Problems With Boost Gauge
22 replies to this topic
#1 The Stig
The Stig
  • 2,163 posts
Posted 21 October 2004 - 07:50 PM
Ok, serious topic this time.
I had my Defi BF's installed this week (Boost and EGT), and unfortunately the boost gauge is misbehaving.
The opening sequence for the gauges are normal (i.e. the lights go on and off and the needle goes all the way up and down, like the STi). However, when I start laying on the boost, the boost gauge slowly climbs up a few 1/10th of a Bar, quivers up and down for a bit once the boost hits full at around 0.4 Bar (my 850R should be hitting 10.9 PSI, probably around 0.7 Bar) and then spikes big time (up to ~ 0.8-0.9 Bar when the gears change. The thing is, the stock Volvo boost gauge is behaving normally all the time, and reacting properly (the boost goes all the way towards the end of the white strip).
I looked at where he installed the boost line for the gauge, and he sliced open the one orangey red-tagged one mid way and installed a T connected, and fed that to the defi boost sensor. I tried to make sure all the connections were tight, and they seemed to be.
Anybody know what's going on?
1997 850R
Engine K&N Panel, HKS SSQV, AGP Blanking Plate, Red Silicon Vacuum Hose, RICA Engineering ECU
Suspension OMP Strut Brace, IPD Sways        Wheels 18" Pegasus, 225/35/18 Goodyear Eagle F1 GS-D3       Interior Défi BF Series Boost/EGT
Exterior Black Jewels [Headlights, Turn Signals, LED Side Markers], 8500K HIDs [Headlights/Fogs], IPD Black Mesh Grille, Headlight Wipers Removed
#2 turbor850
turbor850
    i am the new pegs
  • 4,188 posts
Posted 21 October 2004 - 07:52 PM
I am thinking some sort of leak at the boost guage or around the hoses of the boost guage
FIRST TO PUT 20G ON AN 850R
#3 JHEIII874T5M
JHEIII874T5M
    Level 6 Senior Member
  • 14,845 posts
Posted 21 October 2004 - 07:53 PM
the end of the volvo white gauge is 1 bar FYI.
Joseph H. Essaye III
#4 BlackT5
BlackT5
    NWC Rod Bender
  • 5,769 posts
Posted 21 October 2004 - 08:02 PM
Is there enough line to run it directly to the vacuum tree?
Maybe your gauge is fooked? needs to be calibrated?
1998 S70 T5M
#5 theunderlord
theunderlord
  • PipPipPipPipPipPip
  • 14,738 posts
Posted 21 October 2004 - 08:04 PM
QUOTE(850Ridah @ Oct 21 2004, 01:02 PM)
ya, where'd you score this gauge in question? could be fubar = mad.gif RED850R
#6 J0E
J0E
  • 2,025 posts
Posted 21 October 2004 - 09:33 PM
Recheck the vacuum line going from the source to the sender. Make sure you are either tapping into the tree, manifold, or any real viable source for manifold pressure (don't have a pre-'99, so not familiar with it, but I get everything directly from the intake manifold). Also, check all the electrical connections and make sure everything has been done properly, even though the gauge itself will tell you if there is a problem somewhere.
I highly, highly doubt you have a faulty gauge. Most likely, you are running exactly the amount of boost shown on the gauge and there is an issue with the car itself. Search on the hundreds of threads where people are not running the boost they thought they were supposed to and troubleshoot from there.
BTW, stock boost gauges on any car are meaningless...
#7 The Stig
The Stig
  • 2,163 posts
Posted 21 October 2004 - 10:08 PM
Thanks for the help guys. I don't think the problem is with the gauge itself, or the wiring to the controller, as the start-up/shutdown sequence is normal. Where the problem lies is probably with the placement or leaks, or perhaps even the Defi sensor itself (although unlikely).
Ok, for those with 850s, I'll post a pic of what exactly the boost lines look like right now. Maybe that might give a better idea of what everything looks like.
1997 850R
#8 Guest_DougK_*
Guest_DougK_*
Posted 21 October 2004 - 10:54 PM
QUOTE(HPTJoe @ Oct 21 2004, 03:33 PM)
Im glad someone said it.
Sounds like typical internal wastegate goodness to me going on.
#9 Guest_Guest_*
Guest_Guest_*
Posted 21 October 2004 - 11:04 PM
Did you say that he tapped it into the stock boost gauge? (or mabey im just reading it wrong) but that would be your problem i belive.
#10 The Stig
The Stig
  • 2,163 posts
Posted 21 October 2004 - 11:41 PM
I'm not sure if he tapped into the stock boost gauge line, but I just took some pics of the install, and I'll post them once Will gets them on his site, so that you guys can have a look.
What I meant by the stock boost gauge was that it was behaving normally, and reacting much more quickly than the Defi one, and it was showing the normal amount of boost I'd expect (i.e. bout 7/8's of the way to the end of the white), so nothing's changed there.
1997 850R
#11 The Stig
The Stig
  • 2,163 posts
Posted 21 October 2004 - 11:42 PM
FWIW, the line that he cut seemed to travel into a metallic cylinder near the Turbo from which the wastegate comes out of. Does that help anyone?
1997 850R
#12 The Stig
The Stig
  • 2,163 posts
Posted 22 October 2004 - 01:44 AM
Ok, here are the pics of the install. Anything seem suspicious?
1997 850R
#13 lax01
lax01
  • PipPipPipPip
  • 4,781 posts
Posted 22 October 2004 - 01:45 AM
why do you have a t-fitting in the vacumn line that goes to the waste-gate? is your entire tree full?
2002 BMW M3
Past: 1995 Volvo 850 Turbo
#14 The Stig
The Stig
  • 2,163 posts
Posted 22 October 2004 - 03:19 AM
I assume it is, b/c that's how the mechanic installed it. Could that be the cause?
1997 850R
#15 TorqueSteer
TorqueSteer
    Pretty Boy Racing
  • 4,231 posts
Posted 22 October 2004 - 04:09 AM
Wow those original vaccum lines look awful, i would suggest replacing them all. Just unhook that line and plug it into the vaccum tree, it couldnt possibly be full can it?
#16 The Stig
The Stig
  • 2,163 posts
Posted 22 October 2004 - 04:19 AM
Not sure, I'll have a look!
1997 850R
#17 styx0r
styx0r
  • 401 posts
Posted 22 October 2004 - 05:43 AM
Uhh, yeah, that's the line between the boost controller and the wastegate.
1994 850 Turbo Chassis. 151,000 miles. 1995 HPT motor 15,000 miles, M56H transmission/R clutch. 19T, BSR 3in downpipe, 3in electronic exhaust cutout, IPD 2.5in cat-back. EST Intercooler, Samco intercooler hoses, custom intercooler pipe (metal replacement for stock plastic piece), Greddy Type-S BOV, Aquamist 1S 0.7mm @ 12PSI, Upsolute ECU @ 1.4bar (~21psi), Lotek tripple pod, Greddy Boost, Oil Pressure, EGT gauges, Greddy Catch Can, Greddy Turbo timer, Bilstein shocks/struts w/IPD lowering springs, IPD swaybars, OMP strut tower bar, 17in Alba wheels, 320mm front brakes, X-drilled and slotted, EBC greenstuff pads all around, Bridgestone S-03s 225/45/17s. Gemini Carbon Fiber Hood, Jewel headlights/clear corners.
#18 JHEIII874T5M
JHEIII874T5M
  • 14,845 posts
Posted 22 October 2004 - 06:32 AM
lol classic... ok... do this...
find your throttle body cover, take it off (held in by one screw) then you'll see
take one of the caps off and plug the line into there
#19 The Stig
The Stig
  • 2,163 posts
Posted 22 October 2004 - 06:55 AM
Thanks Joseph, I need a bit of hand holding when it comes to stuff like this. But manly hand holding, of course. biggrin.gif
I'll go and buy some more vacuum hose tomorrow.
1997 850R
#20 theunderlord
theunderlord
  • 14,738 posts
Posted 22 October 2004 - 05:13 PM
QUOTE(Red 850R @ Oct 21 2004, 11:55 PM)
biggrin.gif So much male bonding on volvospeed.
