TorqueSteer 212 Posted February 12, 2009 Report Share Posted February 12, 2009 HahnI am using that exact product for 2 years +, works good!Heres my thread of my Hahn Racecraft super 16g install if it could help. The only thing ive changed since that thread is getting rid of the ATP Adapter.http://volvospeed.com/vs_forum/index.php?s...920&hl=hahn19 psi on the 16g throws me back in the seat and always puts a smile on my face. The 20g should make you very very happy once its all setup! Link to post Share on other sites
turbor850 37 Posted February 12, 2009 Report Share Posted February 12, 2009 I am using that exact product for 2 years +, works good!Heres my thread of my Hahn Racecraft super 16g install if it could help. The only thing ive changed since that thread is getting rid of the ATP Adapter.19 psi on the 16g throws me back in the seat and always puts a smile on my face. The 20g should make you very very happy once its all setup!Nice write up and install. You ever dyno that thing Ben ? Link to post Share on other sites
lookforjoe 2,702 Posted February 12, 2009 Author Report Share Posted February 12, 2009 I am using that exact product for 2 years +, works good!Heres my thread of my Hahn Racecraft super 16g install if it could help. The only thing ive changed since that thread is getting rid of the ATP Adapter.http://volvospeed.com/vs_forum/index.php?s...920&hl=hahn19 psi on the 16g throws me back in the seat and always puts a smile on my face. The 20g should make you very very happy once its all setup!Many Thanks!That is helpful - I hadn't thought of sleeving the housing holes, but it makes sense. What copper tubing did you use, regular plumbing supply?I was also wondering how much manipulating I would have to do to secure the actuator - you example looks practical - you don't have any flex issues where it just sleeving the boost outlet nipple?I'm doing the same with the outlet flange - and again, yours helps me pre-plan just how short to make the initial step.Very helpful! :) Link to post Share on other sites
TorqueSteer 212 Posted February 12, 2009 Report Share Posted February 12, 2009 Many Thanks!That is helpful - I hadn't thought of sleeving the housing holes, but it makes sense. What copper tubing did you use, regular plumbing supply?I was also wondering how much manipulating I would have to do to secure the actuator - you example looks practical - you don't have any flex issues where it just sleeving the boost outlet nipple?I'm doing the same with the outlet flange - and again, yours helps me pre-plan just how short to make the initial step.Very helpful! Yeah the copper tubing is just regular plumbing supply. As far as the actuator fitting is concerned, I did have flex when I was using that skinny bracket. I then switched to a steel bracket that was a good 3mm thick. Once I had that secured in, there was no flex at all, even with the other side resting on that boost outlet nipple.Nice write up and install. You ever dyno that thing Ben ?Thanks! No I never dynoed it, I gave up on benchmarking this car awhile ago. It keeps me happy on the street, so thats all that matters to me. Link to post Share on other sites
Big Will 364 Posted February 12, 2009 Report Share Posted February 12, 2009 Thanks! No I never dynoed it, I gave up on benchmarking this car awhile ago. It keeps me happy on the street, so thats all that matters to me.Amen to that! I'm sure your setup is fantastic. Link to post Share on other sites
lookforjoe 2,702 Posted February 14, 2009 Author Report Share Posted February 14, 2009 Worked on the drain, oil feed & coolant feed lines...used the old motor for the mock upthis is the resultused segments of the power steering bracket sleeve to splice the cut line segmentsline arrangement - all clear & room to drop the drain tube without touching the other lines Link to post Share on other sites
Chilled man 2,981 Posted February 14, 2009 Report Share Posted February 14, 2009 so what did you use to extend the parts ? Link to post Share on other sites
GeraldJ 47 Posted February 14, 2009 Report Share Posted February 14, 2009 Looking good man as your work always does Link to post Share on other sites
lookforjoe 2,702 Posted February 14, 2009 Author Report Share Posted February 14, 2009 so what did you use to extend the parts ?The power steering bracket sleeve... Link to post Share on other sites
Chilled man 2,981 Posted February 14, 2009 Report Share Posted February 14, 2009 :lol: so welded them or ? probally going to have to do this when I put my 20g on Link to post Share on other sites
lookforjoe 2,702 Posted February 14, 2009 Author Report Share Posted February 14, 2009 so welded them or ? probally going to have to do this when I put my 20g onBraised (brass rod) the sectionsStill have to do the coolant return, but I don't have a spare, so I'll have to do that on the fly. Link to post Share on other sites
B Mac 956 Posted February 14, 2009 Report Share Posted February 14, 2009 you sir, are absolutely nuts :P Link to post Share on other sites
lookforjoe 2,702 Posted February 15, 2009 Author Report Share Posted February 15, 2009 Worked on the Wastegate actuator - drilled & tapped the housing to hold the actuator, capped the existing boost port, and made a new homemade nipple for one of the lower bolt holes.actuator alignment, clearance for outlet hosehaven't decided how to deal with the other mount point - I really need a boss tig welded to the compressor housing I guess I'll JB weld the bolt to the housing for now. Link to post Share on other sites
ozzimark 982 Posted February 15, 2009 Report Share Posted February 15, 2009 Cutting it close with the gap between the hose and the actuator rod there As always, looks great man. Any plans to finish up the mockups and drop it into the motor soon? :P Link to post Share on other sites
lookforjoe 2,702 Posted February 15, 2009 Author Report Share Posted February 15, 2009 Cutting it close with the gap between the hose and the actuator rod there As always, looks great man. Any plans to finish up the mockups and drop it into the motor soon? Not much choice on that, I drilled as far out on the landing as I could.Turbo goes in Monday :D Link to post Share on other sites
