2000 S80 T6 Help With Loose Hose
9 replies to this topic
#1 striza
striza
  • 47 posts
Posted 04 June 2009 - 06:34 PM
Attached File  DSCF2320.JPG   1.82MB   40 downloads
I think this is what is causing the stalling.
If someone could post a picture of their setup if possible
2000 s80 t6
#2 flyfishing3
flyfishing3
    Confused For Small Bear
  • 14,397 posts
Posted 04 June 2009 - 06:35 PM
too many POWAAHS shook the booster blaster loose.
Double R garage
#3 striza
striza
  • 47 posts
Posted 04 June 2009 - 06:52 PM
seriously man that thing was a joke.... but no clue where it goes?
2000 s80 t6
#4 flyfishing3
flyfishing3
  • 14,397 posts
Posted 04 June 2009 - 07:02 PM
looks like the part its connected to is the TCV. check for a nipple near the MAF.
Double R garage
#5 striza
striza
  • 47 posts
Posted 04 June 2009 - 07:20 PM
nothing and now im clueless
2000 s80 t6
#6 rbodor3
rbodor3
  • 1,029 posts
Posted 04 June 2009 - 07:37 PM
what color does the hose have?
yellow - goes to wastegate actuator
red - vac to the turbo
blue - goes to the air intake ducting
looks like yours is the blue line, so follow the air intake duct (hard plastic ~3" diameter hose from the air filter house) to the back of the engine. You should see there will be a plastic nipple where this hose will go to. It should have a spot of blue paint on it if it hasn't rubbed off. Resecure this to that line, use some zipties if you don't have the green clamp anymore.
01 Volvo S60 LPT Powered by ARD
3" DP & back | ipd sways and links | Bilstein & Eibach sport | R - BBK | B&M Cooler | 19T | ipd CBV | Quaife | M56lk | greens | FMIC | Snabb | ACD TCV | ARD crank pulley
Looking for S60 Radiator (broken okay) to make aluminum replacement!!
#7 striza
striza
  • 47 posts
Posted 04 June 2009 - 07:46 PM
got any pics?
2000 s80 t6
#8 S8ET6
S8ET6
  • 1,312 posts
Posted 04 June 2009 - 09:27 PM
IIRC, there should be a check valve near your air box that that plugs into.
Can't verify it now, but I'll check back and post pics if necessary
Edit:
that hose should go to the nipple on air intake hose. The nipple is located on the black plastic tube coming across the top of your motor, just before where the intercooler hose connects
Posted ImagePosted ImagePosted Image
294WHP/312WTQ MY GARAGE
#9 striza
striza
  • 47 posts
Posted 04 June 2009 - 10:26 PM
thanx alot man i found it appreciate it
2000 s80 t6
#10 arthur volvo
arthur volvo
  • 1 posts
Posted 07 June 2009 - 09:58 AM
nice car
