Cv
5 replies to this topic
#1 ceesenacho
ceesenacho
  • 15 posts
Posted 16 June 2009 - 12:58 PM
the inner joint popped apart, is there a quick fix till i get the new shaft? nothing else was damaged, i got lucky.
thanks oskar the newbie
#2 dykaar
dykaar
  • 142 posts
  • Interests:Cars, Bultacos, Skiing, Tennis
Posted 16 June 2009 - 01:49 PM
I replaced the boot on the outer, and the shaft was held in the CV cage by a circlip. Did you find the one for the outer?
Or did you mean the spline on the end? The splined shaft "pops" into the tranny. I'm guessing that means a spring loaded ball, like on a socket wrench.
Regards,
doug
Waterloo, Ontario Canada, eh
1986 951
94 855 turbo -> 01 E320 4matic Wagon
00 540
I apparently only buy cars designated by numbers
#3 ceesenacho
ceesenacho
  • 15 posts
Posted 16 June 2009 - 03:11 PM
the joint close to the tranny not the wheel and not the spindle. i was replacing shocks and the wheel fell to the ground, the boot clamp slipped off and tripod came out of the cage. i managed to get everything back together and used a zip tie to keep the boot on. i havent driven it yet but keeping the old fingers crossed, the whole thing looks rather simple. i wonder how safe it is. should a taken a pic, shoulda coulda woulda, famous last words.
#4 AlvinL
AlvinL
  • 2,104 posts
Posted 16 June 2009 - 03:13 PM
You should be able to pop it back in unless you damaged something. Is the inner boot ripped?
#5 ceesenacho
ceesenacho
  • 15 posts
Posted 16 June 2009 - 03:44 PM
the boot is fine, lost some grease though
#6 ceesenacho
ceesenacho
  • 15 posts
Posted 16 June 2009 - 04:32 PM
just got back from a test run, front end feels awesome. definitely worth the time
