Quick Question About Ecu/exhuast?
8 replies to this topic
#1 ThaBigO
ThaBigO
  • 543 posts
Posted 17 October 2004 - 06:27 AM
After you install an exhuast in your car are u suppose to take out the ECU and put it back in?? So it knows that something has been changed?? If not then for what mods are you suppose to do that with?? Let me know.
Thanks,
BigO
1995 850 Turbo Wagon (855)
My Mods
My Car!!!
#2 jross
jross
    Mad Scientist
  • 3,729 posts
Posted 17 October 2004 - 08:29 AM
You can, but it won't do much. You really only have to take out the ECU when you're upgrading the programming, as far as I know.
#3 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 17 October 2004 - 06:30 PM
i think you may just need to give it some time to settle in, but you don't need to remove it...maybe Oliver can do a remap, although if you have the 17PSI program, you probably don't need a remap
#4 VAVolvo
VAVolvo
  • 667 posts
Posted 17 October 2004 - 07:18 PM
QUOTE(prasamin @ Oct 17 2004, 02:30 PM)
... but you don't need to remove it...maybe Oliver can do a remap...
Cool! How can I get in touch with Oliver and will he remap a NA ECU?
Boosting B5254 854 GT
12sec '89 740 Turbo Wagon
#5 NateB
NateB
  • 481 posts
Posted 17 October 2004 - 07:40 PM
I believe your question pertains to clearing the ECU so that is can more quickly adapt to the freer flowing exhaust.
You can achieve this by :
1) Removing the ecu for about 10-15 minutes
2) Or simply pulling the fues to the ECU for 10-15 minutes ( easier)
The idea is the ECU adapt itself over time to the characteristics of your engine and exhaust. The ECU will adapt to your new exhaust over time all by itself. Removing the ECU ( or pulling the fuse) is intended to expedite the process.
Does it work ? Dunno, but it does not cost anything and only takes 15 minutes to do. It is recommended by most whenever a performance modification is performed ( i.e. new cat back; down pipe; air filter; etc.)
YMMV
NateB
1995 Volvo 850 T-5 Sedan
Houston, Tx.
Original Owner- 102,500 miles
Upsolute ECU (Adrenaline Racing)
Custom 2.5" Cat Back w/Magnaflow
SAMCO Turbo Hose Kit
Hosetechniques Silicone Vacuum Lines
Koni Sport Adjustable Struts /Bilstein HD Rear Shocks
Pretty Good Backyard Mechanic - Thanks To Rich and this Forum!
#6 ThaBigO
ThaBigO
  • 543 posts
Posted 17 October 2004 - 10:16 PM
Well how do i pull the Fuses to the ECU which are they??
My Mods
My Car!!!
#7 Guest_Guest_*
Guest_Guest_*
Posted 17 October 2004 - 10:39 PM
QUOTE(ThaBigO @ Oct 17 2004, 10:16 PM)
If you do not know how to pull the fuse ( actually fusible link) then you probably should leave well enough alone.
Your owner's manual will tell you which fuse to pull ( it's #1 I think).
#8 ThaBigO
ThaBigO
  • 543 posts
Posted 18 October 2004 - 12:51 AM
I got my Ecu chip in May of this year, so i think i dont have the 17 psi version.
My Mods
My Car!!!
#9 Karlson
Karlson
    Vodka Lover
  • 7,142 posts
Posted 18 October 2004 - 01:01 AM
I heard somewhere that Oliver now got 17psi version, i have 15psi right now, and pretty happy with that.
1996 850R... gone, but not forgotten
