I had an electical meltdown in some wires that, according to my mechanic, went to the ABS/TRACs unit. He said they were melted beyond repair and given the cost, he reccommend just cutting everything out, and killing the ABS/TRACs system.
Now, my speedo/odometer are non functioning, which he tells me, after the fact, is because of the removal of the wiring to the ABS system.
Does this add up or I am getting fed a line?
Needless to say, I am not happy about this developemnt at all
Speedo Connected To ABS/TRACK?
Started by Guest_Josh_*, Jun 02 2009 01:54 PM
8 replies to this topic
#1 Guest_Josh_*
Posted 02 June 2009 - 01:54 PM
Posted 02 June 2009 - 02:00 PM
Sounds possible, not sure why they melted?
You can just run the speedo wires directly to one of the ABS sensors, driver's front is closest.
#3 Guest__*
Posted 02 June 2009 - 02:51 PM
Thanks for the reply.
So, you are suggesting that the ABS wheel sensor would send a speed signal directly to the speedometer?
The wires from the sensor should be fairly easy to locate but any thoughts on how to identify the speedo wires? Not sure I would even know where to look.
P.S. Its an '98 GLT.
Posted 02 June 2009 - 03:06 PM
I know that my speedo didn't work when the ABS module was out of the car being fixed, so I think you are being given correct info.
Posted 02 June 2009 - 05:50 PM
+1
1998 V70 T-5 -Auto / Pewter - Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
Posted 02 June 2009 - 06:58 PM
Wouldn't it be fairly easy / cheap to go to a salvage yard and cut out a section of wiring harness to match the section that melted, then just splice it in to the good sections of the old wires (probably where the mechanic has already cut them out). Gets you the ABS and Tracs as well as speedo, which does have a value.
Mike Sullivan
Currently: '09 XC70 T6 (3k); '95 855T (128k),'84 MB 380SL (94k summers only).
Kids cars: '98 S70 T5M (130k), '98 V70 M (116K).
Prior Volvo's: '85 744 (256k), '86 245 (165k), '86 245 (195k), '88 745 (208k), '91 745 (196k), '93 965 (147k), '95 855 NA (190k), '98 XC (98k), '07 XC70 (40k).
Posted 07 June 2009 - 02:47 PM
I had intermitant speedo inop problems. Sourced problem to ABS control module. Contacted modulemasters.com and had module rebuilt for I believe around 120 bucks with 5 year warranty and got new bolts with the kit to install re-conditioned module. Speedo has worked great since. I had a very good experiance with them, would advised 2 day priority shipping if on east coast as their office is in Idaho.
1996 Volvo 850 Turbo Wagon / Automatic, 18 inch wheels
18t Turbo, OBX Turbo Back Exhaust, Tuned Ecu, Front Mount Intercooler (2.5 inch piping), IPD CBV, Greddy ProfecB Boost Controller, Greddy Turbo Timer, AEM Wideband, AEM Boost Guage, IPD Plug Wires
Posted 08 June 2009 - 03:18 AM
I used to have the ABS light on my 96 850. Didn't do anything about it for a couple of years. Then I noticed intermittent speedo/odo until one day both speedo and odo just stopped. At thi point, I decided I need to do the ABS ECU fix. After I did, ABS light was gone and speedo/odo was working again.
Posted 08 June 2009 - 04:49 AM
so yeah my speedo dont work since i did my N/A to Turbo swap the abs ecu is just fine and there is nothing unhooked so in theroy i should beable to just tap from a wheel speed sensor or the sensor from the trans and run 2 wires to the speedo and it should work right ?
-Pat-
'99 S70 AWD
'94 855 Turbo 5spd BUILT NOT BOUGHT
'99 S70 AWD
