Vacuum Lines
Posted 22 October 2004 - 12:28 AM
Posted 22 October 2004 - 12:30 AM
-Petri (Val)
Posted 22 October 2004 - 12:35 AM
do they sell a set of lines at some off the sites you guy's use or go to a volvo parts store
Posted 22 October 2004 - 12:39 AM
Also, if you can get a hold of silicone lines, they hold boost much much better and will not deteriorate like rubber. check out www.hosetechniques.com
Edited by FINN, 22 October 2004 - 12:41 AM.
-Petri (Val)
Posted 22 October 2004 - 12:54 AM
Posted 22 October 2004 - 01:03 AM
Posted 22 October 2004 - 04:16 AM
I just ordered the hose kit from hosetechniques about how many vacuum lines will I be looking for thanks Doug
Posted 22 October 2004 - 04:17 AM
a lot of it is trial and error....i used alot of 4mm also some 6.5 and 10mm....
98 V70XC (White)
98 V70R (Saffron)
Posted 22 October 2004 - 04:21 AM
what kind of optima is that in your car I need battery and want optima but can't find any info on them for my car 97 850
Posted 22 October 2004 - 04:25 AM
Posted 22 October 2004 - 04:47 AM
You might want to check the dealer, maybe they can give you a deal. After replacing all of my lines, i noticed that the line that the Volvo dealer uses is far superior to any silicon or rubber line i have ever seen, they also gave it to me for cheaper than anywhere else.
[/quot
i replaced my vacuum lines with volvo lines. they do seem strong, but i paid a lot. can't remember but it was a lot for a yard.
96'850R: ipd ecu, est downpipe w/ test pipe, custom 3" ss catback w/ magnaflow muffler, est air intake, hks ssqv bov, samco hoses, magnecore 8.5mm, ipd engine mount stabilizer, vdo boost gauge, koni shocks/struts, est/sam springs, oem strut brace, fcp big brake kit, cross-drilled rotors, ss brake lines, PIAA exteme white bulbs, alpine v12 amp, 2-12" JL audio subs
Posted 22 October 2004 - 05:11 AM
#14
Posted 22 October 2004 - 06:01 AM
2004 Volvo V70 2.5T Titanium Edition
#15
Posted 22 October 2004 - 10:31 PM
that is what is on those lines it for heat protection it is cloth over rubber because they are so close to the block. that is why they felt so different from the others so now the question is do you really need the protection on those line or will the new lines be okay
#16
Posted 23 October 2004 - 01:58 AM
What are the specs for the hose sizes I need for my car?
Thankyou!
12sec '89 740 Turbo Wagon
#17
Posted 23 October 2004 - 04:08 AM
Edited by TorqueSteer, 23 October 2004 - 04:10 AM.
#18
Posted 23 October 2004 - 05:49 AM
#19
Posted 24 October 2004 - 02:23 AM
how many lines are in the 850 engine bays?
#20
Posted 24 October 2004 - 04:14 AM
