Need a quick answer on this one. I believe that the ECU in the 850 may be faulty. Will an ECU from a '98 S70 T5 run the 850?
S70 Ecu Run An 850?
Started by WhiteT5, Dec 20 2008 11:16 PM
6 replies to this topic
Posted 20 December 2008 - 11:16 PM
- Sean
Posted 20 December 2008 - 11:17 PM
not sure how much help i can be but is the 850 a turbo?
Underhill, VT 2002 S60 T5 5 speed. 2000 Honda CBR 929RR
Posted 20 December 2008 - 11:25 PM
QUOTE (wagonmafia @ Dec 20 2008, 05:17 PM) <{POST_SNAPBACK}>
Yes. Car in the sig. Not worried about how well it'll run it, just whether or not it'll run it at least while idling.
- Sean
Posted 20 December 2008 - 11:38 PM
Yes but make absolutely sure the ac is off or you may never be able to use it again.
G
G
1998 S70 T-5M, 1996 854 Turbo, 1998 V70 T-5M SOLD, 1998 V70 T-5A SOLD, 1996 854 Turbo SOLD, 1993 244 SOLD, 1991 244 SOLD, 1998 V70 T-5M (18T) SOLD, 1985 245 Turbo SCRAPPED, 1982 245 Turbo SOLD, 1997 854 GLT (16T) SOLD,1995 854 Turbo (18T) SOLD, 1997 855 T-5 SOLD, 1996 854 TLA (18T) SOLD
Posted 20 December 2008 - 11:55 PM
Hhhhmmm. I swapped the ECU's. It still doesn't start. The only code present on the 850 is 3-2-5 (Memory Failure). It turns over. I've got spark and fuel pressure.
Background: The car hasn't been started in about 3 1/2 weeks (yeah, bad idea, I know) and now it doesn't want to start. The gas in it can't be more than 6 weeks old at the VERY most, and is more likely about 5 weeks old. I've tried starting fluid and all. What gives?
- Sean
Posted 21 December 2008 - 02:18 PM
You sure your battery is good ? Have your alternator and starter tested as well.
MY97 855 Manual swap, Porsche Brakes, 16T on LPT block and plenty of IPD parts
Posted 21 December 2008 - 06:16 PM
i'm almost positive the only way you would be able to use that ecu is if you have a 97 850
and you still wouldn't be able to use the a/c, or tracs iirc
1993 960 wagon. Most awesome car evar.
This topic is locked
