T Fitting For Boost Vac/gauge
Started by Klingen, Oct 17 2004 03:32 PM
9 replies to this topic
Posted 17 October 2004 - 03:32 PM
Where can i find the T fitting to install the boost/vac gauge i jus got....is it a rarer part that ii need to order from ipd or somthing or can i pick it up at a relatively good automotive place....or can i get it at a small local place?
1998 S70 GLT 5-Speed manual
1st car...BIG plans
In
-Autometer Boost/Vac Gauge
Plans-
New trubo/IC/ECU/17" Enkies/Exhaust/Boost Controller/Maybe water injection
1st car...BIG plans
In
Plans-
Posted 17 October 2004 - 03:52 PM
QUOTE(Klingen @ Oct 17 2004, 09:32 AM)
Go to any home depot type place and pick up the right size compression fitting. Should be about 3 dollars. I would not T the oem line though. Run another one from the manifold.
Volvospeed On Google+
Posted 17 October 2004 - 04:50 PM
QUOTE(Klingen @ Oct 17 2004, 07:32 AM)
Why don't you attach it directly to the vacuum T?
1998 S70 T5M
Posted 17 October 2004 - 06:28 PM
you mean the gauge didn't come with a T fitting?....what??
Home Depot has them, Autozone has them, Pep Boys has them
Or you can use the existing vacuum tree under the TB cover if you have an extra opening there
Posted 17 October 2004 - 08:09 PM
ummm yeah i got spots on the vac tree but how should i connect it?
1st car...BIG plans
In
Plans-
1st car...BIG plans
In
Plans-
Posted 17 October 2004 - 10:50 PM
QUOTE(Klingen @ Oct 17 2004, 02:09 PM)
Uhh..... slide your vac tubing into a 4mm 1" section of soft line and then the other end of the soft line onto the vac tree.
Posted 18 October 2004 - 12:32 AM
n were could i find this soft line....its the same stuff thats on the other tube connected right....sorry if i keep asking stupid questions....Im only 16 n I know all about engines jus havent figured out all the vacuum/bost stuff yet...though i know how a turbo and super charger works....just not much hands on yet
1st car...BIG plans
In
Plans-
1st car...BIG plans
In
Plans-
Posted 18 October 2004 - 01:08 AM
This shows one way to do it
No matter how you do it zip-tie all your hoses and connections exept compression fittings of course.
Posted 18 October 2004 - 03:24 AM
whats wrong with using the stock boost gauge line? Dosent it go right to the vaccum tree?
Posted 18 October 2004 - 03:45 AM
I would use the stock boost gauge line if I didn't have to do all the dash stuff to get to it...I'd rather just go off the tree and run it through the firewall! but that's just me!!
