Custom Tuning
Started by ROB @ VMS, Nov 02 2004 07:14 AM
12 replies to this topic
Posted 02 November 2004 - 07:14 AM
Everyone talks about Boost controllers, air fuel controllers, ect ect . While this area has not been explored much its hard to really find the best way to tune your car. There is the standard Flash, and prom upgrades done by many of the ecu tuners for the volvo market. Custom Tuning is becoming more important as alot of you guys are wanting to make some good power and are worried about chip tuning.
You have your 4.3,4.4 and me7 ecus. what are the limitations ? Its been proven the stock ecu system can work very well but when some people ask for the "19T" map or "a custom file". I would like to get into what really needs to be done.
For instance you are installing a 19T turbo what map do you ask for? Whom to do get the map from? Upsolute and Rica both are a good option. The posts really explains where to start.
1. Injectors size is the first thing they will need to know. Anything over 450cc or so will require that be done first. Make sure they know what you are looking for and what other parts you have. Then start a forsay 18psi and work on getting the correct fuel maps. This may take many times but we got it right on the 2nd -3rd map on my 01 C70.
2. Once they provide you what i call a "base map" you need to get fuel charts and set the fuel curve. Once this is done you are at a good point to raise boost once again if you have the right parts and then you go through the fuel tuning game again.I will share alot of my tuning results with you to show more of what i mean. I just figured i would take the time to tell you and figured this would be a good place to post info.
99 C70 5sp
- Full Vms long block
-ARP Head Stud Kit
-Custom Intake Manifold
-Custom Tubular Manifold
-Tial 38/40mm External Gate
- Hhs Ssq Bov
- Walbro 255lph pump
- RC 550cc Injectors
- -8AN Braided fuel lines
- Rica custom Tuning
VolvoMotorSports
Posted 02 November 2004 - 07:30 AM
I want to get my Upsolute re-tuned for my 19T (I have one of Bill's 19T maps), but I really don't want to wait for weeks and weeks while the ECU is shipped to the tuner, re-tuned and shipped back. I've had this "base map" on my relatively heavily modified car (stock motor tho). The map was also set for orange injectors and now I am running blue injectors.
Can anyone who re-tunes gaurentee a quick turnaround on the ECU and arrange for 1 or 2 day shipping?
If so I'll go to a dyno or get a/f charts ASAP.
1994 850 Turbo Chassis. 151,000 miles. 1995 HPT motor 15,000 miles, M56H transmission/R clutch. 19T, BSR 3in downpipe, 3in electronic exhaust cutout, IPD 2.5in cat-back. EST Intercooler, Samco intercooler hoses, custom intercooler pipe (metal replacement for stock plastic piece), Greddy Type-S BOV, Aquamist 1S 0.7mm @ 12PSI, Upsolute ECU @ 1.4bar (~21psi), Lotek tripple pod, Greddy Boost, Oil Pressure, EGT gauges, Greddy Catch Can, Greddy Turbo timer, Bilstein shocks/struts w/IPD lowering springs, IPD swaybars, OMP strut tower bar, 17in Alba wheels, 320mm front brakes, X-drilled and slotted, EBC greenstuff pads all around, Bridgestone S-03s 225/45/17s. Gemini Carbon Fiber Hood, Jewel headlights/clear corners.
Posted 02 November 2004 - 08:41 AM
If you get me the air/fuel charts im sure i can get a new map avalible to you. if you send the ecu to them on a monday im sure you can have it back by thurs. You have to pay shipping but i would be glad to get something done for you.
99 C70 5sp
-ARP Head Stud Kit
- Hhs Ssq Bov
VolvoMotorSports
Posted 02 November 2004 - 09:40 AM
As long as I know Unichip is doing custom mapping on the dyno. I have talked to a distribuyer in Izmir they are connecting the car to a dyno and load the zero map and then accelerate by 1000 rpms. after that they reload the map and custumize it. Depending on the car this 1000 rpm steps might go as low as 250 rpms.
<!--coloro:#000099--><span style="color:#000099"><!--/coloro--><!--sizeo:5--><span style="font-size:18pt;line-height:100%"><!--/sizeo--><!--fonto:Courier--><span style="font-family:Courier"><!--/fonto-->2000 V70 T5 Auto @90K Km. full stock.At <strike>the dealer for a rebuilt</strike> home <!--colorc--></span><!--/colorc--><!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc-->
Euro spec Clear Headlight + Turn Signals+Strut Brace+Engine Protection Plate has arrived and <strike>waiting to be</strike> installed
Posted 02 November 2004 - 10:16 AM
I have an upsolute place within 2 miles of my house. Drive in, drive out tuning. But I'm not gonna get my chip from them.
Posted 02 November 2004 - 10:58 AM
QUOTE(Nebor @ Nov 2 2004, 04:16 AM)
where do you live?
Posted 02 November 2004 - 01:56 PM
That is why I had my ECU socketed for my chip that way all my local tuner had to do was send my A/F maps in to Austria via E-mail and then he would burn a new chip for me to try out and I would install it in the socket.
1998 S70 T5 5-Speed
Upsolute ECU @16 Pounds Boost
243Whp / 285 Wtq
243Whp / 285 Wtq
Posted 02 November 2004 - 04:06 PM
and who did this for you?? How does a socked ECU work?
CHEAP PERFORMANCE PARTS
DIGITALSPEED CC
[b]We Carry Koni, Eibach, H&R.......
can be found here ---> Pics of my spaceship
wee my car dips like a banana in the chocolate
DIGITALSPEED CC
Posted 02 November 2004 - 04:26 PM
QUOTE(ROB @ VMS @ Nov 2 2004, 12:14 AM)
Hey Rob,
wasn't Terry/vms offering remap setups, just wondering since he is doing my motor I would like to get it done from you guys ounce i am ready.
Posted 02 November 2004 - 05:39 PM
QUOTE(C70Jeo @ Nov 2 2004, 12:06 PM)
My Upsolute Dealer Sonny Lowe did the work for me. He unsolders the original Eprom and then solders in its place the eprom socket. The regular Eprom then inserts into the socket, the eprom can be taken off without having to be unsoldered and resoldered again, etc. He does very good work, I would highly recommend him anytime.
An EXAMPLE is it like this WITHOUT all the resistors, wires, etc. The bottom piece is the socket, the top part inserted is the EPROM.
Edited by JDELUNA, 02 November 2004 - 05:47 PM.
1998 S70 T5 5-Speed
243Whp / 285 Wtq
243Whp / 285 Wtq
Posted 03 November 2004 - 03:01 PM
I would sure hope that it does not look like that. GOOD LORD that is an electrical hack job if i ever saw one.
Is there duct tape and zip ties on that ECU somewhere too?! Glad thats not your ECU.
1995 850 Sedan T-5, Custom Chip (European Based Code), Turbonetics CBB T3/T04E, 3" Custom Downpipe, HKS Wastegate, 2.5" BSR Cat-Back, 1 Missing Cat (now where did I put that thing?), 440cc RC Engineering Injectors, TurboXS Racing, Bypass Valve H-34 Type, Walbro 255LPH Race Fuel Pump, Aeromotive FPR, Aquamist 1S, Jacobs Ignition, Apex AVC-R, Apex S-AFC, Custom CAI/Ram Air System, Samco Silicon Hoses, Greddy E-Guages, 302mm Brake Conversion w-Slotted Rotors & Race Pads, Braided SS Brake Lines, KW Suspension Stage 2 Coilovers, IPD Anti-Sways, OMP Front Strut Bar, Euro Headlights, Euro Corner Lights, Side Marker Lights, Volans
My Dirty Engine Bay
My Dirty Engine Bay
Posted 03 November 2004 - 04:47 PM
QUOTE(erikbergum @ Nov 3 2004, 11:01 AM)
LOL !!!
1998 S70 T5 5-Speed
243Whp / 285 Wtq
243Whp / 285 Wtq
