850 Glt Questions
5 replies to this topic
#1 BlueVolvo850GLT
BlueVolvo850GLT
  • 1 posts
Posted 19 October 2004 - 09:31 PM
Ok, I have a 1997 850GLT. It's all stock as far as performance is concerned. I'd like to put a bigger turbo in because supposedly the GLT turbo is pretty weak. I'd also like the turbo to bolt right on if possible so that I don't need to mess with anything else. Also, will I need an ECU upgrade or can I still benefit from a bigger turbo with the stock ECU? What adjustments could I make to the stock turbo if I decide not to upgrade?
I know there are lots of questions, but any advice would be greatly appreciated.
-Chris
#2 odell1523
odell1523
  • 1,293 posts
Posted 19 October 2004 - 09:36 PM
http://volvospeed.com/vs_forum/index.php?showtopic=10819
"Silver 850 t-5"
m56h swap, r clutch, 19t turbo
custom tuned ECU set at 19psi
optiflow intake,turboxs rfl bov w/ block off plate
reverse IC,aquamist 2d, 3" turboback(catless)
magnaflow stainless muffler
17" TSW eurace and 18" voxx forza(FOR SALE), H&R lowering springs
Bilstein yellow struts and shocks
Volvo Strut tower brace, carbon fiber cam cover
Sparco Milano racing seat
yet to install: FMIC KIT!
#3 theunderlord
theunderlord
  • PipPipPipPipPipPip
  • 14,738 posts
Posted 19 October 2004 - 09:40 PM
QUOTE(BlueVolvo850GLT @ Oct 19 2004, 02:31 PM)
-Chris
So this what you got so far:
850 GLT, 2.4L engine, mitsubishi turbocharger TD04HL-13G (190 hp, 197 lb-ft, low psi like 4 or 5)
With an ECU upgrade + Exhaust you'll be around 212HP 265lb-ft. (from iPD)
ECU upgrades are always a good idea!
#4 theunderlord
theunderlord
  • 14,738 posts
Posted 19 October 2004 - 09:41 PM
QUOTE(odell1523 @ Oct 19 2004, 02:36 PM)
#5 850 GLT
850 GLT
  • 300 posts
Posted 19 October 2004 - 09:48 PM
Do a search. This comes up pretty often. You can put a 1996-'97 15G turbo off a regular turbo volvo in there. You'll want to get a whole new exhaust and chip to take advantage of it.
Ignorance is bliss.
user posted image
#6 BlackT5
BlackT5
    NWC Rod Bender
  • 5,769 posts
Posted 19 October 2004 - 09:50 PM
QUOTE(odell1523 @ Oct 19 2004, 01:36 PM)
1998 S70 T5M
