (Silver)
98 V70XC (White)
98 V70R (Saffron)
98 V70XC (White)
98 V70R (Saffron)
Posted 10 October 2004 - 07:00 PM
Did you try insalling the old one to see if the misfiring continued? Maybe yours was dammaged some how?
Posted 10 October 2004 - 07:45 PM
I thought about that. unfortunately I had to bastardize the old ignition bracket to get the Accel coil on there. I was thinking about calling a buddy up and swapping coils to see if that fixes the problem.
Larry Overn
2003 Honda Civic Si
Talmo, Georgia
2003 Honda Civic Si
Talmo, Georgia
#5 Guest_Guest_*
Posted 10 October 2004 - 09:30 PM
Put your gaps back to stock settings and I bet your misfring will go away, if not then it could be the coil is bad. Good luck.
Posted 10 October 2004 - 09:46 PM
Had OEM Bosch plugs at stock gap before the AutoLites. Problem was there. That is why I tried a larger gap. Didn't fix it. Seem to think it is a bad coil maybe. I'll need to get together with someone who has a stock coil and switch it out and try it. Chris you out there? Please e-mail me or call me. Thanks.
Larry Overn
2003 Honda Civic Si
Talmo, Georgia
2003 Honda Civic Si
Talmo, Georgia
Posted 10 October 2004 - 10:38 PM
I have had no misfire problems so far (Exept when I had my #5 wire pinched by the cover) I am running stock volvo plugs and used the stock coil wire end that I put onto the Accel coil wire
Right before it blew up at Laguna Seca last November 30th
Black 97 854R, Sport Grill, Urethane Top Bushing, Momo Strut brace, Koni shocks, K&N air filter, B&M Tranny cooler, Upsolute ECU, Accel super coil, Magnacore plug wires, Custom Swedish I/C, Reverse I/C piping W/Samco hoses, HKS SSQV BOV, Polished Throttle body, Custom 3" S.S. down pipe, Magnaflow 3" Catalytic, Apexi 3" Muffler, IPD Sport Springs, IPD Sway Bars, QuickBrick Motorsports end links, Brembo Lotus calipers & 320x28mm X-drilled front rotors with Brembo Galpher pads, Brembo X-drilled rear rotors with EST Carbon Fiber pads, Stainless Steel brake lines, 215x45 17" Toyo Proxes 4 on Volans, 235/40 17" Toyo RA1 on Team Dynamics Pro-Race 1.2 17"x8" (for track), IPD Skid plate, Greddy TT, Custom 3 guage pod, AEM WB o2, Auto Meter Z-series Boost, EGT, Oil press, Water temp., Tranny temp. gauges, Mobil 1 w10/30, Royal Purple ATF, Horns moved for air flow, de-badged,
Posted 10 October 2004 - 10:55 PM
Play with your gaps, start real low (025 or less even) and gradually go up, it should fix the problem.
Good idea to check the coil too though
Posted 24 October 2004 - 09:38 PM
Alright fellas. Sorry for the delay in the update. I have been busy. It was the coil. I had Chris_R come over (thanks for your help man) and we put his stock coil in with the original Magnecor ignition lead. No misfiring. Car ran great. That isolated the problem to either the coil or the custom Magnecor ignition lead. Fortunately Chris had the same exact coil laying around. We installed it with the custom Magnecor lead and went for the same ride. No misfiring. It was the coil. I dug out my stock coil and have it bolted up and running fine. Before we started the test I reinstalled the OEM Bosch plugs at a 28 gap. Everything is back to normal. I may just replace with a stock coil or maybe a Nology profire. I am trying to keep the stock airbox, so I need something small enough to fit in there. I don't think that the MSD will. The Accel required some trimming. I am thinking about the Nology. Any ideas on that.
Larry Overn
2003 Honda Civic Si
Talmo, Georgia
2003 Honda Civic Si
Talmo, Georgia
Posted 25 October 2004 - 03:17 PM
the MSD will fit with EST's bracket
