Obdll Codes?
8 replies to this topic
#1 SIXER
SIXER
  • 147 posts
Posted 01 May 2009 - 11:37 PM
So i put the car on the code reader today and two codes came up p0172 system too rich (Bank 1) whats the cause of this?
and p0505 Pd Idle control system malfuction i guessing this has something to do with the idle control valve? So is this on the way out and what will happen if it goes? Thanks. C.J
1998 S70 T5 SE
#2 misa
misa
  • 313 posts
  • Interests:Volvos,girls,body-building...
Posted 01 May 2009 - 11:54 PM
About idle control valve....you may try to clean it with brake cleaner.Sometimes oil from flame trap comes in it and clogg it a little bit.
When you clean it you must disconnect it first,and before reconnect,dry it very well.
Repeat cleaning process few times if neccessary(untill almost all oil comes out).
Not brake cleaner-carbon cleaner.
'97 850 2.5 20v /fully equiped/ polar white wagon
'85 340 1.4 gls silver/gold metallic
#3 SIXER
SIXER
  • 147 posts
Posted 02 May 2009 - 12:03 AM
[/quote]
do you have any names of brand of that cleaner?
1998 S70 T5 SE
#4 MrWinkey
MrWinkey
    Am I drunk? You tell me!
  • 4,759 posts
Posted 02 May 2009 - 12:08 AM
Clean your IAC motor with Carb clean and your MAF with MAF cleaner, clear codes and see what returns
"SMOKE TROUT NOT CRACK"
#5 SIXER
SIXER
  • 147 posts
Posted 02 May 2009 - 12:32 AM
QUOTE (MrWinkey @ May 2 2009, 01:08 AM) <{POST_SNAPBACK}>
ok sounds good thanks so do you think the two codes came on because of each other? because i cleared them and the only one that came back right away was the p0505 Pd
1998 S70 T5 SE
#6 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,481 posts
  • Gender:Not Telling
Posted 02 May 2009 - 12:40 AM
Cleaning the idle motor is a very good idea. When it is is clean you should be able to shake it and hear it clicking.
The other DTC you posted won't come back immediately because it is a fuel trim code and the ECM has to adjust fuel trim to a certain point before it will post a DTC. A good visual inspection for vacuum leaks wouldn't be a bad idea either.
98 S70 T5M
#7 JC 855 GLT-R
JC 855 GLT-R
  • 5,404 posts
  • Interests:volvos obviously, benzs too, snowboarding, modifying things and tinkering with things...
Posted 02 May 2009 - 12:51 AM
whats the mileage on the car??
1993 Mercedes-Benz 190e 2.3 91k still broken
1996 Volvo 855 GLT-R 320+k and going ( Project GLT-R)
1998 Subaru Outback SUS -Daily Driver
Volvo for LIFE......
Parts for sale
#8 SIXER
SIXER
  • 147 posts
Posted 02 May 2009 - 05:52 AM
QUOTE (AZNJippiJAk @ May 2 2009, 12:51 AM) <{POST_SNAPBACK}>
248000KM
1998 S70 T5 SE
#9 SIXER
SIXER
  • 147 posts
Posted 10 May 2009 - 11:26 PM
So i cleaned my IAC and my MAF and the codes are gone, made a big difference.
o yah and that little hose thats connected to the side of the intake maniflod i forgot
to attach that when i was doing the pvc ,but all is well now the codes are gone and car
is running good.
1998 S70 T5 SE
