Creaking Sound Suspension
Posted 27 October 2004 - 11:06 PM
also, is it possible that the pass side of my car looks a little higher than the driver side?
I also think the car is not sitting as low as it was when i first had the springs installed...looks a little higher now
alignment issue?
i now want to cut the springs....just not low enough for my taste!
Posted 27 October 2004 - 11:08 PM
me too.. if you do it... we need a write up!
Posted 27 October 2004 - 11:20 PM
Sold in 2008, 1996 White 850R Wagon
Posted 28 October 2004 - 12:21 AM
Don
IPD Ecu
Bilstien HD's
B&G spings
Volans
96R wagon
740 wagon
Posted 28 October 2004 - 01:12 AM
Andrew, I'm just a skinny little indian guy that weighs next to nothing, so it's definitely not me in this case!!!....maybe I'm just trippin and it's all psychological, but i definitely want the car lower.
Posted 28 October 2004 - 01:59 AM
how but if the rear of the car is higher than a front? i got est sprins
Posted 28 October 2004 - 02:12 AM
Posted 28 October 2004 - 05:56 AM
no sway bar in there, but what are delta links, where are they, what they look like???
yeah, maybe I should grease it up a little....just wasn't doing that until i got the springs installed, so i'm just trying to troubleshoot here....not really affecting anything i hope, except that the noise is annoying and embarrassing!
Steve, I have the exact same car as you, and I hope I can get it looking like yours someday!...good job man.
#9 Guest_Guest_*
Posted 28 October 2004 - 04:26 PM
You need to let them be on there for atleast several weeks and a few thousand miles to break them in and let them settle. They will get lower with time, and get even most likely. Mine for a while looked a touch off to one side but they evened up and lowered down.
-Andy//mAydAy//Too lazy to log in
Posted 28 October 2004 - 05:54 PM
-Pras-
Posted 29 October 2004 - 12:43 AM
...good job man...
thanx pras..
delta links is just the name of the rear suspension on 850 fwd cars.. it's the two beams u see going under and across the car. they have some play in them (supposedly helps aid turn-in).. u may wanna check the ends out.
btw..found a few good indian restaurants up here in sf.. hmm.. mango chutny and nan... i luv nan
Posted 29 October 2004 - 01:48 AM
...good job man...
thanx pras..
man, i'm hungry.
Posted 29 October 2004 - 02:03 AM
#14
Posted 29 October 2004 - 06:11 AM
#15
Posted 29 October 2004 - 03:00 PM
1. The driver's side of the 850 and 98-00 S/V 70 series are lower by 1/8" - 1/4" due to slight uneven weight distribution in the design of the car. It is like this in stock form, you just notice it more once the car has been lowered. There is nothing that can be done about it, it just is.
2. Suspension creaking on a lowered car is very common, especially in the rear when pulling into driveways and such. You can check the lower bolt on the bottom of the rear spring to ensure it is tight and also grease the bottom cup the spring sits in. This will alleviate some of the creaking, but with these cars creaking is all too common.
3. I have cut the lowering springs on my V70. 1 coil in the front and 1/2 a coil in the rear were cut, overall stance is about 2.5" lower than stock on 19" wheels. Though I do not have a problem with cutting springs within reason and do not have any issues with ride or suspension problems, I will not do any write-up on how to do it. Because things can go wrong, it becomes too much of a liability. However, I will say that it is not rocket science to take a grinder and cut off a top coil on a spring.
Good luck!
1998 V70 T5
Chrome 19" Niche Rhine Wheels
#16 Guest_WagonfanT5_*
Posted 29 October 2004 - 05:38 PM
I have a V70 T5 that i installed TME sport springs from a sedan. The guys at IPD tell me that the springs from a sedan are made for a lighter jerk end and there for will sag which is the case as my wagon is lower and yep it creaks too (the G-freind hates it-which is nice b/c we just put the miles on her wagon) and have taken it in and greased the ares where the springs seat in. It helps but not permanent (especially when it gets cold) I have also been told that it is the struts that are creaking too and if you sure around on this site you will see some that say that the stock shocks can not handle lowering and it blows them out which happened on mine.
So there's my .02 but i would try and find some real wagon rears.
As for me i am switch back to my stock springs in back with bilstiens.
#17
Posted 29 October 2004 - 06:36 PM
Good luck!
#18
Posted 29 October 2004 - 08:50 PM
#19
Posted 30 October 2004 - 12:49 AM
#20
Posted 30 October 2004 - 02:11 AM
Just use some toothpaste!
Buy a can of this Lithium grease. Then jack up one side at a time and spray your springs with it. Its should stop the noise.
