Help!
#1 BlackT5
BlackT5
    NWC Rod Bender
  • 5,765 posts
Posted 04 April 2009 - 06:44 PM
So I just had a piece of the o-ring from the oil dipstick go into the pan. sad.gif I drained the oil and it didn't come out. Is this going to be a problem? Obviously it's not going to get sucked up the oil pickup, I just don't like the idea of it in there.
1998 S70 T5M
#2 AlvinL
AlvinL
  • 2,104 posts
Posted 04 April 2009 - 07:43 PM
#3 Jack8745
Jack8745
  • 1,128 posts
  • Interests:not facebook
Posted 04 April 2009 - 07:52 PM
you're fine
K.I.S.S. - Keep It Simple Stupid
'97 854 GLT | 16T | ARD Green | OBX full exhaust | R Mani | NA TB | Unorthodox Racing Underdrive Pulley | etc...
#4 Dan2286
Dan2286
  • 127 posts
Posted 04 April 2009 - 09:53 PM
Dont feel too bad, I had a leaf fall into the distributor hole on my Cutlass. I cant let that go, because if it gets sucked into the pick up tube it could ruin a fresh engine rebuild pretty fast ohmy.gif
I would not worry about a piece of o ring. It will most likely just sit at the bottom of the pan and do nothing. Even if it gets sucked into the pick up tube, it wont get past that. Im sure it will come out with the oil one day.
