Dual Mass To Single Mass Flywheel
16 replies to this topic
#1 turbor850
turbor850
    i am the new pegs
  • 4,188 posts
Posted 01 April 2009 - 03:52 AM
If you go from dual mass flywheel to single mass flywheel, what parts would be required and what would be a good alternative to the "R" clutch ?
Any help of part numbers and what is needed would be great.
I assume I need a 707 pressureplate from Audi and either "R" clutch or something to hold around 400 hp . . . . and would that be all ? ? ?
FIRST TO PUT 20G ON AN 850R
#2 Chilled Man
Chilled Man
    MILFSPEED
  • 30,087 posts
  • Gender:Not Telling
Posted 01 April 2009 - 03:53 AM
QUOTE (turbor850 @ Mar 31 2009, 10:52 PM) <{POST_SNAPBACK}>
just buy a single mass wheel thats it
new $230 ish used $100 ?
only alt to a R clutch is the 707
#3 turbor850
turbor850
    i am the new pegs
  • 4,188 posts
Posted 01 April 2009 - 03:55 AM
QUOTE (Chilled Man @ Mar 31 2009, 10:53 PM) <{POST_SNAPBACK}>
what if I already got a Southbend stage 4 clutch in the car ? can that just work with the single mass wheel ?
#4 EricF
EricF
    tbricks spy
  • 4,163 posts
  • Crew:LBC
Posted 01 April 2009 - 04:03 AM
Depends on thickness of the friction plates primarily I think. If the single mass and dual mass use the same clutch discs, then yeah you can probably just change flywheel and PP.
#5 JoshV70
JoshV70
    Brody
  • 4,542 posts
Posted 01 April 2009 - 04:15 AM
Here's the exact dual mass clutch setup on Matt's car:
Here's the 707 plate and clutch I have for my single mass:
Both items from Southbend.
#6 johnloves850's
johnloves850's
  • 2,439 posts
Posted 01 April 2009 - 12:55 PM
anybody have aluminum fly wheels with their m56's?
i would love to get one for my swap eventually, if people have had any experience with them that is...
1993 960 wagon. Most awesome car evar.
#7 turbor850
turbor850
    i am the new pegs
  • 4,188 posts
Posted 01 April 2009 - 02:24 PM
QUOTE (JoshV70 @ Mar 31 2009, 11:15 PM) <{POST_SNAPBACK}>
ah, very nice Josh
did you get the stage 4 clutch also ? what was that rated at ? and what was the process of getting your set-up ?
#8 JoshV70
JoshV70
    Brody
  • 4,542 posts
Posted 01 April 2009 - 03:46 PM
QUOTE (turbor850 @ Apr 1 2009, 10:24 AM) <{POST_SNAPBACK}>
ah, very nice Josh
Not sure what "stage" I got. Just called Andy at Southbend and told him I wanted a Sachs 707 plate with a 6 puck "feramic" clutch. I had to repin my flywheel for the pressure plate which wasn't a big deal.
#9 Chilled Man
Chilled Man
    MILFSPEED
  • 30,087 posts
Posted 01 April 2009 - 03:50 PM
josh what all did that end up running total ?
#10 JoshV70
JoshV70
    Brody
  • 4,542 posts
Posted 01 April 2009 - 03:51 PM
QUOTE (Chilled Man @ Apr 1 2009, 11:50 AM) <{POST_SNAPBACK}>
It's been awhile. Somewhere around $500?
#11 Chilled Man
Chilled Man
    MILFSPEED
  • 30,087 posts
Posted 01 April 2009 - 04:37 PM
QUOTE (JoshV70 @ Apr 1 2009, 10:51 AM) <{POST_SNAPBACK}>
that was the clutch and repining the fly wheel or ?
#12 JoshV70
JoshV70
    Brody
  • 4,542 posts
Posted 01 April 2009 - 04:47 PM
Clutch kit.
#13 mAydAy
mAydAy
    Team Spec Clutch
  • 1,466 posts
  • Crew:ECC
Posted 02 April 2009 - 01:24 AM
Throwout bearing/clutch slave cylinder setups are different (in their OEM setup). The single mass cars ran an external slave cylinder that pushed a lever arm onto the throwout bearing. Dual mass cars ran an internal slave cylinder/throwout bearing assembly.
That said, I'm not sure if it matters if you run an external slave cylinder with a dual mass flywheel, or an internal slave cylinder with a single mass flywheel, all I know is that it changed over with the flywheels.
1998 V70XC
1994 850T
1994 850 NA 5spd
#14 Carbon_R
Carbon_R
  • 558 posts
  • Crew:LBC
Posted 03 April 2009 - 12:01 AM
You can haz a single mass flywheel but you need to use a single mass design clutch.
R clutch, SPEC or South bend.
The dual mass pressure plate is different, I have a 99 tranny that was designed to run with a dual mass but I use the internal slave design, SPEC stage 3+ clutch for the T5R as listed on thier website and a single mass flywheel.
Just make sure your flywheel has squares (new design flywheel) not holes (old style), I have the old style and misfires galore. Need to replace my flywheel to the new one.
#15 JHEIII874T5M
JHEIII874T5M
    Level 6 Senior Member
  • 14,845 posts
Posted 04 April 2009 - 01:46 PM
QUOTE (Carbon_R @ Apr 2 2009, 08:01 PM) <{POST_SNAPBACK}>
Have you tried swapping crank sensors to the other style (longer vs. shorter)?
Edited by JHEIII874T5M, 04 April 2009 - 01:46 PM.
Joseph H. Essaye III
#16 Carbon_R
Carbon_R
  • 558 posts
  • Crew:LBC
Posted 04 April 2009 - 06:23 PM
QUOTE (JHEIII874T5M @ Apr 4 2009, 07:46 AM) <{POST_SNAPBACK}>
#17 socal850tuner
socal850tuner
  • 1,238 posts
  • Interests:cars....
  • Crew:SCC
Posted 05 April 2009 - 04:26 AM
QUOTE (johnloves850's @ Apr 1 2009, 05:55 AM) <{POST_SNAPBACK}>
I haven't heard of any but if u get a custom one let us know how it goes. Depending on how much less it weighs that is a good deal of improvement.
'97 850 T5; K&N cone filter, IPD Sway Bars, Powerslot Slotted Discs, Strut Brace, IPD Poly upper engine mount, Voodoo mbc, MSD Blaster SS, Magnecor Spark plug Wires, Autometer Boost gauge on A-pillar, Pioneer Head unit, pioneer 5 1/4" up front and pioneer 6"x9" in the back, Rockford 450w amp, ~600 MTX 10" Sub, pioneer back door speakers, and 3.5"clarions in the dash
projects: Porsche 2.8 race, Porsche 2.0 race(complete), Porsche 3.2 street (complete), Porsche 3.4TT street(complete), Porsche 3.0 street (complete), Porsche 3L twin-plugged carbed street rocket(complete)
2K Motorsports
