302mm Brake Upgrade >>>>
#1 Guest_Guest_*
Posted 25 October 2004 - 07:43 PM
Posted 25 October 2004 - 07:44 PM
Upsolute ECU @16 Pounds Boost
243Whp / 285 Wtq
Posted 25 October 2004 - 07:51 PM
Im not 100% but i think they were standard on 1999 v70r...talk to larry108 and/or gdogg...
98 V70XC (White)
98 V70R (Saffron)
Posted 25 October 2004 - 08:14 PM
Posted 25 October 2004 - 08:17 PM
243Whp / 285 Wtq
Posted 25 October 2004 - 08:53 PM
I can guarantee you that the 302mm brakes will work with the Meteors. I put them on my car. The 302mm were stock on the 99+ R's. You can check the TME website. I can't remember the address, but they have details on their site about which Volvo wheels the 302mm rotors will and will not work with. Hope this helps.
2003 Honda Civic Si
Talmo, Georgia
Posted 25 October 2004 - 08:55 PM
TME front brake kit for 850 and some 70-series cars include larger (302 mm) brake discs, caliper carriers and brake pads. Steel braided brake hoses are ordered separately. Require 16" wheel size. 302 mm brakes will not fit the following Volvo original 16" wheels: Columba, Persus, Solar, Pleiad, Helium.
We can also supply a larger (320 mm) front brake kit on special order for 850, 70-series as well as for S60, V70N and S80. Require 17" wheel size. For 40-series we only have a steel braided brake hose kit.
Posted 26 October 2004 - 01:17 AM
ohhh...320mm sounds nice... any idea on if we can order it here in the US through Ipd or something like that?
SpeedTuning 17PSI - MSD 6A - 3" Back - Sunglasses
Posted 26 October 2004 - 01:45 AM
Larry...do u kno if the 99+v70r, w/ stock 302mm, had bigger brakes in back???
98 V70XC (White)
98 V70R (Saffron)
Posted 26 October 2004 - 02:25 AM
There it is, only notice there is very little clearance from the caliper to the wheel. I changed to 17" wheel.
06 GTO LS2 (new project)
98 V70R (wife's car now)
94 854 T (surviving a teenager)
92 740 (my winter bomb)
01 Vmax
03 SV 650
03 Speed 4
05 Sprint
Posted 26 October 2004 - 02:26 AM
pic no worky
Posted 26 October 2004 - 02:28 AM
i am planning to change my brakes in next month. Kevin, how much is special order for 850 series? I got 17 volans.
Posted 26 October 2004 - 02:30 AM
#14
Posted 26 October 2004 - 02:34 AM
#15
Posted 26 October 2004 - 02:35 AM
2400.-
4986-853022 302 mm front brake kit with plain discs, calipers and pads. 4 400.-
The first one is 2400 kronor ~ $350
The second one is 4400 kronor ~ $610
Edited by White850T5, 26 October 2004 - 02:36 AM.
#16
check out the TME TMEwebpage... iPD can prolly import it for you....
#17
Posted 26 October 2004 - 02:43 AM
2400.-
But i want to buy( 320 mm) front brake kit. But it is too much money.. $1,271 usd
#18
Posted 26 October 2004 - 02:53 AM
The 320mm brake kit was very spendy and was still a 1-piston floating caliper.
The 98's and 99's had the same rear brakes. 295mm solid rotor with Girling floating caliper. Same caliper used on the front of some 240's and 740's. The 2000 R's had a ventilated rear disc. Same overall diameter as far as I know. I am still trying to find out if it was a different caliper for the 2000 R's.
2003 Honda Civic Si
Talmo, Georgia
#19
Posted 26 October 2004 - 08:22 PM
98 V70XC (White)
98 V70R (Saffron)
#20
Posted 26 October 2004 - 09:23 PM
2400.-
$1200 for a 320mm brake upgrade, that does not seem to much to me, especially that it uses VOLVO OEM parts.
243Whp / 285 Wtq
