P0303, S70 Running Horrible
17 replies to this topic
Poll: what should i replace first on my 2000 s70 glt? (9 member(s) have cast votes)
what should i replace first.
You cannot see the results of the poll until you have voted. Please login and cast your vote to see the results of this poll.
Vote
#1 michael-s70
michael-s70
  • 496 posts
Posted 16 December 2008 - 01:09 AM
have a 2000 s70, driving along in the snow today and all of the sudden the car just about stalls out at a light and starts shaking . unsure.gif i look down idle is about 850 and fluctuating between 500 and 1200. ohmy.gif please I need some input!!! fast!!!!
00 S70 GLT, 98 S70 T5M, 91 760 TURBO, 98 S70 N/A, 96 850R
PART OUT: silver 98 s70 t5a black interior
#2 nolanator
nolanator
  • 1,461 posts
Posted 16 December 2008 - 01:13 AM
QUOTE (michael-s70 @ Dec 15 2008, 05:09 PM) <{POST_SNAPBACK}>
okay so if you're going to replace one of those things...why wouldn't you replace them all. i've never heard of anyone replacing the cap rotor without replacing the cap and pretty much all the other stuff you listed...it's like thirty bucks worth of stuff ...seriously?
and why did you post this in the performance section
#3 MyCarIsRed
MyCarIsRed
  • 1,526 posts
QUOTE (nolanator @ Dec 15 2008, 08:12 PM) <{POST_SNAPBACK}>
ditto. Do all those things. At least do cap+rotor together.
#4 Fudge_Brownie
Fudge_Brownie
    Hippie Exterminator
  • 9,771 posts
Posted 16 December 2008 - 02:25 AM
Plugs cause they're cheap. Besides, 303 is the 3rd cylinder specifically isnt it? I bet that plug is toast or gapped too wide. At least pop it out and check it!!!
86 Kawasaki Gpz900R Ninja
#5 phenom1979
phenom1979
  • 191 posts
Posted 16 December 2008 - 02:41 AM
Replace them all but if you want to do one, figure out what the oldest one on your car is and do that one. Or just do plugs first, that seems to be the most possible culprit.
98 S70 T5 AUTO,NEW 16T AF, IPD CAI, OBX catless and muffler delete, IPD POLY UPPER MOUNT, QBM FIREWALL MOUNT,POWERFLEX TRANS MOUNT, UPSOLUTE ECU TUNE 17PSI to 18PSI with NXS BOOST CONTROLLER, SAMCO INTERCOOLER HOSES, SM SILICON VAC LINES.
FOR SALE BOSCH IGNITION COIL $20, INTERCOOLER HOSES $25, AIRBOX $25, OBX REAR MUFFLER $20, PICS ON REQUEST.
#6 1337-850
1337-850
  • 297 posts
Posted 16 December 2008 - 02:59 AM
QUOTE (phenom1979 @ Dec 15 2008, 09:41 PM) <{POST_SNAPBACK}>
Sounds like what's going on with my car, haven't pulled the codes yet, but when i diconnected the MAF it runs fine... so it could be a bad MAF but not a bad idea to replace those items either...
2011 C30 T5 - Black - Stock for now 1997 Volvo 855 GLT-5 LPTHPT - 13G16T (Straight Flange), IPD Stage II ECU, 3" TurboBack, K&N Cone, 17"Pegs, H&R, Bilstein HD, XC90 Spring Seats, IPD Sways and more...
1974 Porsche 914-4 - Tastefully modded
2004 Volvo V70 2.5T Titanium Edition18" Pegs/BFG KDW2's
#7 --Aaron--
--Aaron--
    Scum Bag
  • PipPipPipPipPipPip
  • 12,551 posts
Posted 16 December 2008 - 03:45 AM
OEM double check the gap is .028.
#8 michael-s70
michael-s70
  • 496 posts
Posted 16 December 2008 - 04:12 AM
i forgot to also say if i need plugs what ones? i will do it all i just want to know whats causing it. i also have coils not a dist lol my bad i wasnt thinking when i posted it. also what cyclinder is the 3rd one? dead center maybe idk?
#9 --Aaron--
--Aaron--
    Scum Bag
  • 12,551 posts
Posted 16 December 2008 - 04:15 AM
QUOTE (michael-s70 @ Dec 15 2008, 11:12 PM) <{POST_SNAPBACK}>
Volvo OEM plugs ftw....double check gap is .028.
Stay away from Iridiums they'll work for a while but it is proven time and time again they'll have you replacing plugs and spending more money eventually. (speaking from experience and observation of the forum)
My bad on the cap and stuff.....totally missed that your newer than 98. LOL @ us smile.gif
#10 s70turbo1998
s70turbo1998
  • 4,041 posts
Posted 16 December 2008 - 04:17 AM
OMG WTF REPLACE EVERYTHING.
Don't listen to that. P0303 is the 3rd cylinder(middle). Check that cylinder first. You don't have a cap and rotor. Make sure the gap is correct on the plug, and that it looks (relatively) clean. Switch out your third cylinder plug with a plug from another cylinder and run the car. See if the code changes cylinders. If it does, you just need one new OEM spark plug.
#11 MyCarIsRed
MyCarIsRed
  • 1,526 posts
Posted 16 December 2008 - 05:04 AM
QUOTE (s70turbo1998 @ Dec 15 2008, 11:17 PM) <{POST_SNAPBACK}>
aw... i was waiting for the write-up on s70 wire cap + rotor replacement... laugh.gif
#12 troyhyde
troyhyde
  • 1,290 posts
Posted 16 December 2008 - 05:26 AM
Check plug. Check resistance and continuity of the plug wire.
Not a week ago I replaced my 3rd cylinder plug wire. It was an open circuit that showed no continuity. Not sure why, it happened out of the blue. Thank goodness it wasn't a blown headgasket or something serious fouling the plug.
Diagnose don't buyagnose.
If you have a high performing car with highish mileage on the parts, replace all. Otherwise, just replace what's busted.
#13 550
550
    someone please talk to me
  • 12,870 posts
Posted 16 December 2008 - 04:59 PM
Definitely check the MAF as someone mentioned. That made my S70 shudder like a ho. It also threw some misleading codes.
#14 HtownTurboBrick
HtownTurboBrick
  • 6,213 posts
Posted 16 December 2008 - 05:53 PM
Check your coil packs, since they're probably original. They'll probably have a crack going down the sides.
~Jon AKA: the ddrunkn trigr hapy pumckin~
- '98 S70 T5M w/ '00 R motor swap 266whp/340wtq on 16T - 98' S70 T5 Black: Former DD new project - 96' 850 GLT -
RIP Joe Ng 02/29/56-08/18/05...
#15 michael-s70
michael-s70
  • 496 posts
Posted 17 December 2008 - 02:16 AM
QUOTE (HtownTurboBrick @ Dec 16 2008, 10:53 AM) <{POST_SNAPBACK}>
dude your a freakin genious!!! your right i went and had the code cleared and the packs pulled. what do you know all of them have cracks. exspecially cylinder 3 had bronze tint on one of the sides from it hitting the block.
thanks
#16 HtownTurboBrick
HtownTurboBrick
  • 6,213 posts
Posted 17 December 2008 - 03:56 AM
QUOTE (michael-s70 @ Dec 16 2008, 08:16 PM) <{POST_SNAPBACK}>
thanks
lol thats why i don't buy 99+...i hate coil packs and i hate ETM...98 simplicity is where its at. That being said, yea i've messed with enough 99+ cars to know how retarded the car gets with bad coil packs. spent 2 weeks hunting that rat bastard down. glad you got it all sorted out.
#17 michael-s70
michael-s70
  • 496 posts
Posted 17 December 2008 - 10:18 PM
QUOTE (HtownTurboBrick @ Dec 16 2008, 08:56 PM) <{POST_SNAPBACK}>
ya i love this car but it costs so damn much when something critical goes out. i almost wanna say "wheres my ford ranger? i want her back" lol but i guess its the perks of a Used car! dry.gif
#18 Mecay
Mecay
  • 61 posts
Posted 17 December 2008 - 10:56 PM
QUOTE (michael-s70 @ Dec 16 2008, 01:09 AM) <{POST_SNAPBACK}>
Do a research if a 01 c70 ht coils works on your car if it does,
I have a complete set (5) 65k miles on them for $135+ship.
t5 s70 '98 AT 16t angled+obx setup, NA intake w/tbody+960 t/body plate, j pipe...
Wanted: WHITE V70 WING. -SAMCOS
FOR SALE: Swap parts , 850R door sills, japan mani, singlemass flywheel,850 fogs, forge BOV...
