Is A 16g Turbo A Direct Bolt-on From The 15t?
5 replies to this topic
#1 MACH FYV
MACH FYV
  • 30 posts
Posted 01 November 2004 - 10:38 PM
Hey gang,
I've been wondering which turbos would be suitable upgrades from the 15G's. I know a lot of ppl opt for the 19T, but would a 16G bolt right in? These are readily available form all sorts of Mitsubishi message boards and the like. Is anybody running one? Lemme know! Thanks!
Edited by MACH FYV, 01 November 2004 - 10:44 PM.
Sean - Huntington Beach, CA
1994 850 T5 Wagon - "The Daily" :: 1990 VW Corrado G60 - "The Track Wh0re"
RIP: Too many VW's and Volvos to count!!!
#2 theunderlord
theunderlord
  • PipPipPipPipPipPip
  • 14,738 posts
Posted 01 November 2004 - 10:45 PM
QUOTE(MACH FYV @ Nov 1 2004, 03:38 PM)
Hey gang,
readily available? what Mboards are you talkin' about?
#3 mAydAy
mAydAy
    Team Spec Clutch
  • 1,466 posts
Posted 01 November 2004 - 10:58 PM
16g is a TD05 exhaust housing. Some of them (Ones with regular T3 style flanges) with some modding of the exhaust manifold can be made to work....
1998 V70XC
1994 850T
1994 850 NA 5spd
#4 prasamin
prasamin
    Bipedal Magnaflux
  • 16,242 posts
Posted 01 November 2004 - 11:09 PM
QUOTE(MACH FYV @ Nov 1 2004, 10:38 PM)
Hey gang,
yes, please let us know where the treasure is to be found.
#5 pennybridge pioneer
pennybridge pioneer
  • 494 posts
Posted 01 November 2004 - 11:44 PM
if you're willing to get creative it can be done. You'd want to track down a mitsubishi td05-12b turbo that was used on the 740 and 760 turbo volvo's in 1988 and 1989. Then you'd need to have the 12b compressor housing ported out and have a 16g compressor wheel mounted in it, or you can separate the turbine and compressor housings and mount the DSM 16g compressor housing and wheel on the volvo td05 turbine housing. At this point you'd want to port out the td05 turbine housing and also i guess the exhaust manifold a little bit, just to get the most flow out of the bigger turbo. With this turbo you'll be pushing quite a bit more air and it will probably spool a little slower because of the bigger turbine section, but probably not too noticeable if it can be tuned correctly. A custom "chip" will have to be the way to go because there are no off-the-shelf chips for up-sized turbos other than the more common 19t swap. However if you have the means of tuning it sufficiently it will push LOTS of air and perform mighty fine.
1993 245 with filthy mod
life starts at et0
#6 MACH FYV
MACH FYV
  • 30 posts
Posted 02 November 2004 - 12:26 AM
hehe...well, I have a Mitsu truck, and I've met a few people form my racing days who tune DSM's. 16G's are tossed around quite a bit if you look around the Talon/Eclipse racing circles. I see them all over the place.
So what I'm hearing is...the 16G will NOT bolt right in. I will need to modify, replace, or build a custom exhaust manifold. sad.gif That's a bummer.
What options are there for direct bolt-on upgrades? Would anything that uses a TD-05 housing, as opposed to the 15G's TD-04 housing, require a different exhaust manifold? And if so, are there any tuners who have already fabricated these manifolds? unsure.gif
