Magnaflow Cat
6 replies to this topic
#1 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 28 October 2004 - 06:38 AM
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...7930426008&rd=1
it says it's not good for CA residents, but I figure the entire exhaust is illegal, so would this work on my 850 in CA and not set off an CEL as long as it is OBD2?
do i need air tube or no air tube....if i want a CA compliant OBD2 cat, then it's like $200-300....ridiculous price...oh, and will i need the O2 bung built into it?
thanks for the help fellas,
-Pras-
Edited by prasamin, 28 October 2004 - 06:39 AM.
#2 Hum Jim
Hum Jim
  • 239 posts
Posted 28 October 2004 - 03:17 PM
You can get a 3" Carsound (Magnaflow) Cat for around $100 and they are CA legal. no need for a air tube.
This may be the same Cat. http://www.jegs.com/cgi-bin/ncommerce3/Pro...491&prmenbr=361
Edited by Hum Jim, 28 October 2004 - 03:24 PM.
IPB ImageIPB Image
Right before it blew up at Laguna Seca last November 30th
Black 97 854R, Sport Grill, Urethane Top Bushing, Momo Strut brace, Koni shocks, K&N air filter, B&M Tranny cooler, Upsolute ECU, Accel super coil, Magnacore plug wires, Custom Swedish I/C, Reverse I/C piping W/Samco hoses, HKS SSQV BOV, Polished Throttle body, Custom 3" S.S. down pipe, Magnaflow 3" Catalytic, Apexi 3" Muffler, IPD Sport Springs, IPD Sway Bars, QuickBrick Motorsports end links, Brembo Lotus calipers & 320x28mm X-drilled front rotors with Brembo Galpher pads, Brembo X-drilled rear rotors with EST Carbon Fiber pads, Stainless Steel brake lines, 215x45 17" Toyo Proxes 4 on Volans, 235/40 17" Toyo RA1 on Team Dynamics Pro-Race 1.2 17"x8" (for track), IPD Skid plate, Greddy TT, Custom 3 guage pod, AEM WB o2, Auto Meter Z-series Boost, EGT, Oil press, Water temp., Tranny temp. gauges, Mobil 1 w10/30, Royal Purple ATF, Horns moved for air flow, de-badged,
#3 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 28 October 2004 - 06:03 PM
http://www.car-sound.com/universal/430.htm
here's the link for the info on the cat i'm referring to
http://www.performanceintl.com/shop/detail...wcat&desc=43034
and here is a roundabout price on it....
could i just go with the one on Jegs or one from Ebay in the same series?....and if I need a O2 before the cat and after the cat, can they just build that onto my piping, or do I need the 2 O2 bungs on the actual converter?
i am not paying $200 for a cat...
#4 Guest_Guest_ashman_*_*
Posted 29 October 2004 - 05:54 AM
Im going through the same thing pras. I even had a shop tell me that there was no way theyd put a high flow cat on a 96 850 because its illegal. stuff. Thats all I get here in LA. Let me know where you get yours.
#5 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 29 October 2004 - 06:42 PM
go to the ghetto, and they'll do anything you want...i went to a couple of places in Inglewood....as long as you bring the cat in, they will do it for you...no one will "provide" the cat for you....buy one at JEGS or Ebay, and take it in when you want everything welded up, and they will install it....make sure you keep your O2's in there, and should be fine i suspect....I think I can just go with a OBD2 HF cat, that is not CA compatible, but none the less OBD2, and as long as there is no CEL, I should be okay...risky, but I'll take the risk...let's just say I know a guy...When I smog end of Jan, and if I pass with this "guy I know", i'll ask if I can get him some more business...i'm sure he won't mind!
#6 fromtheshadows
fromtheshadows
  • 665 posts
Posted 30 October 2004 - 10:24 AM
yeah ur right. I would go to san pedro muffler shop cause I know theyll do it, but i dont like the way they do things over there. I guess im ghetto bound then. fun place for someone as blonde as i am. yay
Hailing from Long Beach, CA
'96 850 turbo with the usual full list of mods
My wheels weigh 5.8kg
#7 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 30 October 2004 - 06:53 PM
don't go to san pedro muffler...they'll charge you $200 just to weld it up...i went there twice already...they suck, even though they build great exhausts
