How would you go about raising compression on the 5 cylinder motors in both the turbo and non turbo cars?
How Do You Raise Compression?
Started by ProjectT-5R, Oct 28 2004 06:15 AM
6 replies to this topic
Posted 28 October 2004 - 06:15 AM
2000 V70R M56
1995 T-5R M56
1989 244 M47
1985 744T M46
1995 T-5R M56
1989 244 M47
1985 744T M46
Posted 28 October 2004 - 06:18 AM
thinner head gasket
Joseph H. Essaye III
Posted 28 October 2004 - 07:07 AM
Oversize pistons... I've never heard any word one way or the other on how much you can shave our heads? Think I've asked a couple of times.
Posted 28 October 2004 - 07:19 AM
Oversized pistons will not raise the C/R. You can mill the head a tad or you can go with a higher compression piston.
99 C70 5sp
- Full Vms long block
-ARP Head Stud Kit
-Custom Intake Manifold
-Custom Tubular Manifold
-Tial 38/40mm External Gate
- Hhs Ssq Bov
- Walbro 255lph pump
- RC 550cc Injectors
- -8AN Braided fuel lines
- Rica custom Tuning
VolvoMotorSports
Posted 28 October 2004 - 07:59 AM
Rob, just the person I wanted. You had made a comment about VMS would be able to make a 300 hp NA 5cyl. That is what made me raise this question. How would you do that other then raising compression?
And to stay on topic, I understand milling the head cause it would cause i smaller combustion chamber, but the pistons come to the top of the block, so how would you get higher compression pistons? Just have smaller more percision valve reliefs so there is more material there? Cause the valve relief now is just like a large cirle dip in the piston not just a cut for each valve. Is there any other way to make a higher compression piston?
2000 V70R M56
1995 T-5R M56
1989 244 M47
1985 744T M46
1995 T-5R M56
1989 244 M47
1985 744T M46
Posted 28 October 2004 - 12:04 PM
QUOTE(ProjectT-5R @ Oct 28 2004, 07:59 AM)
This is one example
Terry Coon
Custom Performance Department
Volvomotorsports
PH;800 652-0042
Custom Engine Builders
OEM Replacement Parts
Volvomotorsports
PH;800 652-0042
Posted 28 October 2004 - 01:47 PM
QUOTE(ROB @ VMS @ Oct 28 2004, 01:19 AM)
Sorry if it sounded like I meant the first or second oversize kind of oversize.
Terry, do you know how much you can mill off of the head without running into valve clearance issues? (cars with turbo and NA pistons will probably be different amounts)
Or maybe what the stock valve clearance is. That should give a decent idea.
