Vol-Fcr And Obd2 Usb-Cable Problem
27 replies to this topic
#1 akka
akka
  • 2 posts
Posted 20 June 2009 - 09:36 AM
Hi Forum Members,
I am new to this forum, this is my first post. I found a topic here, but is unfortunately closed, so i decided to open a new one to get ideas (hopefully) to my problem.
I have a 1996 Volvo 850 with speedometer problems (sometimes it stops showing actual speed while driving - then odometer also stops).
I was told that it might be an ABS related problem. So I purchased an USB KKL 409.1 OBD2 cable (this) from ebay. I downloaded VOL-FCR SERIAL demo (also tried usb version - doesnt work at all). The cable's virtual port was set to com1 as suggested in the above linked topic.
The software was able to establish a connection to the car, it was able to query model and software IDs but then it failed reading trouble codes saying 'comms lost with car, null time out or message error'.. Attached File  volfcr1.jpg   19.49K   61 downloads
I dont know what might be the problem, I would be very thankful if someone could help me out with a good advice!
#2 Ozark Lee
Ozark Lee
  • 1,400 posts
Posted 20 June 2009 - 11:57 AM
I made the serial version of the program work but I bought an actual serial interface cable to do it. I am at my cabin at the moment and I can't give you the specific number of the cable. There are a couple of versions of USB to serial converters that have been said to work but I have no specifics. The big problem is that most laptops don't have a serial connector anymore - I knew there was a reason I kept the old IBM think pad around even with the dead batteries. Rumor has it that there is a cracked full functioning version of the program on bit torrent.
I will be back in the city on Sunday and if no one else has given you the specifics on the cable I will post back the numbers on the one that worked for me.
...Lee
'98 S70 T5
'96 850 Platinum Edition Turbo
'96 850 N/A
'94 850 N/A
Previous: 1989 740 GLT , 1986 740 GLT, 1972 142 Grand Luxe
#3 AverageVolvo
AverageVolvo
  • 1,634 posts
  • Interests:Woman,Cars,Guns, Sex, Music.
    And making $$$ to fund the above.
Posted 20 June 2009 - 05:57 PM
FCR only works on 96-98 volvos.
The serial cable works best
You need to Crack the software, they only include a demo and it says lost communication when you try to read or erase dtc..
email me @ justanothervolvo@gmail.com
I can help you out ; )
As for your speedometer, possibly ignition switch, Try gently turning the key back and forth when the can is running.
Possibly ignition switch, when the car is runnig gently wiggle key back and forth and see if that helps.
96 850 (412) wagon W/2 racing seats no rear seats, ..Converted to M56h with Quaife. R clutch,Kw v2 coilovers, qbm end links,Ipd sways,strut and shock braces/ Front/rear lower Ultra racing chassis braces. Team Dynamic 17in rims 17lbs .Poly mounts on trans, engine and firewall.Porsche Bbk, Ss lines, Super Blue Ate.5mm Spacers,Rolled Fenders,R Manifold, T04E 50 trim @18psi. Divorced WG and BOV ,3in Downpipe, gutted 3in cat,2.5 tme/Ipd catback Gizzmo Ebc, 1 gallon Aem progressive Meth Injection kit. Walbro 255. Na mani W /960 plate and Na Silicone Tb hose. Boost/egr/wideband gauges dash mounted. Double Din touchscreen Nav. 12in Fosgate p3 and 2 Alpine amps/ + Cf spoiler+ V70 stuff.
#4 JordanW
JordanW
  • 398 posts
Posted 22 June 2009 - 08:03 PM
if you are able to adjust your virtual comm port settings, slow it down, less then 9600. Try also adjusting UART settings. If that's an acutal screen shot, you got the usb cable to work, as it can atleast qury the controller. However, you'll need the crack for the software.
*-J-*
#5 Dan A
Dan A
    Old Man Crew Pledge Pres.
  • 1,808 posts
Posted 23 June 2009 - 03:14 AM
If you are using the USB cable, then most likely you are not running on the COM1 port.  COM1 is typically reserved for the serial port.  Try the other COM ports.  You can also look in your Device Manager to find exactly which port it's running on.
#6 akka
akka
  • 2 posts
Posted 23 June 2009 - 09:44 AM
Thank you guys for the answers!
Actually Jordan was right, playing with the COM port settings (setting it less then 9600) helped, now i am able to read DTCs.
The cable and software i used were: obd2 kkl usb cable with ft232b chip inside from ebay, vol-fcr 1.3.6 serial version and the driver from http://www.ftdichip....Drivers/VCP.htm
If you guys could share with me the difference between the 1.3.6 and the newer software versions (what has the newer more?) i would be thankful!
#7 T5power
T5power
  • 4,773 posts
  • Interests:Underwater Basketweaving
Posted 30 June 2009 - 07:02 AM
where did you guys find the demo of FCR? I have been looking for about a half hour and i cannot find it....
///T5
#8 JC 855 GLT-R
JC 855 GLT-R
  • 5,404 posts
  • Interests:volvos obviously, benzs too, snowboarding, modifying things and tinkering with things...
Posted 30 June 2009 - 01:34 PM
i got the program still trying to figure it out
1993 Mercedes-Benz 190e 2.3 91k still broken
1996 Volvo 855 GLT-R 320+k and going ( Project GLT-R)
1998 Subaru Outback SUS -Daily Driver
Volvo for LIFE......
Parts for sale
#9 JordanW
JordanW
  • 398 posts
Posted 30 June 2009 - 03:30 PM
You can search for it on ebay and usually purchase it with a cable. I'm sure if you really search you can find it other places... Below is the support info from the program.... On their website is a link that will take you to a chart that shows the Volvo models and what functions are available to each model. Its a decent program, but worth no more then $30.00. Becareful on cars with Motronic 4.3- it won't pull OBDII or diag. codes... It tells you how to use the OBDII port to pull blink codes eg(2-1-1)
Vol-FCR™, Fault Code Reader for Volvo ™ Cars. Version Beta 1.3.06
Copyright cr-diagnostics © 2002, 2003.
Supplied by:
ilexa
PO Box 111
Truro
Cornwall
United Kingdom
TR2 4YF
www.onboarddiagnostics.co.uk/volfcr
For technical support:
Tel 0870 7543 827 Mon-Fri 09:00-18:00 (GMT) or Fax 0870 7543 829 Anytime.
e-mail
volfcr@onboarddiagnostics.co.uk
This program is designed to read & reset fault codes on Volvo ™ cars.
The program has no connection with the Volvo Car Corporation.
The program will only work on Comm Port 1.
Some S/V 40 engine functions have not been implemented and are disabled.
No liability can be accepted for use of the program or the information presented.
You may wish to print information from the program, the easiest way to do this is to press the Alt + Print Screen keys to take a snap shot of the screen then press 'Go Back' to stop comms and finally paste the screen into a program such as Wordpad, save the result and print / e-mail as required.
-Scroll Down for more-
On ‘96/’97 850 cars with the 16 way ‘OBDII’ socket, and some other models, some of the control modules use ‘flash’ codes, this program is not designed to work with these modules.
The controls for these have been coloured yellow in the program.
THE USE OF THE FOLLOWING INFORMATION IS ENTIRELY AT THE USERS RISK
To retrieve the flash codes the following procedure can be adopted:
Connect an LED, with the correct polarity, in series with a 1k8 ohm resistor, between pin 16 (+) and pin X, where X is the pin corresponding with the module to be read. Connect a push to make switch between pin X and pins 4 or 5 (-).
The circuit can then be used in the same way as the pre ’96 diagnostic sockets, situated in the engine compartment.
For
Motronic 4.3 or Fenix 5.2, X = 3.
ECC , X = 6, Timer Type 4, X = 9.
Cruise Control, X = 13; 900 & S/V 90 ABS, X = 12 .
*-J-*
#10 exitspeed
exitspeed
  • 1 posts
Posted 27 June 2011 - 03:15 PM
Has anyone figured out the com port settings when using the ftdichip driver? I can read codes fine, however, when I attempt to clear the codes I receive the com error. I have set connection speeds to 9600 buad but there are additional settings in the com port advance tab that probably need to be changed. Unfortunately, I do not have time to wait for a serial cable nor do I have access to a loptop with a serial port. Any help would be very much appreciated. I need to pass va inspection this week.
#11 misa
misa
  • 313 posts
  • Interests:Volvos,girls,body-building...
Posted 28 June 2011 - 01:48 AM
...If you guys could share with me the difference between the 1.3.6 and the newer software versions (what has the newer more?) i would be thankful!
Newer versions are not anymore serial to obdII port.They are usb to obdII port and the other difference is that they can display live data.
'97 850 2.5 20v /fully equiped/ polar white wagon
'85 340 1.4 gls silver/gold metallic
#12 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,554 posts
  • Interests:Volvo's, football, and finishing school.
Posted 28 June 2011 - 02:10 AM
I don't know about the computer stuff since I just bought a reader from ebay for like 30 bucks done. as for the speedo if you have a 96 850 then your speed sensor comes from the abs. most likely its the module. there is a guy on here the is good at fixing them and is well priced. as for the tach. not working there is a cog in the re that is relatively easy to replace, just go slow and you wont have a problem. this is what I used to fix mine. My link
1996 850 turbo wagon auto, Custome intake, MSD coil, IPD spark plug wires, Eibach springs, Bilstiens HD, Mesh grill, IPD strut tower bar,ultra racing 2 point rear strut bar, Tiki end-links,IPD intake manifold spacer, FCP silicone inter-cooler hoses, stoptech steel braided brake lines front and rear, completely rebuilt auto tranny, Complete stage zero. soon to have (white injectors, s70 front end, 16t, ARD tune)
#13 Anatoli
Anatoli
  • 731 posts
Posted 28 June 2011 - 06:42 PM
VOL FCR and vag come cable ($10) worked great for me.
Only a few times I had to set the COM port in device manager, because it was not recognizing number other than 1 IIRC.
I used it for both of my 97 854GLTs and also on 96 base.
(03 V70 2.4i at -- 17X kmiles)
(00 v70XC FWD LPT at -- 18X kmiles)
#14 AverageVolvo
AverageVolvo
  • 1,634 posts
Posted 28 June 2011 - 07:49 PM
Zombie Thread, bringing it back from the dead Posted Image
This thread is days short of 2 years old Posted Image
#15 Anatoli
Anatoli
  • 731 posts
Posted 29 June 2011 - 03:28 PM
maybe so, but it warms my heat to know that I was not the one to revive it :ph34r:
#16 schigara
schigara
  • 2 posts
Posted 16 January 2012 - 01:46 AM
Hey guys, Old thread but maybe someone has some info pertaining to my problem. I purchased the Volvo FCR cable from ebay with a serial port end instead of the usb. For some reason I thought the serial version was better than the usb. Of course, my laptop has no serial ports so I also bought a ExpressCard serial port.
I set the add on serial port in device manager to com1. The FCR program can't communicate with the car. I tried lowering the baud rate and adjusting the Uart settings but still no go. Will a usb to serial adapter work or should I just try to find an FCR cable that has the usb plug?
#17 Keaton85
Keaton85
  • 6,426 posts
Posted 16 January 2012 - 02:29 AM
Get a cheap-o ebay USB vagcom cable and be done with it. don't bother with serial...
#18 schigara
schigara
  • 2 posts
Posted 21 January 2012 - 03:55 AM
I did just this. The cable came today and worked fine. I cleared the SRS code that I set when I replaced to odometer gear and started the car while the passenger airbag was unhooked.
#19 Cmercon
Cmercon
  • 7 posts
Posted 29 February 2012 - 04:36 PM
I have a KKL VAG COM for 409.1 cable and VOL-FCR USB version. I am able to read engine,abs,srs and lock/immobilizer codes. I cannot however reset the service light or access the climate control system (the reason I bought the cable. I receive an error.
Anyone have any luck with these systems and what did you do?
1988 Volvo 740 GLT 4-Cyl, 1990 Volvo 780 Coupe 4-Cyl Turbo
1994 Volvo 850 Wagon GLT, 1995 Volvo 850 Turbo Sedan
1998 V70 Base Wagon
#20 Dan A
Dan A
  • 1,808 posts
Posted 29 February 2012 - 05:10 PM
Fill out your sig so we know what car you are talking about.
99 V70R
98 V70 GLT
