95 850 turbo
Fan is coming on intermittently (less times than more)
Check the fuses= good (how ever did not switch out the big J marked overload fuse)
Checked the fan and even tried a different fan= good
used a good fan relay= good
Checked the circuit to see if its getting juice= good
If it makes any difference the guy who usually works on this car tied the coolant intake and outake pipes together since she need a new heater core but does not want to spend the money on it right now.
Any suggestion appreciated
*** the 2 min update after I posted***
I searched for +radiator +fan, +overheating + fan...with no luck. I look 7 posts down and I see a similar thread...go figure
