Where Is The T-Connctor Located?
#1 B-RED
B-RED
  • 165 posts
Posted 17 July 2009 - 11:44 AM
I'm trying to replace the headlight washer t-connector:
http://www.fcpgroton...category_id/220
but I am unable to find it. It seems to be hidden/stuck between the condenser and radiator.
93 Volvo 850 GLT: H4 HID kit • Hella MicroDE H3 fogs • 5%-20% Tint •
#2 Alleycat
Alleycat
  • 24 posts
Posted 17 July 2009 - 02:52 PM
Behind and kind of under the right headlight. You can see it if you lay underneath the car and look up with a flashlight. Apparently it's easier to replace if you remove the headlight. Have to do mine also so I'll know for sure after this weekend.
_A_
#3 B-RED
B-RED
  • 165 posts
Posted 17 July 2009 - 07:23 PM
I removed the headlight, but still wasn't able to reach it. I'll post back when I try it from the bottom
_A_
#4 Alleycat
Alleycat
  • 24 posts
Posted 19 July 2009 - 08:37 PM
Just did mine yesterday. You can access it from in front of the radiator with the hood open. The metal cross piece down near the bumper has a clip that holds the hose. I undid the hose from the passenger headlight wiper arm and just gently pulled the hose in front of the rad until the connector was visible. Just make sure you dont loose the passenger wiper hose into the headlight trim piece or it may be hard to get it back through.
As a side note, I bought two t-connectors from the dealership. They gave me identical connectors. The headlight washer connector is actually different as the hoses are smaller. If you have the wrong connector, it makes it harder to get the hoses on the fitting.
_A_
