Oil Leak
8 replies to this topic
#1 Siscos850Turbo
Siscos850Turbo
  • 12 posts
  • Interests:Autos, Car audio, ect.
Posted 05 August 2009 - 02:35 AM
Ive developed an oil leak I think its coming from the Oil Cooler hose, before i found out it was leaking i replaced the CV Axel on the passenger side and gave it an oil change then it started leaking.
1995 Volvo 850 Turbo Wagon all stock.
#2 Modus
Modus
  • 693 posts
Posted 05 August 2009 - 05:46 AM
Top by the radiator or on the bottom? Is this leak a drip or residue?
#3 jdlc
jdlc
  • 1,511 posts
Posted 05 August 2009 - 12:24 PM
Check the connections to the radiator if the leaks are from there.
If it's the hose(s) or crimping to the end of the hoses, they must be replaced - do both at the same time.
Check my sig if you want to save some $.
* SOLD - Joy.D - 98 S70 T5M Blk/Blk, B&G springs/Bilstein HD/TC, ipd TCV, 17psi ST tune, Volans, est short shifter, Forge BOV, SAMCO ic hoses, R-mani, 3" dp/obx exhaust, SAS delete
#4 Siscos850Turbo
Siscos850Turbo
  • 12 posts
Posted 06 August 2009 - 04:20 AM
Bottom and drips, Its the hose close to the oil filter..
#5 FCP Groton
FCP Groton
  • 1,838 posts
Posted 06 August 2009 - 03:13 PM
both hose for the oil cooler come out the bottom front side of the engine. Are you seeing the oil dripping from the line? The reason I ask is because I thought one of my oil lines were dripping and it ended up being the dip stick. It would come out of the tube and drip down onto the lower oil cooler line.
Andrew Owendoff
#6 atefitty
atefitty
    Manuals tighten my pants
  • 430 posts
Posted 07 August 2009 - 04:47 AM
If the hose is wet its probably bad..They usually fail where they are crimped to the metal fittings..I just did mine today..They cost $80 at the dealer..Got mine at a junkyard for $16...Some of the bolts are a little tough to get at...But if you've got the better part of a day to spend on this project you can save a little.
1997 850R
IPD Strut Brace, IPD Boost Guage, EST Intake, TME Catback Exhaust, Bilstein Struts/Shocks, TME Lowering Springs, Wastegate adjust to 6psi, European Side Markers...just new, black jewels and ECU upgrade....next : finally a downpipe!
#7 Siscos850Turbo
Siscos850Turbo
  • 12 posts
Posted 09 August 2009 - 05:35 PM
yeah thats where its leaking from, i hate to drive it around with the leak and auto part store doesnt have the hose for it..
#8 JordanW
JordanW
  • 398 posts
Posted 09 August 2009 - 11:22 PM
$80 at the dealer? WOW, awesome price... I can't seem to find OE Oil cooler lines for less then $100... Where is this dealer?
*-J-*
#9 a2matt
a2matt
  • 109 posts
Posted 10 August 2009 - 12:13 AM
I think I paid ~$180 at DW Volvo for the pair back in February. Also order extra green o-rings, a new $2 metal flange for the oil thermostat housing and a new rectangular o-ring for the oil t-stat housing.
The most important part of this job is to clean out the t-stat housing where the lines go in. When the openings are cleaned out (spotless is the key here), the lines should seat properly with very little effort. Don't overtighten the T30 bolt or you will strip out the aluminum threads on the t-stat housing. I used threadlock on mine. Also, be sure to lube the new o-rings with vaseline or they will rip.
A short L-shaped T30 tool comes in handy on this job.
1998 V70 GLT, 216,xxx miles
