Ground Wire Kits?
Started by Adam Franke, Oct 13 2004 11:42 PM
13 replies to this topic
Posted 13 October 2004 - 11:48 PM
lol if you're that desperate I'll make you one.........
Joseph H. Essaye III
Posted 14 October 2004 - 01:21 AM
Well, it's that I'm at school and away form my car, so I'd prefer to order one and have it shipped and waiting for me whenever it is I get home rather than having to waste time gathering and assembling materials when I do get home. I'm usually only home for 3-4 days tops. The next time I'm home I'll I only have about 5 hours to work on it total and I have other things I want to get done.
Posted 14 October 2004 - 01:39 AM
http://www.caraudiomag.com/testreports/0401cae_hyper/
They talk about ground wires there, used an 850R for the demo and you cna buy the kit from that company.
-Andy
-Andy
1998 V70XC
1994 850T
1994 850 NA 5spd
1994 850T
1994 850 NA 5spd
Posted 14 October 2004 - 02:44 AM
Ok ill save you time and tell you that I spent $200 on a entire ground box and it practically did nothing.
Posted 14 October 2004 - 03:47 AM
Im actually more on topic than ever. A ground box, in theory, is better than new ground wires. Therefore if a ground box didnt do anything, than obviously ground wires wont do anything.
Posted 14 October 2004 - 07:03 AM
ground box? no idea what that is and i wouldnt spend 200 bucks for it , but if your car has a bad ground, grounding wires will work. all volvo 850' or v70's arent the same on this issue. dude seriously just get some monster cable and have the ends crimped youll save enough to where it wont matter if it doesnt work. if it does give you 15 horsies...youll be giving less than about 1$ per horsie so yey. my car mustve been badly grounded do to battery cable corrosion. I used some baking soda and a wire brush to clean everything and stop the corrosion so I thought I was fine. Then my friend bought a hyperground kit and said he noticed a difference in many running systems on his vw R32, so recently i went and got some cheap wires, grounded the same 5 points he did, and I did notice a difference immediately. I mightve had the same gains by replacing the battery cables, but I didnt really know my ground was that bad without the ground wires. I will eventually replace the battery cables and then take the wires off and do a double blind comparo with a friend to settle it once and for all, if only for myself.
Hailing from Long Beach, CA
'96 850 turbo with the usual full list of mods
My wheels weigh 5.8kg
Posted 14 October 2004 - 11:30 AM
If nothing else just do it yourself it won't cost that much. I've been meaning to but I haven't had time to go out to get the wires. I'm going to solder all mine together, the same way I bled down on the 4ga amp wiring I put in. I've been holding out because I haven't found blue or clear wire I wanted to use...
-Andy
-Andy
1998 V70XC
1994 850T
1994 850 NA 5spd
1994 850T
1994 850 NA 5spd
Posted 14 October 2004 - 01:32 PM
http://redlinepower.com/html/hks_circle_earth.html
buy the universal kit
its called HKS Circle Earth grounding wires or something
you can probably find it cheaper somewhere else
/end of discussion
/end of discussion
Edited by turbor850, 14 October 2004 - 01:34 PM.
FIRST TO PUT 20G ON AN 850R
Posted 14 October 2004 - 06:40 PM
you can pick up those ground boxes for like 60 (or mabe it was 80?) on ebay. If you just add the box and all ground connections are in check then, fine. However if your wires look shabby and have a layer of crap on them, then replacement can def be an aid. I personally thought the stock ones coming off the head look cheap and crappy as all hell. Plus all of the stock ones coming off the - bat terminal are only crimped (not sealed) which can easily lead to poor connections.
#14
Posted 14 October 2004 - 07:30 PM
i bought 10ft, could have used another foot or 2
