One Last Clarify Question On Catch Cans...
8 replies to this topic
#1 lax01
lax01
  • PipPipPipPip
  • 4,781 posts
Posted 18 October 2004 - 03:36 PM
I know this has been discussed many times on VS, but I was wondering if anybody could give me a little bit more detail on the process of installing it. First off, I'm installing it because I'm noticing a lot of blow-back in the I/C pipes and I'd like to get rid of that. So I bought this one:
after many of the guys from VS recommended it. After looking at the "Modification section"of VS, I'm still confused. As I recently replaced my intake hose, I'm pretty familar with the crankcase ventalation system but just need further clarifcation of how to hook up the catch can.
What I assume you do is, take the plastic tube (I think they refer to this as the 10mm pipe, which runs from the front of the intake manifold and is incased in some type of heat foam) and mate that with a 6 mm fuel safe hose which then connects to the left-side of the catch can. Then, on the right side of the catch can, a 6mm fuel safe hose runs from the catch can back to the top of the CCV (where the original 10 mm plastic tube hooked up to). Correct? This setup means, I'm polluting slightly (and losing a small amount of metered air) but am removing a lot, if not all of the oil from the crankcase ventalation vapors? Correct? Also, are there any better ways of doing this?
Thanks.
2002 BMW M3
Past: 1995 Volvo 850 Turbo
#2 swdracr
swdracr
    Pretty Boy Racing
  • 1,225 posts
Posted 18 October 2004 - 03:56 PM
I think you have the right idea. You're basically just putting the catch can inline between the PCV box and the PCV valve to remove some of the oil vapor before it enters the intake. (I guess you already know that, but I'm just trying to simplify what you said to make sure we're thinking the same thing.)
Patrick
'97 850 RIPB Image
IPB Image
#3 lax01
lax01
  • PipPipPipPip
  • 4,781 posts
Posted 18 October 2004 - 03:59 PM
yup, thats exactly it....so I think my only lingering question is, since the plastic tube coming from the intake manifold is 10 mm (right?), how do I step that down to 6mm to fit the 3/8" inlet on the catch can and then how do I then reconnect it back to the PCV valve on the intake hose...can I get these things at Advanced Auto Parts?
2002 BMW M3
#4 theunderlord
theunderlord
  • PipPipPipPipPipPip
  • 14,738 posts
Posted 18 October 2004 - 04:11 PM
QUOTE(lax01 @ Oct 18 2004, 08:59 AM)
Any hardware store should do... you're looking for barbed hose fittings. Bring your parts and show a guy who works there what you gotta build... should be no prob... post some pics when yer done, this has been on my wish list to do...
EDIT: where'd you score your catch can?
Edited by '98S70R, 18 October 2004 - 04:12 PM.
#5 lax01
lax01
  • PipPipPipPip
  • 4,781 posts
Posted 18 October 2004 - 04:16 PM
Jegs...came out to be $60...not too bad considering I'm noticing a lot more blow-back and would like to pro-long the life of the turbo...
where can I get fuel safe hose? Most car stores right?
2002 BMW M3
#6 Adam Franke
Adam Franke
    Supporting Member 4 Lyfe
  • 2,299 posts
Posted 18 October 2004 - 04:17 PM
Besides removing the oil vapors, what does a catch can do for you? Does it add horsepower in some way? Also, would this be beneficial on a non turbo car in any way?
#7 theunderlord
theunderlord
  • 14,738 posts
Posted 18 October 2004 - 04:18 PM
QUOTE(lax01 @ Oct 18 2004, 09:16 AM)
Cool, thanks. Yeah... the hose shouldn't be a big deal, I'd call ahead and ask tho... We all had catch cans on our Cummins Diesels... It's a good idea.
#8 patrick
patrick
  • 2,656 posts
Posted 18 October 2004 - 06:56 PM
scope, i made my own, main benefit also is you are not spoiling cold intake air w/ superhot crank vapors, however mine is different and ents to the atmosphere, since in SC we dont have any emissions laws. if you do it lik tht i noticed significantly less heat soak however you can smell he oil vapor if sitting in traffic for a long time.
Current: 2001 Grand Cherokee Limited V8 4x4 2.5in lift and some other goodies
Past:
94 850 160k sold
84 242ti 202k sold
99 F150 4x4 99k sold
#9 lax01
lax01
  • PipPipPipPip
  • 4,781 posts
Posted 18 October 2004 - 07:37 PM
just curious Patrick, but where did you mount yours? being N/A, where is your PCV anyways?
2002 BMW M3
