Blow Off Valve (bov)
14 replies to this topic
#1 Caaine
Caaine
  • 177 posts
Posted 26 October 2004 - 10:14 AM
I have always wanted that sweet sound of a BoV. But I donīt want to overdo it because I assume it gets annoying and the missus might have me remove it! wink.gif
I just purchased an S80 T6 and thought it was a great idea to put in a Bov, probably sounds sweet with that 6 cylinder engine. Now, I am actually quite a newbie when it comes to cars and modifications and was hoping you guys could answer a few questions.
1. Is it viable to use in an S80 T6?
2. Is it any different to use with twin-turbos than a single one?
3. What brand should I purchase for a cool modest sound, reliability and ease of installation? (HKS, Greddy, BlitZ)
4. Will it affect the car/performance/mileage in any negative way?
Best regards,
1999 S80 Turbo T6
Regards,
Caaine
#2 styx0r
styx0r
  • 401 posts
Posted 26 October 2004 - 10:24 AM
1. it is possible to mount BOVs on an s80T6.
2. The s80 uses parallel turbos (3 cyl per turbo), one intercooler for each? - I'm not sure on this, but you will need one BOV for each pressurized pipe system.
3. HKS SSQV is not modest, could be annoying to some, expensive - would not suggest in your situation. Greddy Type-S might be a good choice. I like mine.
4. The stock "BOV" equivilant vents the excess boost pressure back into the airbox when you let off the throttle. An aftermarket BOV like you are talking about will vent that pressure into the atmosphere, thus the (relatively) loud noise - much like you would hear from a semi.
Because the ECU thinks that all the pressurized air is still in the system, when you vent it to the atmosphere instead, the motor will run rich for a short time (because the ECU believes more oxygen is in the motor then there actually is. This can create a small period of reduced performance / and or back firing (if you have no cats).
This will not however hurt your motor. Mileage should be unaffected, performance should be almost exactly the same. In your situation it's a cosmetic mod. If you decide to run lots of boost or swap to a manual transmission, a BOV starts to make performance sense.
hope my garbled mumblings help
1994 850 Turbo Chassis. 151,000 miles. 1995 HPT motor 15,000 miles, M56H transmission/R clutch. 19T, BSR 3in downpipe, 3in electronic exhaust cutout, IPD 2.5in cat-back. EST Intercooler, Samco intercooler hoses, custom intercooler pipe (metal replacement for stock plastic piece), Greddy Type-S BOV, Aquamist 1S 0.7mm @ 12PSI, Upsolute ECU @ 1.4bar (~21psi), Lotek tripple pod, Greddy Boost, Oil Pressure, EGT gauges, Greddy Catch Can, Greddy Turbo timer, Bilstein shocks/struts w/IPD lowering springs, IPD swaybars, OMP strut tower bar, 17in Alba wheels, 320mm front brakes, X-drilled and slotted, EBC greenstuff pads all around, Bridgestone S-03s 225/45/17s. Gemini Carbon Fiber Hood, Jewel headlights/clear corners.
#3 Caaine
Caaine
  • 177 posts
Posted 26 October 2004 - 10:41 AM
Thanks much for a concise and a quick reply. Do I just purchase a Greddy Type-S Universal fit then or something specific?
Iīm not thinking this will improve the performance of the car, just to instill fear into those GTIīers that will be to my side on a red light biggrin.gif
1999 S80 Turbo T6
Regards,
Caaine
#4 turbor850
turbor850
    i am the new pegs
  • 4,188 posts
Posted 26 October 2004 - 03:18 PM
QUOTE
nope, just one intercooler
FIRST TO PUT 20G ON AN 850R
#5 Turbo Brick
Turbo Brick
  • 488 posts
Posted 26 October 2004 - 03:23 PM
You'll only need one BOV even though you have two turbos.
#6 Adam Franke
Adam Franke
    Supporting Member 4 Lyfe
  • 2,299 posts
Posted 26 October 2004 - 03:46 PM
Hahaha, get two, it'll sound cooler...*PSHH**PSHH* If that doesn't scare a GTI....
#7 Caaine
Caaine
  • 177 posts
Posted 26 October 2004 - 05:06 PM
Thanks for the all the replies guys. Think I will stick with one BoV though smile.gif
Will this work for me?
Greddy Type S on Ebay
BoV sound
1999 S80 Turbo T6
Regards,
Caaine
#8 theunderlord
theunderlord
  • PipPipPipPipPipPip
  • 14,738 posts
Posted 26 October 2004 - 05:16 PM
QUOTE(Caaine @ Oct 26 2004, 10:06 AM)
BoV sound
dammn that sounds cool!
#9 swdracr
swdracr
    Pretty Boy Racing
  • 1,225 posts
Posted 26 October 2004 - 05:17 PM
QUOTE(Caaine @ Oct 26 2004, 12:06 PM)
BoV sound
Patrick
'97 850 RIPB Image
IPB Image
#10 theunderlord
theunderlord
  • 14,738 posts
Posted 26 October 2004 - 05:20 PM
QUOTE(swdracr @ Oct 26 2004, 10:17 AM)
BoV sound
how can you tell?
#11 J0E
J0E
  • 2,025 posts
Posted 26 October 2004 - 05:40 PM
QUOTE('98S70R @ Oct 26 2004, 10:20 AM)
how can you tell?
By turning your speakers on.
#12 theunderlord
theunderlord
  • 14,738 posts
Posted 26 October 2004 - 05:42 PM
QUOTE(HPTJoe @ Oct 26 2004, 10:40 AM)
how can you tell?
so funny.
#13 JHEIII874T5M
JHEIII874T5M
    Level 6 Senior Member
  • 14,845 posts
Posted 26 October 2004 - 05:59 PM
turning the speakers on, also look at the link...
http://www.935motorsports.com/media/hksSSBOV.mp3
Joseph H. Essaye III
#14 theunderlord
theunderlord
  • 14,738 posts
Posted 26 October 2004 - 06:01 PM
QUOTE(JHEIII850Turbo @ Oct 26 2004, 10:59 AM)
see that's all someone had to say..
#15 Caaine
Caaine
  • 177 posts
Posted 26 October 2004 - 06:04 PM
If you like that, they have a bunch of audio and video at Blow Off Valves
I really like the sound in the BoV I linked above. They say, Larger Valve HKS... which means?
Should I go for HKS instead or have I just not found a good Greddy sound file yet? Huge distortion in many of these clips as those geniuses place the mic right where the air blows off. smile.gif
Edited by Caaine, 26 October 2004 - 06:07 PM.
1999 S80 Turbo T6
Regards,
Caaine
